Help - Longer clutch cable for TKO swap?
I have an '03 GT and I replaced the stock tranny with a TKO 500. I also replaced the clutch and flywheel at the same time and had a firewall adjuster and aftermarket clutch quadrant installed. The connection for the clutch cable sits a little farther back on the TKO and it seems like there is a always a little tension on the clutch cable. I get some noise from the tranny sometimes and difficulty shifting into gear. I have the adjuster all the way out. If I adjust it in, it won't hardly shift at all. It seems like it just needs a little more slack and it would be fine. My question is, does anyone know of a longer clutch cable that will work, or a place that will make a longer cable to fit mustangs? Any information or help would be greatly appreciated.
2003 Dark Shadow Gray GT, K&N air intake, 75mm Trick Flow Throttle Body and upper plenum, Comp Stage II cams, SLP long tubes, SLP hi-flow x-pipe, Loudmouth II catback, FRPP 4.10s, TKO 500 tranny, RAM Powergrip clutch, subframes, lowering springs... |
I thought that when you adjust the firewall adjuster "in" it provides more "slack" at the shift fork? If so then getting a longer clutch cable would basically server the same purpose, so it sounds like your problem is elsewhere.
Some tension on the clutch cable is normal as long as it is not excessive. If you don't have an adjustable clutch cable, get one. It gives you about two inches of adjustment at the clutch fork.
Thanks man. I still have the stock cable right now, so I will get an adjustable cable and hopefully that will solve the problem. Thanks again.
Threads Similar to: Help - Longer clutch cable for TKO swap?
| New clutch cable and quadrant still short on clutch | sharpshooter33 | 99-04 | 1 | November 4th, 2011 09:28 AM |
| Clutch and clutch cable problems | greystang92 | V6 Mustangs | 2 | July 22nd, 2011 07:54 PM |
| Clutch Or Clutch Cable OR Shifter??? | 96GtGoodz | 96-98 | 21 | July 27th, 2009 02:59 AM |
| CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS | Hububula | 5.0 Mustangs | 3 | May 28th, 2007 10:08 AM |
| Getting My Clutch Quadrant, Adjustable Clutch Cable and | 97Cobra | 4V / SVT | 3 | May 2nd, 2007 02:33 PM |
