1999 Mustang GT
Need help cutting rear springs
hey guys. Happy thanksgiving. Yesterday i cut 1.25 off my front springs it took me about 4 hours since it was my first time ever doing them. Well today i wanted to cut my rears maybe a coil or a little bit more but im lost i don't know where to go or what tools i need to do to take it off. So can anybody help me out please?
Priest of the Car Gods
You already cut the fronts, so I'm assuming you're not talking about what tools you need to actually cut the spring.
Are you asking about how to remove the rears? Because that's crazy-easy... WAY easier than the fronts. Just jack the rear up by the pumpkin, unbolt the lower shock mounts, support the body with jackstands, and let the rear end down as far as it will go. You may be able to get the springs out without doing anything beyond that, but if you have to, support the axle-side of the LCA with the jack, unbolt the axle-side mount, then slowly let the jack down. Insofar as cutting the rears, take it off the top. You need to keep the shape of the pig-tail on the bottom, and when you reinstall the springs, make sure the pigtails point to the passenger side.
#3 | |
1999 Mustang GT
I'm pretty sure it's all 15 and 18mm.
2002 mustang gt
![]() iTrader: 1 reviews
All you need is a 15 and 18 its super easy
Rock stock
04 mustang gt
7.21 @ 98
i disconnect the quad shock and regular shock to let the rear end droop and the spring will come out no problem...may need a little prying if necessary
![]() cams + 150 shot |
1999 Mustang GT
And what can i use to take off the harden bolts. I used wd40, nd pentrating oil nd it still wont come out
i've never seen anyone say the fronts easier then the rear....i guess there is a first time for everything....rev hit the nail on the head
1999 Mustang GT
Threads Similar to: Need help cutting rear springs
| Cutting rear springs | WhiteVenom | 99-04 | 2 | January 12th, 2011 03:27 PM |
| cutting springs in FL... | delgadog | 96-98 | 21 | January 3rd, 2011 11:53 AM |
| Cutting rear springs | njstang | 99-04 | 91 | April 8th, 2009 05:01 PM |
| Cutting rear springs? | tribaltek | 2005 - 2010 | 5 | June 12th, 2008 09:20 PM |
| cutting rear springs | tom2000r | 99-04 | 2 | March 31st, 2008 09:54 AM |
