Performance Thoughts on the J mod
LinkBack (1) Thread Tools
Old November 22nd, 2011, 09:12 AM   1 links from elsewhere to this Post. Click to view. #1
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
I am thinking about doing the J Mod to my Auto 4R70W I have read that it opens up flow on the valve body causing less wear and tear on the clutches, and allows the stock tranny to hold more power. Has anyone done it and been able to tell a difference before and after? Advise me on your experience with this modification.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old November 22nd, 2011, 09:42 AM   #2
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
It sounds like you're just referring to the valvebody portion of the J-Mod. Depending on the "level" you choose, the TC you're running, and the actual level of power you're putting through the transmission, the before/after difference will range from slightly to extremely noticeable.
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 22nd, 2011, 09:58 AM   #3
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
I have not done it, but I have been happy turning up the pressure via SCT handheld, and at stock power levels I should have no problems.
I have also heard that the 4R70W already has a lot of the J-mod type enhancements to it already vs. the old AOD transmissions.
Have you seen this site before? Jerry's original articles are in here somewhere:
TCCoA | TCCoA
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old November 22nd, 2011, 10:35 AM   #4
Tang Stang's Avatar
TCCOA has the main articles, but you'll want to read this addendum for the later model 4R70W's: http://www.crownvic.net/tech/4R70Wnotes.pdf
Old November 22nd, 2011, 11:07 AM   #5
SSG Pate's Avatar
I think Ill do this and see how it goes.. Cant hurt anything I suppose, But i really like the way the Stock transmission shifts I dont want it to be firm and jerky.
Old November 22nd, 2011, 11:21 AM   #6
Tang Stang's Avatar
What TC and gears are you running, and how much power/tq are you putting through the transmission?
Old November 22nd, 2011, 11:38 AM   #7
SSG Pate's Avatar
I have 410 Gears Stock Converter.. as far as power I have no ideal until we dyno. high 400rwhp Range perhaps
Old November 22nd, 2011, 11:48 AM   #8
Tang Stang's Avatar
Well, definitely read the entire article (TCCoA Tech Articles), but the comments Jerry made in the link I posted earlier will apply to your transmission. Basically, holes #2, 4, 5, 9, & 11 need to be opened up to ~ .100", and you need to remove the bottom 1-2 and 2-3 accumulator springs. Keeping the holes at .100" will keep the shifts relatively mild, though I would open those holes up to ~ .110" if you're planning on swapping in a higher stalled TC anytime soon, as higher stalled TC's tend to absorb some of the part throttle shift firmness.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/240161-performance-thoughts-j-mod.html
J-Mod - online conversations | BoardReader This thread Refback December 29th, 2011 11:03 PM
Threads Similar to: Performance Thoughts on the J mod
Thoughts on this 06 GT please JCCNY 2005 - 2010 15 January 1st, 2011 10:07 PM
CAI from AM...Thoughts. freefallin2000 99-04 58 April 23rd, 2010 12:29 AM
Thoughts? 07GT-CS 2005 - 2010 45 March 27th, 2008 05:36 PM
staight line performance or track performance??? andoutcomethewolves V6 Mustangs 12 February 19th, 2007 11:34 AM
