Random noise/SCT question
Old November 21st, 2011, 09:14 PM   #1
Criscone's Avatar
Criscone is on a distinguished road
Send a message via AIM to Criscone
So ive got 2 noises i can not diagnose for the life of me. Car runs awesome with no issues, these just bother me. 04 GT 5spd
1. When turning (more so to the right) i get a whineing in the rear. Very slight, but enough to annoy me. Only hear it in parking lots (slow speeds). it sounds like a powersteering whine but from rear. Idk if this matters also, but when getting onto a hard on-ramp going left its smooth, going right it seems rough. If that makes any sense..
2. What i think is an exhaust leak, however it only does it when engine is underload. I can rev it all day with no noise. Say im doing 40mph and in 5th gear and punch it, i hear the noise. It sounds like a diesel mac truck downshifting. Also makes the noise full throttle in anygear past 3k-ish.
..Thats all, ive fixed every other little thing that bothers me except these 2 things. Cant figure them out at all.
SCT X3 Question
Im running the race tune and love it. However when switching to the race tune from performacne, i hit advanced options to see what was in there(the one they say to skip), now it asks everytime for it. Does this mess up the tune? I wanted to see how to delete the rear o2's since im removing my cats, and how to put in the 2step option. Didnt find either. Also dont know how to use the datalog option either. I cant believe this didnt come with some type of manual..
Old November 22nd, 2011, 10:11 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
1. Sounds like a wheel bearing.
2. Could be an exhaust leak, but that description sounds more like detonation.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 22nd, 2011, 10:31 AM   #3
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
I'm sure you're running 93 octane fuel, right? It sounds like detonation (spark knock) to me You can mess with the timing in the options - knock it back -4 from what it is set at and see what happens, and also check/replace your spark plugs.
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old November 22nd, 2011, 03:40 PM   #4
Criscone's Avatar
yes always 93, in everything i own regardless. im going to put it back to stock and see if its still there. If so, should i just send bama/AM an email for a new tune? How can i see exactly what they did/used for a tune anyhow?
Old November 22nd, 2011, 03:56 PM   #5
Tang Stang's Avatar
Without the actual tune file and your own copy of Advantage (part of the PRP), you can't see exactly what they did in the tune. What plugs/tstat are you running? Try either returning to the stock tune or dialing back the advance a bit and see if it goes away.
Old November 22nd, 2011, 04:52 PM   #6
Criscone's Avatar
Went to stock tune and still does it, and I THINK not as loud tho. It's most aggressive/loud if I'm doing 20-25mph put it in 5th and punch it. Sounds like a diesel truck.
Tstat an plugs stock, never touched them since I've owned it.
How can I adjust timing just to see? And will it screw up my tune? When I go in advanced options before it loads tune, all the presets in there are checked at "0" degrees.
I'm going to put stock tune back in now again and try it at 20-25 like I just did with race tune.
Old November 22nd, 2011, 04:58 PM   #7
Tang Stang's Avatar
Why are you trying to go WOT in 5th at 20-25 MPH in the first place?
Was the tune written with the assumption that you would have swapped to a 180 degree tstat and one heat range colder plugs? Most canned "performance" tunes are.
You can back off the timing in the "advanced options" that you're seeing before loading the tune. You should be able to either take out the timing in seperate rpm ranges or globally. Just back it off two degrees and see if it improves.
Old November 22nd, 2011, 05:52 PM   #8
Criscone's Avatar
I hear the noise when normally driving, I tried seeing when it's the worst. Was for testing purposes only. So it makes the noise on race tune, swapped back to stock and it makes it very slightly/if at all. So it's definitely the tune.
Never told them I had different plugs or tstat.
Soo I can just go into global spark and check -4 and that takes 4 degree timing OFF whatever they set it at?
Old November 22nd, 2011, 06:00 PM   #9
Tang Stang's Avatar
You might ask them what their assumptions are for their "race" tune.
Yes, -4 in global spark will retard ignition timing by 4 degrees across the board.
Old November 22nd, 2011, 07:59 PM   #10
Criscone's Avatar
Did the -4, still has it just not as bad as it was. Can I go more?
Old November 22nd, 2011, 09:10 PM   #11
Criscone's Avatar
Talked to American muscle, told me To change my fuel filter and swapping to auto lite copper plugs. So im doing that tmrw, if it doesn't work I call them back, datalog car and send them back results for a fresh tune
Threads Similar to: Random noise/SCT question
random squeeling noise 4.6DreameR 99-04 5 November 12th, 2011 07:49 PM
Random knocking noise, What could it be??? Roadrashjr 99-04 5 February 17th, 2011 09:05 PM
Random Question Rob2002GT 99-04 52 February 25th, 2010 10:38 PM
Random question... OhhShorty 99-04 19 August 15th, 2007 02:13 PM
Weird Noise at random .....Help Brianzeke007 V6 Mustangs 7 January 11th, 2007 12:11 PM
