12.9@113
clutch grabbing 3rd
When shifting from high rpm into third, it takes a pause when grabbing 3rd gear. Could this possibly be an adjustment issue? I'm going to put a tad bit more slack in the pedal because there is almost none right now and see how that goes.
Could it also be the POS ram HDX clutch though? Thinking about going to a McLeod...
Blown
390rwhp, 389ft-lbs at 11.9psi (See garage) ![]() |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
more likely it is axle binde or you have issues with fuel pressure from the returnless fuel system. try doing a wot shift and see if it hits hard.
![]() bone stock from the factory! |
12.9@113
If it was in the fuel system wouldn't it do it in 1st to 2nd also?
Blown
12.9@113
It only does it from 2nd to 3rd at WOT is what I meant to say...
Blown
2003 Mustang Fauxbra
N/T @ Fast
Are you saying that there is a mechanical pause blocking your from shifting or an engine hesitation on the shift? I understand you to be having a mechanical block. If i'm understanding the problem correctly it sounds as if you're not getting complete disengagement of the clutch during the shift. Either your shift/clutch timing is off or your not depressing the clutch pedal far enough to disengage. If your engage/disengage point on the pedal is near the top of it's travel your on a good start. When I go to the track I move my seat forward about two inches to guarantee I completely disengage and don't have a problem getting it into gear. Try moving your seat forward and see how it goes. Moving the pedal disengagement point lower will only magnify the problem.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
#6 | |
12.9@113
It's definitely not an engine hesitation. Maybe I just need to play with it a little more. Still getting used to this blower.
Blown
#7 | |
12.9@113
Also sick of this adjustable cable. Need to go to ford and get an OEM cable.
Blown
N/T @ Fast
If you have the clutch adjusted so tightly that it's allowing the clutch to slip you absolutely need to loosen it up. The way I adjust them is to add tension to the cable and/or firewall adjuster until the TOB barely touches the fingers on the pressure plate, then add about another half turn on the firewall adjuster.
If your's was so tight that it was slipping it doesn't sound like the adjustment is the issue, although it could be that you just aren't depressing the pedal far enough and at the exact time to allow engagement of third gear. I can tell you that I have trouble getting into third every time I don't slide my seat forward 2".
#9 | |
12.9@113
Blown
12.9@113
Well adjusted the clutch. And moved my seat up. Lol clutch felt smoother and moving the seat up was surprising a little more comfortable. Idk which one made a difference. I just never had this issue until now lol
Blown
N/T @ Fast
Yep. I'll frig the 2-3 shift up every time if I try to powershift with the seat back.
2002 mustang gt
I had a very similar problem with my car just before I lost syncros for 3rd gear. Clutch was fine and no matter the adjustment did the same thing. I bought an adjustable clutch cable, firewall adjuster and mm clutch quad trying to fix it and it did nothing for it. I hope your issue is different but after a while she started grinding 3rd and I dropped the tranny and had it rebuilt. I also took the opportunity to ditch the stock clutch and install a center force df clutch. Good luck!!!
3.90 gears, k&n intake, pypes catless midpipe and violator catback, ford racing springs, steeda triaxe short throw, back seat delete, sct tuner/ bama tune, centerforce df clutch, and other things aswell
#13 | |
12.9@113
Blown
Black 2003 Gt 5spd
2hrs@46mph
![]() iTrader: 1 reviews
sounds like a bent clutch fork. had the same issue.
Threads Similar to: clutch grabbing 3rd
| new Clutch Ram 88951 vs Advance auto parts Perfection clutch | Paulnhbtx | 99-04 | 11 | October 3rd, 2011 01:53 AM |
| clutch pedal vibration and excessive clutch chatter | mscribellito | 99-04 | 13 | August 19th, 2010 04:59 PM |
| clutch replacement- replace whole clutch assembly or just clutch disc? | WilltheThrill | 4V / SVT | 12 | December 13th, 2008 12:18 AM |
| front brakes are grabbing | Swatstallion00 | 99-04 | 3 | October 18th, 2008 10:47 PM |
| Clutch swap... grabbing high on the pedal | demonicus | 5.0 Mustangs | 13 | July 7th, 2008 01:44 PM |
