What happens with a slightly smaller water pump pulley?
Old November 16th, 2011, 09:24 PM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
So thinking of getting a smaller water pump pulley so that my belt doesnt rub with the ati idler, which logic would make me think that a fast spinning water pump pulley would cool down the motor and not cause all sorts of problems; however, nothings ever that easy... I'm guessing the faster pulley might cause small air pockets reducing the effectiveness of the pump?
Anyone an expert on water pumps?
Old November 16th, 2011, 09:37 PM   #2
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
worst case senario you spin your pump too fast and it dies, but I cant see that happening with just a slightly smaller pulley. You shouldn't expect any problems, but if you are worried maybe you should get a different idler.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old November 16th, 2011, 09:41 PM   #3
i got the smallest idler they sell... 1.95
was on the phone with procharger and they suggested either a smaller tensioner or water pump pulley, but i'm not finding any in my google search
arent underdrive pulleys larger than stock water pump pulleys?
Old November 16th, 2011, 09:48 PM   #4
2003 gt
5.4 32v on the way
yes, under drive is larger. Something you should watch out for is that you can get a wrong pulley. I think it was somewhere in 01 that ford changed the waterpump/pulley setup so a 99 pulley wont work out with an 03 pump.
Old November 16th, 2011, 09:51 PM   #5
right i have a late model 01, but i'm having a hard time finding any water pump pullies smaller than stock
Old November 16th, 2011, 09:53 PM   #6
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
it sounds to me it maybe cheaper and less head ache to find the proper bracket to fit your year. since that pulley looks to hang to low going to a smaller pulley or altering that setup may have issues with reducing belt wrap and causing un-needed belt slip
bone stock from the factory!
Old November 16th, 2011, 10:12 PM   #7
thats the thing... it is the proper main bracket for my year... there's only one place for that idler pulley to go and thats right there by the alternator
Old November 17th, 2011, 08:50 AM   #8
anyone on coagulation?
Old November 17th, 2011, 09:23 AM   #9
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Maybe an electric water pump? That probably comes with basically an idler pulley which would probably be the same size, I honestly don't know just throwing it out there
Rock stock
Old November 17th, 2011, 09:32 AM   #10
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
Coagulation? You mean cavitation?
Yes, this can happen if you spin the pump too fast. If the impeller is spinning too fast, you get sort of a venturi effect between the impeller and casing, which in that low pressure area will cause vapor pockets, and thus cavitation.
However I don't have the efficiency/velocity maps from Ford to determine how far you have to go for this to happen. I imagine that this would be feasible if you kept the engine RPM low, but would bring the prospect of cavitation at high RPM. Bottom line, I wouldn't chance it.
Another failure mode would be bearing failure. Spinning it faster means higher rotational velocity, which can kill bearings. Your bearings go out, and suddenly it's either leaking like a seive, or the damn thing seizes up and things go south real quick from there.
I would stay away from a smaller water pump pulley unless you go electric, in which case the pulley diameter wouldn't matter.
Look for a different idler.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old November 17th, 2011, 09:38 AM   #11
number1gt's Avatar
2002 mustang gt
Can you use an adjustable idler? I know kenne bell has adjustable idlers
Rock stock
Old November 17th, 2011, 10:01 AM   #12
Sorry thats what I meant, so without changing the water pump, what else can I do though?
Gates makes some idler brackets, http://www.gates.com/idlers/Idler%20Catalog.pdf, but will that work since it's right there at the alternator thats the problem?
Threads Similar to: What happens with a slightly smaller water pump pulley?
Procharger idle pulley and water pump pulley too close? me2dumb4college 99-04 20 November 17th, 2011 11:19 AM
Water pump pulley Chris747 99-04 28 August 8th, 2011 03:48 PM
water pump pulley ZoomZoomMFer 4V / SVT 1 August 7th, 2010 11:31 PM
Does this look like a race underdrive crank pulley & stock water pump pulley? STREETFIGHTER50 5.0 Mustangs 8 January 26th, 2010 10:47 AM
