Best way to pass through the firewall?
Old November 22nd, 2011, 05:58 PM   #1
03fastgt is on a distinguished road
I need to run quite a bit of wiring through the firewall, and im going to buy a little 4 screw (.5-1inch diameter) grommet. I'm just wondering if theres a place either in the passenger side foot panel or drivers side that is fairly easy to drill/run wiring through.
Just looking for a clean install. (2003 Mustang GT)
Pictures would be great.
Thanks
Old November 22nd, 2011, 07:34 PM   #2
MarkF is on a distinguished road
I used the hole that the hood latch cable passes through (driver's side), I ran a 12gauge and 4 18gauge wires through the hole and used the existing grommet. It was a bit hard to catch it on the engine side since it comes out behind some other sheetmetal, but I was able to squeeze my hand in a hole and grab it, once I had one through I used it to pull the others.
Old November 22nd, 2011, 07:36 PM   #3
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Thanks
There sure is look on the Drivers side firewall there is a good size hole there to the left and below the brake boost I just cut the large grommet, then matched one up from LOWES and ran all my wiring and Boot gauge line through it.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old November 22nd, 2011, 07:39 PM   #4
Matt.'s Avatar
2002 Nitrous Injected V6
12's?
Matt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the roughMatt. is a jewel in the rough
On the drivers side there is a grommet that you can run a bunch of wire through, atm there is like 8 16 gauge wires ( all my nitrous wiring)and a big audio wire going through it. Its like a foot or two down from the top of the firewall around the steering wheel
Project Red Magic
-Full Intake, Full Exhuast,Geared, Tune, Sprayed, Dropped-
-18 Inch Hypercoated Saleens wrapped in Nittos-
Old November 22nd, 2011, 07:43 PM   #5
SSG Pate's Avatar
ImageShack® - Online Photo and Video Hosting
Old November 22nd, 2011, 07:46 PM   #6
SSG Pate's Avatar
Ok from image shack someone please explain to me how the FUC- to get the picture to post
Old November 22nd, 2011, 07:48 PM   #7
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
southfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of lightsouthfour! is a glorious beacon of light
Send a message via AIM to southfour! Send a message via MSN to southfour!
H/C/I V6
BMC Member: 12521
Old November 22nd, 2011, 07:50 PM   #8
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
right click on image, then click copy image location then insert the [img/] tags
H/C/I V6
BMC Member: 12521
Old November 22nd, 2011, 07:52 PM   #9
SSG Pate's Avatar
Thanks for posting that, but how did you do that? anyhow next to the brake booster you can see all my lines coming out, these feed into the drivers side where you can see them and route your wires this was before I build my engine, but the hole is still the same.
Old November 22nd, 2011, 07:53 PM   #10
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
see my post above yours
H/C/I V6
BMC Member: 12521
Old November 22nd, 2011, 07:58 PM   #11
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
^ the hole you used will only be there on auto cars, as that's where the clutch cable comes thru on manual cars.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old November 22nd, 2011, 07:59 PM   #12
SSG Pate's Avatar
Can you still not use that same hole and share it with the clutch cable?
Old November 22nd, 2011, 08:02 PM   #13
Not Banned
southfour!'s Avatar
2000 Mustang V6
2000 Silverado 1500
not its completely filled with either the stock firewall thing or an aftermarket adjuster.
H/C/I V6
BMC Member: 12521
Old November 22nd, 2011, 08:45 PM   #14
ytngt has a spectacular aura aboutytngt has a spectacular aura about
I drilled a hole right under and between the clutch cable and throttle cable hole.
Old November 23rd, 2011, 12:11 AM   #15
Cool I'll check that out when it warms up, thanks!
Old November 23rd, 2011, 12:13 AM   #16
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
i ran mine through the fat rubber grommet with a harness coming through...near the clutch cable hole...
cams + 150 shot
Threads Similar to: Best way to pass through the firewall?
Best Pass Time pass 69fastback 5.0 Mustangs 33 March 3rd, 2011 08:47 AM
firewall Q's Dratomic 5.0 Mustangs 24 March 31st, 2009 10:03 AM
firewall tom2000r 99-04 4 January 27th, 2008 09:34 PM
firewall EasyE64 Audio/Video 5 October 4th, 2007 01:21 PM
firewall tag Iownastang 5.0 Mustangs 9 September 12th, 2007 08:50 AM
