2000 GT Convertible
![]() iTrader: 1 reviews
3v swap
so i have been reading a couple of threads on this i got a basic list of what would be needed for it i just want some advice from anyone that has done this swap and if there's a write up. i have search but haven't found one.
a couple of question will it bolt up to the stock motor mounts and i might upgrade the k-member, and the smog related stuff i live in cali so it has to have all the smog stuff. |
2000 GT Convertible
bump anyone?
From what I have read, you can keep the same k-member as well the mounts from the 2v. Now so smog proposes you should keep the factory (2v) manifolds till you can pass smog. I don't see why you can reuse the old motor's smog crap. One I don't know is if they will check for VCT operation. Your best bet is to call a smog ref and ask him/her.
2000 GT Convertible
yea most of that i got from bits of info i found im mostly looking for the small details to make it much simpler....... and for the smog stuff all i have to do is keep the smog stuff from the new motor not the old one. and i don't think there's a way to check vct
12.73@111.36
There are a couple of guys on this forum that have done the swap. I expected them to respond. With the adapter kit the motor bolts right in. You use your stock exhaust, stock wiring harness and stock ECU. You have to lock out the variable valve timing and use a manually operated Cobra TB. I have heard that Logan Motorsport sells the complete swap kit for $950.
California is a little particular. Any intake or exhaust mod has to have a CARB # in order to pass inspection. You're car only has to meet the emission standards required of a 2000 Mustang GT. Swapping in a newer motor doesn't give you new standards. But I also know that California is cracking down building Hot Rods on old platforms. I'd suggest you start by calling a local inspection station. They may or may not know but they should be able to refer you to someone who does.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
2000 GT Convertible
the inspection is not really a issue i just have to leave the stock smog stuff off the newer motor.
im more worry about the little detail that will take hour trying to figure out the main one im thinking about is where the AIC valve will go? |
12.73@111.36
I don't believe you use the 2v IAC. From what I've read you use the 05-09 intake with a Cobra throttle body.
2000 GT Convertible
ok i thought that i would have to put the IAC on. do you know about the radiator and heater hoses?
Threads Similar to: 3v swap
| Which one is easier??a rear end swap or engine swap? | Bies08 | V6 Mustangs | 42 | May 11th, 2010 04:33 PM |
| pi swap or motor swap | whiteboy05 | 96-98 | 12 | December 8th, 2009 05:30 AM |
| PI Head Swap and Transmission Swap | jEEd | 96-98 | 18 | May 14th, 2009 12:57 AM |
| 1995 351 to swap or not to swap.& how to? | Jeffery9508 | 94-95 | 9 | August 3rd, 2008 08:00 AM |
| Can't decide, engine swap or PI swap? A few questions... | k3vin | 96-98 | 24 | September 5th, 2007 06:48 PM |
