Oil Gauge Problem
Old November 20th, 2011, 10:27 PM   #1
Jaa1456's Avatar
2000 GT
Jaa1456 is on a distinguished road
Question
Oil Gauge Problem
I started up my car today and noticed it took about 30 seconds for the oil gauge to move at all. It normally moves right to the center of the gauge on start up. At first thought it was just a delay and maybe never noticed it before. But then it went back down all the way again, then back to the middle, it did this for about 45 seconds. Then it stayed in the middle, I started driving everything was fine. I stopped at a red light and it went down again, I took off it went up again, then down when I stopped. Then it went to the middle and stayed for the rest of the trip. Do you think the pump is going bad or maybe the sensor?
Old November 20th, 2011, 10:34 PM   #2
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
Mine actually reads oil pres when it feels like it. Checked oil level. Good to go so it doesn't bother me.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old November 20th, 2011, 10:40 PM   #3
04MidnightGT's Avatar
12.9 @ 111.44
04MidnightGT will become famous soon enough04MidnightGT will become famous soon enough
Could be the sender...?
l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow
Old November 20th, 2011, 10:44 PM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Oil level and oil pressure are two entirely different things. I won't drive a car if I think there is an oil pressure problem. I've seen too many people lock up their motors driving with the idiot light on. The worst case secenario is that your oil pump is failing. However, I had a similar problem. In my case it was a $8.95 oil pressure indicator switch. From the way your oil pressure gauge is acting I suspect that's your problem. The switch is located beside the oil filter and is very easy to change.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 20th, 2011, 10:49 PM   #5
Jaa1456's Avatar
2000 GT
8.95 sounds like something worth changing out, not to expensive. Did you get it from Ford or some where like autozone? Also how hard was it to change?
Old November 20th, 2011, 10:50 PM   #6
joswo1980's Avatar
2001 mustang gt
no clue
joswo1980 is on a distinguished road
Diffintly stop driving it and put that oil sender switch in immeditaly just so ur sure, it still does it change ur filter and oil if all fails its ur pump buy u really wanna narrow it down b4 u end up needing a engine, just even a couple of seconds wo oil will destroy it
zex blackout 125 shot,bbk 78mm tb,bbk CAI, flowmaster accel supercoils, diablo tuner. New setup in works VORTECH V2 SQ BOLTED ONTO A MMR 750
Old November 20th, 2011, 10:50 PM   #7
Jaa1456's Avatar
2000 GT
Also the check engine light is not on.
Old November 20th, 2011, 10:51 PM   #8
joswo1980's Avatar
2001 mustang gt
no clue
Autozone cheaper and it just screws out and in just if ur taking off a bolt, reeeeaaalll simple
Old November 20th, 2011, 10:53 PM   #9
Jaa1456's Avatar
2000 GT
oil is due for change next month but only due to age not mileage. There is also no oil leaks and the car doesn't burn oil. I will go for the switch tomorrow.
Old November 20th, 2011, 10:56 PM   #10
35.9@16.99
iTrader: 17 reviews
Changing mine tomorrow. prev owner said gauge has always been like that since he had it 1-2years.
Old November 20th, 2011, 11:01 PM   #11
joswo1980's Avatar
2001 mustang gt
no clue
I was meaning if replacing sending unit dosent fix the problem then change ur oil and filter, filter could be clogged
Old November 20th, 2011, 11:15 PM   #12
Jaa1456's Avatar
2000 GT
I hope its not clogged only a thousand miles on it since last change
Old November 21st, 2011, 06:45 AM   #13
12.73@111.36
I noticed that both of you have 2000 GTs. That is what mine is. If yours is a mid-year build you may have to go back to Autozone. I bought the 2000 GT switch but it wasn't the same as the one that was in it. I went back to Autozone and discovered that Ford made a mid-year change. My car took a 2001 oil pressure switch.
Old November 21st, 2011, 09:24 AM   #14
Jaa1456's Avatar
2000 GT
In that case I will buy both and return the unused one. I have to double check the sticker but I think mine is June.
Old November 21st, 2011, 09:40 AM   #15
35.9@16.99
iTrader: 17 reviews
I have a 2000 body with an unknown motor. How can I find out if mine is a early or mid. Besides valve cover bolts.
Old November 21st, 2011, 10:01 AM   #16
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Look at the sticker in the drivers side door jamb. It will have the build date on it.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old November 21st, 2011, 10:05 AM   #17
joswo1980's Avatar
2001 mustang gt
no clue
Its a unknown motor silly,
Old November 21st, 2011, 10:06 AM   #18
joswo1980's Avatar
2001 mustang gt
no clue
In ur case just take adapter off and bring it with u to match it up
Old November 21st, 2011, 10:08 AM   #19
I like boobs!!!
2000 GT convertible
dunno
Derp
Old November 21st, 2011, 10:13 AM   #20
12.73@111.36
Valve cover bolts won't tell you anything about a 2000. All of them had Windsor motors. It was mid-year 2001 that Ford started putting in the Romeo motors. If the motor has been replaced then you don't even know the year. In that case I take the old one out, plug the hole with a rag so that oil doesn't drain everywhere, and drive a different car to Autozone to match it.
Threads Similar to: Oil Gauge Problem
Glow Gauge Problem BluePony98 General Tech 0 April 18th, 2011 08:34 PM
Gauge problem??? roush4life 99-04 0 April 9th, 2011 11:02 PM
Temp gauge problem brimmer555 5.0 Mustangs 27 January 7th, 2011 04:26 PM
FUEL GAUGE PROBLEM SUPERCOUPE 2005 - 2010 4 November 8th, 2007 01:42 PM
Gauge Cal Problem marcfiebka 99-04 2 July 3rd, 2007 07:40 PM
