how to make heater warmer?
Old November 21st, 2011, 01:06 PM   #1
brendon557's Avatar
2003 Mustang GT
brendon557 is on a distinguished road
Any body know how to make my heater warmer? Mine is warm now but its cold up here in Alaska and I know it could be a lot better.
Any ideas?
2003 Mustang GT
My baby. Slowly working her up. Slowly because I am on a college budget
Old November 21st, 2011, 01:09 PM   #2
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
what t-stat are you running?
Mods in garage
Old November 21st, 2011, 01:14 PM   #3
Priest of the Car Gods
ReverendDexter's Avatar
Clapped-out '90 GT 'vert
~5.5 seconds off TTOD :(
+1 to the thermostat. A higher temp t-stat will have hotter coolant circulating in the system, which means more heat getting in your cabin.
Also, a coolant system flush will get any crud out of the heater core, which should help heat transfer, as would adding a surfactant like Redline's Water Wetter or Royal Purple's Purple Ice.
O o
/¯/______________________
\_\
Old November 21st, 2011, 01:24 PM   #4
brendon557's Avatar
2003 Mustang GT
right now its stock thermostat. Any recommendations on a aftermarket one?
2003 Mustang GT
Old November 21st, 2011, 01:25 PM   #5
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
First off, what is your operating temperature? Does your engine even truly warm up?
In lieu of a thermostat, you can create your own "winter fronts." Many HD trucks run these in cold climates to retain both engine heat as well as cabin heaters. All they do is effectively reduce the amount of area on the radiator that is exposed to airflow. You can get real fancy ones, but some guys even just duct-tape cardboard to their grille.
Just don't go overboard and keep an eye on the temperature. If you cut off too much air it could overheat. You can add a little on, try it, add a little more, and repeat as desired. Plus if it's just cardboard if it gets too warm you can rip it off.
Here's an example used on a Dodge Ram in a cold climate- This is an aftermarket piece that can be foleded and buttoned in different positions to adjust airflow.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old November 21st, 2011, 01:46 PM   #6
02 gt
Bham gt is on a distinguished road
Check your coolant level if you are low the air wil not be as warm as it should be
Old November 21st, 2011, 01:52 PM   #7
jeep45238's Avatar
2003 Mustang GT
jeep45238 is on a distinguished road
Replace your thermostat. If it fails in the open position, it'll always circulate coolant through the radiator, and it will take forever to warm up, if it ever gets there.
A new thermostat won't let that happen until the coolant reaches the temp the thermostat is rated for. I just bought one yesterday for the mustang, I think it's a 195*F unit.
Old November 21st, 2011, 02:03 PM   #8
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
+1 new thermostat, check coolant and block off radiator.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Old November 21st, 2011, 03:47 PM   #9
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Move south. Your heater will kick ass year round in south Georgia or any part of Florida.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Threads Similar to: how to make heater warmer?
Bottle warmer help! Nicos2001GT 99-04 2 November 27th, 2010 12:21 AM
noticed engine getting warmer ddarkslayer 5.0 Mustangs 11 August 15th, 2010 03:47 PM
Bottle Warmer??? 95blackbeauty General Tech 8 October 3rd, 2007 02:09 AM
Will a NX bottle warmer work with a NW kit? Aliate X General Tech 2 October 22nd, 2005 12:16 AM
