General 460 question
so ive got a 460 in a toy and it is losing oil pressure when it warms up (normal i know) but it cold starts in the dead middle of "normal" and after 20 mins is off the gauge low, it comes back up with RPMs but is still super low. thoughts? suggestions? im going to get an aftermarket gauge today and see if i can get a accurate numerical reading. im debating just going to a stupid heavy oil lol or doing a high volume pump. how hard is it to change the oil pump? i realize this could be due to main bearings and oil pump but im not in a position right now to tear down the motor this is in my DD. thanks guys.
2003 Mustang Fauxbra
N/T @ Fast
460 or a 4.6? If it's a 460 you have to drop the pain to replace the pump. If it's a 4.6 the pump sits on the crank snout behind the timing cover. Two completely different animals.
![]() All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now? 03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold |
460 as in the big block made forever that made like 13456ftlbs and 25hp. i thought it was a pan dropping scenario is it drop the pan, drop the pick up tube, and its right there? that easy?
N/T @ Fast
Yes sir. Correct. I think your hp numbers are slightly skewed but the torque number is pretty close.
08 roush stage 3 mustang
worn out bearing, common on high miler, Have had a few of those, from the 429 to a 545 stroker.
well could i get by till spring ya think with a high volume pump and some 20W50? its a dd and i need it i could rebuild it in the spring when i have the mustang back out of storage
Yes, run the 20-50 and see what happens. Some will run along time with low oil pressure.
N/T @ Fast
You may wanna read a little in your spare time, pretty good resources in the forum and decent classified section.
460 Ford Forum
sweet, thanks! (if it blows up im hunting you down ford429 and your "yes").... just fuggin with ya... sorta... ...
#10 | |
yeah i seen that, just you guys at MM are johnny on the spot with answers and id say 80% of the time know what youre talking about lol so i figured id shoot the question here. but i will be forcing another registration upon that forum soon |
N/T @ Fast
lol, i'm a member over there too.
I'm a member there too! Hunt me down if you want too! good luck!! Yes, if you want to do it right you will rebuild it. I was just stating that it might make the winter with heavier oil, maybe hv pump. You said it was dd, and didnt have time to rebuild now. Haven't been on 460 ford forum for a long time- sold my 90 gt mustang drag car 3 yrs back.
If you decide on rebuilding, for peformance check with lem and charlie evans, lots of info and good prices at evans ford. They would have all you need from parts to shortblocks, and charlie does some very nice port work on heads, one of the best I know.
will do, and signed up over there.
Threads Similar to: General 460 question
| General Musing Question. | thewayshemoves | 99-04 | 11 | January 14th, 2009 04:15 AM |
| general question | bigbadwollfff04 | 99-04 | 9 | June 9th, 2008 10:41 AM |
| general question | jasons_98gt | 96-98 | 1 | February 2nd, 2008 02:38 PM |
| General Question | My02GT | 99-04 | 23 | January 10th, 2008 05:25 PM |
| general question here!!! | CBSTANG | 99-04 | 7 | March 26th, 2007 10:55 PM |
