Cutting stock springs tools
Old November 22nd, 2011, 02:22 PM   #1
1999 Mustang GT
281huntergreen is on a distinguished road
Not to bother again guys, but i have another question to ask what are all the tools i would need to cut my stock springs until i get some H&R springs in January. I would like to cut one coil since i have read that's it should provide the same drop as the H&r springs.
Old November 22nd, 2011, 02:25 PM   #2
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
as in what tool to cutt them with?
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old November 22nd, 2011, 03:06 PM   #3
1999 Mustang GT
from taking the lug nuts off to the control arms and to cutting the springs.
Old November 22nd, 2011, 04:22 PM   #4
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
this isnt too bad to do. the fronts are the hardest to get out/back in IMO. you will need a floor jack, 2 jack stands, a good set of metric wrenches/sockets and a grinder with a cut-off wheel.
i use this method when doing springs. makes things go pretty quick and it really isnt that much work.
Mustangworld Progressive Rate Springs Install
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old November 22nd, 2011, 04:47 PM   #5
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
Harbor Freight 4 1/2" angle grinder/cut off wheel. $20, works like a charm.
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old November 22nd, 2011, 04:49 PM   #6
Traction...?
1996 GT's Avatar
1996 GT/ 2008 GT Vert
1996 GT has a spectacular aura about1996 GT has a spectacular aura about
Best way to remove the front springs it putting a jack underneath the LCA and after unbolting everything, SLOWLY lower the jack and the spring will fall out. Make sure you stand to the side incase something slips. Thats how i removed my old ones.
Old November 22nd, 2011, 04:54 PM   #7
Kyle's Avatar
03 DSG GT
12.82@111.23mph
Kyle is on a distinguished road
WRONG.........
Easiest way to do fronts is get the car up in the air.. put the jack under the LCA.. unbolt the front sway bar, unbolt steering rack, unbolt LCA and drop the back of the LCA...
doing it this way requires only taking off 8 bolts.. brakes dont come off, caliper doesnt come off.. etc
Put my Eibach Pro's in this saturday and the front took 45 minutes for both sides
2003 DSG GT AUTOMATIC - 12.82 1/4 @ 111.23 mph
Old November 22nd, 2011, 04:59 PM   #8
1999 Mustang GT
Thank you so much guys. Reps all around. Would i need a spring compressor? and do i have to remove the brakes and rotors?
Old November 22nd, 2011, 05:05 PM   #9
Traction...?
1996 GT's Avatar
Originally Posted by Kyle View Post
WRONG.........
Did you even read a word i wrote? Its pretty common sense i ment that its up in the air, what do you think would happen if you pulled a wheel off without a stand under it?
EDIT: 281, yes, you will need a coil spring compressor and yes you will need to take off your rotors and calipers.
Old November 22nd, 2011, 05:32 PM   #10
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
iTrader: 10 reviews
you dont really need a spring compressor IMO. when i unbolted my front struts from the strut tower and slowly left the jack down from under the lower A-arm, the springs will nearly fall out. once you cut a coil out, they will pretty much go right back in effortlessly. the fronts deff. have to have the calipers removed. its really easy, 2 bolts per side is all. and what ever you do, DO NOT forget the ABS sensor wire. when the suspension in the front is at full drop (struts unbolted) it will tear out if you dont un-do the wire from its mount. it also helps to unbolt the sway bar ends. you will gain a little more down travel, making it easier to get the springs out.
the rear is just as easy. when you take out the lower shock bolts and drop the rear end down, i find it easy to grab the old springs and twist them...kind of like a bolt...just take a look at how the coils are spaced and you will see what i mean.
they will come right out. again, when you cut your stockers, they are super easy to get back in. the H&R springs will go in really easy...i have those on my car as well and they basically fall right in with the suspension at full drop.
BSD 100MPH Club
YMR #8975
MM Nitrous Club #7
MM Cobra Club #87
Old November 22nd, 2011, 05:35 PM   #11
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
LMR sell a tool to hold the spring in the control arm.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Old November 22nd, 2011, 06:51 PM   #12
1999 Mustang GT
Thanks do i have to take off the sway bar also?
Old November 22nd, 2011, 06:55 PM   #13
1999 Mustang GT
And guys how do i take off 1 coil? do i just cut from the end of the coil on the top to the other?
Old November 22nd, 2011, 07:51 PM   #14
bullitt02875's Avatar
2001 Bullitt
bullitt02875 is on a distinguished road
ok you guys are doing it the hardest ways possible. disconnect your swaybar links and remove your abs cable from all the mmounts, cant remember if you have to take it off at caliper. put a jack under the balljoint, remove your two strut bolts (at spindle) and just lower the jack. done. reverse to put back in
01 DHG Bullitt
Stroked, Forged & Blown
Built Rear, Viper T56, Suspension, Drag Radials
374.6 rwhp 374.4rwtq @ 4.6L 10psi
Now 5.1 and 15psi, no idea on the numbers!!
Old November 22nd, 2011, 08:05 PM   #15
1999 Mustang GT
So then i don't have to remove the calipers now? what tools would i need to do it this way the less the better.
Old November 22nd, 2011, 09:05 PM   #16
2001 Bullitt
Need a wrench or two for you sway bar links, an I thi k it's like a 21mm socket for the strut bolts. And even if you ha e to pull the caliper, it's two bolts and it slides off takes all of an extra 2 minutes. Just take those apart and you should be able to just lower the jack and push the control arm down by hand. Can also just pop the ballpoint instead of disconnecting the strut, and no not with a pickle fork haha
01 DHG Bullitt
Old November 22nd, 2011, 09:45 PM   #17
Traction...?
1996 GT's Avatar
Yeah i also think it was a 21mm.
Threads Similar to: Cutting stock springs tools
cutting stock springs, how much? Willy Mo 99-04 32 April 3rd, 2011 11:05 AM
Cutting Stock Springs: Let's see them and hear about them! NoColoradoGT 99-04 18 November 26th, 2010 04:10 PM
Cutting stock springs? fordx316 99-04 4 October 16th, 2010 10:15 PM
cutting the stock springs??? 93HatchsBFF 96-98 10 July 15th, 2010 02:52 PM
Cutting Your Stock Springs? dpstang98gt 96-98 6 November 18th, 2007 10:54 PM
