Climate control issues any ideas
Old November 22nd, 2011, 09:04 PM   #1
04 stanger 4.6 40thAnn
objects in mirror are ricers
wheresthedoor423 is on a distinguished road
Well all of a sudden my climate control will only blow max hot air no matter what temp setting I put it on. Pulled off the climate control knobs unit to check the air blend cables but they work fine. I know there's a valve in the dash that has something to do with the cabin temp but don't know what it's called. Anyone had this issue? A/c works just fine so it's not that. Lucky winters coming up so it's not a big issue right now till spring.
Old November 23rd, 2011, 09:49 AM   #2
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Sounds like the blend door is stuck inside the box. I don't know if the Mustang's blend doors are actuated by vacuum, cable or servo. If it's cable or vacuum those need to be checked inside the box and outside. If it's servo you'll have to pull the box to check but I doubt it's servo actuated. Sounds like the blend door is either stuck mechanically or the actuator is stuck.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old November 23rd, 2011, 09:57 AM   #3
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
Yep, pull the radio deck and a/c out, in the back of the dash you'll see a grey piece connected to the a/c via a black cable... when you turn the a/c knob you should see it move back and forth
Threads Similar to: Climate control issues any ideas
Hot Climate Control Thunderscrash 99-04 1 April 4th, 2011 08:34 PM
Climate fan control issue D3fault 2005 - 2010 V6 2 April 9th, 2010 01:59 PM
climate fan control problem D3fault V6 Mustangs 4 April 7th, 2010 07:41 PM
Climate control system!!! HELP!! BOOSTED96 99-04 2 December 10th, 2009 06:04 PM
climate control module WildWill 94-95 1 September 25th, 2008 11:44 PM
