spring rate for rear coils, and front?
Old November 16th, 2011, 09:53 PM   #1
2003 mustang gt
bigboy05 is on a distinguished road
looks like im going to be getting
79-04 Mustang Maximum Rear Coil Over Kit Silver for Lakewoods
and
1996-2004 Ford Mustang Tubular Chrome Moly K Member Kit - UPR Products
soon so i was wonderin gwhat spring rate you guys wyold go with for a Street/Strip car?... and also if i do the 70/30 shocks out back i need the 50/50 lakewood struts up front correct?
Kenne Bell powered
11.44@121.9
1.59 60 foot
Old November 16th, 2011, 10:01 PM   #2
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
no if your looking for drag setup i would go with a set of 90/10's for the front and 50/50's for the back. it would be better to get ajustible shocks and struts so you can dial it in at the track and be able to increase the rate for the street. as for the spring rate for a gt 175x12 is a good size front, but personaly i would just keep the stock springs front and back to save money
bone stock from the factory!
Old November 17th, 2011, 12:01 AM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
i would not go lakewoods with upr coil overs. If anything go with the set made for the strange shocks. The lakewoods are not built strong enough for the added load and will break the lower mounting eyelet off.
Old November 17th, 2011, 10:04 AM   #4
2003 mustang gt
1994-2002 Ford Mustang Strange 10 Way Adjustable Shock S6004LM - UPR Products
^^even this one only says its up to 02'
1994-2004 Ford Mustang Strange 10 Way Adjustable Strut S6005LM - UPR Products
So you think it would be easier just to get these 2?
and i could just use these with the K-member?
The springs on the car right now are very low, not sure on the company but they are red and the car is real low
Kenne Bell powered
11.44@121.9
1.59 60 foot
Old November 17th, 2011, 12:27 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
The suspensions are the same from 99-04. so dont worry that it only says till 02. i would definitely go that route over the lakewood route.
Old November 17th, 2011, 02:32 PM   #6
2003 mustang gt
Ok that makes more sense because i can adjust it for the track and normal driving aswell...what spring rate should i get since the front coilovers come with the K-member? and i could use the Strange stuff with it right?
Kenne Bell powered
11.44@121.9
1.59 60 foot
Old November 17th, 2011, 06:39 PM   #7
02gtvortech's Avatar
2002 mustang gt
02gtvortech is on a distinguished road
i have 300 pounds springs with my coilovers and it rides very nice.
324RWHP 323RWHP 8.1 psi. BOOST
Old November 17th, 2011, 08:12 PM   #8
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
just get the 12/250s that come with the kit its their street/strip rate... pm me if you want a price on everything you want from upr.... ad yes the strange's will fit with the coilovers..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Threads Similar to: spring rate for rear coils, and front?
Spring Rate Help Cricket 4V / SVT 9 December 3rd, 2011 09:18 PM
Spring rate? jivepepper 99-04 4 July 10th, 2010 07:25 AM
Spring rate Codeman V6 Mustangs 13 April 19th, 2010 03:55 PM
Good rear shocks if I'm doing kmember/coils in front? SDYC00GT 99-04 16 March 18th, 2009 09:16 PM
Spring Rate?? flamed 98 gt 5.0 Mustangs 4 March 16th, 2008 12:31 PM
