Dare I say... VICTORY!!
Old November 23rd, 2011, 09:48 AM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
Woohoo... procharger issues resolved!!
Had to cut the spacer with a dremel to make everything line up right, but I'm just glad the belt is no longer rubbing!
Old November 23rd, 2011, 10:55 AM   #2
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
Was it the offset spacer that fixed your problem? Also make sure the pulleys are lined up. I was shredding belts when mine were misaligned.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old November 23rd, 2011, 11:09 AM   #3
Yea, so the offset spacer was the issue, we were just running it straight out the alternator hole with a spacer on it.
Once we put the offset spacer on, then the previous spacer was too long and made the main bracket stick out off the motor, so we had to grind it down, which brought it back in, and got the pulleys all lined up.
Old November 23rd, 2011, 01:34 PM   #4
2001 Mustang GT Vert.
cbjohnson9 will become famous soon enoughcbjohnson9 will become famous soon enough
yea, I think procharger could've done a better job with their design for that part of the install. I'm really glad I switched to a 3 bolt setup where the idler pulley/procharger mounting location is the actual alternator hole. It also did away with the allen head screws
Mods in garage
Threads Similar to: Dare I say... VICTORY!!
Do I dare ask on this forum? TinyWeyant 99-04 44 September 16th, 2011 01:31 AM
Don't you dare wish me luck dude496 The Clubhouse 24 February 25th, 2010 10:24 AM
Dare I take The Plunge? Averlus 2005 - 2010 39 October 29th, 2009 10:42 AM
Dare 2 be different~phase 1 timberwolf 2005 - 2010 31 November 2nd, 2008 08:45 PM
