1998 Mustang GT
Rear Cobra Brakes
Im going to upgrade my rear brakes to cobra brakes, and what all parts do I need to complete the swap? I Know I'll need the mounting brackets, but where could I find them cheap?
98 Mustang GT Mods:Flowmaster 40's Pypes O\R X-pipe Ram Clutch BBk CAI Pro 5.0 Shifter. mm c\c plates, 3.73s, cobra brakes with stainless lines, hawk blue pads and bfg r1 race tires. (for track) Ford racing race springs. Black DD FR500s
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
cobra rear brakes are a waste of money, you can use your gt brackets just fine. the only diff between cobra rear brake calipers and gt calipers is the cobra calipers are wider to fit the thicker rotor.
![]() bone stock from the factory! |
2001 Bullitt
quote: the only diff between cobra rear brake calipers and gt calipers is the cobra calipers are wider to fit the thicker rotor.
wrong. the calipers are exactly the same, only difference is the mounting braket and rotors and PADS. it uses a thinner pad compared to a gt/ v6
01 DHG Bullitt Stroked, Forged & Blown Built Rear, Viper T56, Suspension, Drag Radials 374.6 rwhp 374.4rwtq @ 4.6L 10psi Now 5.1 and 15psi, no idea on the numbers!! |
#4 | |
2003 mustang v6 ;)
slow
2001 Bullitt
Cobras: Disc Brake Pad; DTC-70 w/0.585 Thickness; Rear;
GT isc Brake Pad; HP Plus w/0.660 Thickness; Rear; .075 difference in thickness.
Abyssinian of AX
'02 Saleen
19.34@42.259
Agreed
![]() A Cobra rear upgrade is of little benefit, beyond appearance. There is some mechanical advantage, so they "are" better, but not noticeable by seat of the pants ![]() My recommendation is to just leave the OEM GT rears with a set of good pads, SS lines and just go premium fluid. Jazzer
#7 | |
2001 Bullitt
+1 dont waste the money. most people think more pistons and bigger, must stop you faster. doesnt work like that lol
12.73@111.36
There was more to the kits when I was looking at them a few years ago. They included dust shields and some other parts. Oh, and I agree they are a waste of money.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
1998 Mustang GT
The Cobra Mounting Brackets are Different because they move the caliper out for the 11.65 inch rear rotor. And actually do waste the money because a stock GT rotor is solid not vented. The bigger cobra rotor is vented so they are thicker, which leads to yes a smaller pad. Because during an on track session my rear pads heat up and get way too hot and eat up axle seals. My rear brakes are white hot and smoking coming off track. Ive also gotta find a way for cooling ducts to get back there. My fronts are fine, I run ducts through the cobra fog light holes lol. and btw Im using Hawk blues. I just wanna now what all parts I need for the swap and Wheres the cheapest place to get them?
The Mean Green
All I needed when I did mine were the cobra mounts for the caliper brackets, rotors and pads. The stock caliper bracket can be grinded down to fit the wider rotors. The vented rotors should definatly help things stay cooler, plus they fill out the wheel better.
Threads Similar to: Rear Cobra Brakes
| Cobra rear brakes? | Wich88 | 4V / SVT | 15 | October 12th, 2011 09:45 PM |
| cobra brakes vs Baer brakes | 03SuperchargedGT | 99-04 | 20 | May 1st, 2009 05:08 PM |
| Installing 03 cobra rear brakes | Saleenssc14 | 99-04 | 11 | February 14th, 2009 06:59 PM |
| rear disk brakes and rear end | extropy | Classic Mustangs | 3 | August 11th, 2008 06:41 PM |
