Reinforce pinch welds?
Old November 22nd, 2011, 10:01 AM   #1
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
Question:
I have subframe connectors but my jack doesn't fit underneath them since the car is lowered and my jack sucks. Its also a lot easier to toss the jack under the pinch welds but they are getting bent more an more every time I use them.
Would it harm the car at all to weld in some right angle steel along the bottom floor pan and the inside of the pinch weld to add some strength to it? (provided I didn't blow through the floor or start anything on fire, of course)
I don't have pictures, but this is the style of metal I'd be using, and I would probably run as long a piece as possible along the pinch weld to disperse any weight. I suppose it could make the car marginally stiffer as well, but the subframes already do that. Thoughts?
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old November 22nd, 2011, 10:31 AM   #2
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Even reinforcing it with angle iron won't be enough in my opinion. You'd still be absorbing most of the force into the floor pan. My suggestion would be outriggers welded between the subframes and the rocker as a jacking point.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old November 22nd, 2011, 10:37 AM   #3
Tang Stang's Avatar
Tang Stang is just really niceTang Stang is just really niceTang Stang is just really niceTang Stang is just really nice
Or just drive up onto some 2x10's before jacking up the car...
Rod @ AzzKicker Cars
2004 Ford Mustang GT-The Driver-BBK CAI, PP TB & Inlet, Steeda UD's, SLP LM1, & 3.73's.
1990 Mercury Cougar XR7-The Meth Addict-5.0L DOHC Stroker w/2.1L KB SC.
1995 Ford F150-Mud Toy-5.0L, 4x4, 33's, & Warn 8274 Winch
Old November 22nd, 2011, 10:46 AM   #4
Do you have any pictures of what this would look like? Is this similar to the beefed up subframe connectors I've seen? I'm also not that confident in my welding abilities to add a new jacking point which is why I want to reinforce whats already there. Are you thinking if I reinforced them it would put more stress of the floor pan and bend that instead?
I'm going to have to do that. The only problem with that is if I have a flat and have to change it on the side of the road
Thanks guys!
Old November 22nd, 2011, 10:55 AM   #5
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
+1, this is what i have to do to get my car on lifts
Old November 22nd, 2011, 11:05 AM   #6
bulloch27's Avatar
N/T @ Fast
If you're not that confident in your welding ailities you're not going to be able to effectively reinforce the pinch welds either. The pinch weld is nothing more than the side of the floorboard of the car spot welded to the rocker. If you look back through my posts I just posted this weekend pics of my through floor subframe connectors. In those pics you will find pictures of the outriggers that tie the frame rails into the rockers as I'm suggesting. Do you really jack your car up that often to even consider this as an option? Ever considered ramps? My car is low too, I back the rear tires onto ramps with no issues though.
Old November 22nd, 2011, 02:16 PM   #7
Kyle's Avatar
03 DSG GT
12.82@111.23mph
Kyle is on a distinguished road
Carrying around 2 - 2x10 pieces that are 6 inches long wont add much weight to the trunk if your worried about a flat
2003 DSG GT AUTOMATIC - 12.82 1/4 @ 111.23 mph
Threads Similar to: Reinforce pinch welds?
How to reinforce front strut towers (does 56k still exist?) 01KnightRiderGT 99-04 25 December 14th, 2010 09:33 PM
welds Troy5.0 5.0 Mustangs 5 August 6th, 2010 01:11 AM
looking for a set of welds mjkids 5.0 Mustangs 0 March 6th, 2010 08:17 PM
How are Greg Welds? AggieStang 99-04 4 August 11th, 2009 10:51 AM
Feelin the Pinch oldernewbie The Clubhouse 10 January 19th, 2008 10:16 AM
