2000 Mustang Gt
no clue
bad cop's and tps
I was reading and article about someone whose stang would stall when coming to a stop or cornering etc. Some of you know that I have that problem in my 00 gt so I was told to buy a new iac which didnt help. Well in that thread, I was told it could be a bad cop. I tested all my cop's and 3 or 4 are bad. Then I tested my tps (for the hell of it). The reference voltage is at 5 volts (haynes says thats where it should be). Then I tested the tps at idl. Haynes sayes it should be about 0.5-1 volt. Mines at almost 5 volts
. Then I would rev it and check the volts and it would actually go down. I wanted to get a second opinion on the everything. Also the cop's dont miss so Im not going to replace them right away and theyre 42 bucks on rock auto. Any info is appreciated.
Just because your cars loud doesnt mean its fast |
'02 GT 5spd
![]() iTrader: 1 reviews
TPS,,,,I'm amazed they last as long as they do given their construction. (I've built several TPS testers for 2nd/3rd tier suppliers). Might be easier to remove the TPS from the TB to test it. You're likely looking at the signal wrong, since your car does run.
They are usually pretty cheap too. I'd suggest just buying another TPS, even if that's not your problem, a new one will definitely provide a cleaner signal. (the internal wiper arm eventually gets bad spots on the contact strip).
boringly stock........but running well
#3 | |
2000 Mustang Gt
no clue
'02 GT 5spd
rockauto rocks
I don't think you could invert the voltage signal from your TPS and have the car run decently (besides stalling),,,at all. Hopefully the tps is your problem though, cheap/fast fix.
2000 Mustang Gt
no clue
Yea bro I order from rock auto all the time lol. I thought I was measuring the voltage wrong and I swapped the probes and the number turned negative ( its obvious now lol). I hope a new tps will solve my problem too bro. Ill keep you posted.
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
most accurate way to read the tps is threw a scan tool like sct cause it will show you what the computer sees. if indeed it is bad it is cheap to replace, hell i think i have an extra one laying around along with the coil packs. id sell you all the stuff you need for cheap so you can eliminate everything you think you have going wrong
![]() bone stock from the factory! |
#7 | |
2000 Mustang Gt
no clue
2003 mustang v6 ;)
slow
i have oem coils nothing special, but i have found that oem works best, i still run stock in my mid 600 hp car now
Chitty Chitty Bang Bang
2001 Mustang GT
I know these COP's have some bad rep to them, but I replaced all my COP's with these. At 176 shipped for all 8 it isn't bad at all. I was reading to make sure you use di-electric grease to hopefully prevent premature failure. Some people have them fail within a month, some people have them go 4+ years with no problems. Worth a try?
2001 Mustang GT 5-Speed ![]() God Created Man, but Sam Colt Made Them Equal |
2003 mustang v6 ;)
slow
oh well, i only have 7 used ones that worked fine when i pulled them
#12 | |
2000 Mustang Gt
no clue
I think Im going to wait a little while before I replace my coils. They havent failed yet and I feel that money should be spent elsewhere
2001 Mustang GT
If they aren't bad I wouldn't replace them. I thought I had a bad one so that's why I replaced mine. If I didn't, I would have kept it OEM
2000 Mustang Gt
no clue
They dont miss so Im not going to replace them yet. I researched how to check cop's with a multimeter and 3 or 4 were out of spec
I also have this problem its mostly only when I come to a pretty quick stop however it has done it a few times literally driving down the freeway.
2000 Mustang Gt
no clue
I think its common with our cars actually. My car has never stalled on me on the interstate but a few times when I was turning it stalled and Id almost nail a curb or a car at the intersection so Id like to solve the problem
12.73@111.36
Mine was doing this all the time. I cleaned the IAC and it still did it. Are you running an aftermarket throttle body? The stock throttle body has a hole in the butterfly valve. The BBK one I bought didn't. At first I had vacuum lock and had to tweak the stop screw about a 1/16th turn to fix that. It still was stalling going around corners. I eventually tweaked the stop screw a little more, not much, and not enough to change the idle. Problem fixed. I don't really know but maybe the butterfly valve was shutting too fast or too tight and it wasn't giving the IAC enough time to react. I been running it that way for two years now without any problems.
You might try adjusting the stop screw. It's a whole lot less expensive than replacing all that other stuff.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
#18 | |
2000 Mustang Gt
no clue
Threads Similar to: bad cop's and tps
| help please COP's | 4.6DreameR | 99-04 | 2 | October 23rd, 2011 11:51 AM |
| Is there a difference between GT cop's and mach cop's? | 93hatch | 4V / SVT | 22 | June 15th, 2009 07:18 PM |
| MSD COP's | UnixHH | 99-04 | 17 | January 26th, 2009 07:07 AM |
| COP's | 68 dlxcoupe | 4V / SVT | 0 | June 1st, 2008 09:26 PM |
| COP's | GTsetGO | 99-04 | 3 | May 1st, 2008 03:17 PM |
