2001 mustang GT
Cylinder Misfire...
I have a 2001 Mustang Gt i have a misfire in the 3rd cylinder from the firewall on drivers side.. when idleing i can pull connectors off coil and injector and no drop in RPM i can swap in a working coil pack and injector in that cylinder and nothing happens still no fuel or spark, i have taken the injector harness from that cylinder and plugged into a different injector and it works... would a dead piston still cause my fuel and spark not to drop idle when unplugged?? a few weeks before this happened i installed a focus fuel pump and A KB BAP would this cause me any problems??
the car is procharged 44lb injectors ((stock MAF sensor)), fuel pump and BAP, car is also untuned |
2003 Mustang GT
Put in 1 step colder plugs. Gap at .035 and get a dyno tune. You'll need a better maf of a MAFia. Those injrcters aren't calibrated to the maf, probably running rich
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
I like boobs!!!
2000 GT convertible
dunno
Run a compression check and make sure that cylinder is good. If you have bad compression you probably have a bent valve. Even with stock cams these 4.6's will hit the intake valve on the piston at high rpms... ask me how I know.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
2001 mustang GT
ok shaun i am running the NGK v-power in my car now and the MAf i have a Pro-m calibrated for my set up i just need a 3'' Maf housing so i can install it, would my stock MAF cause this problem only in 1 cylinder. And nick i hav'nt done a compression test i need to get that outta the way first off but, something i left out after the car warms up it smokes a faint bluish white out the tail pipes and where the manifold connects to the exhaust it smells like fuel, could it be too rich??
I like boobs!!!
2000 GT convertible
dunno
It could still be too rich, but I would rule out the cylinder with a compression test as soon as you can. Even if it's rich, it should still fire. If it was that rich, then the whole damn engine should be rich, not just one cylinder.
2003 Mustang GT
Is do a leakdown test over a compression
I like boobs!!!
2000 GT convertible
dunno
A compression check is WAAAAAAY easier than a leakdown test and will tell you IF something is wrong. If the compression is good, there's no reason to do a leakdown test. If you find something bad on your compression test though, a leakdown test will tell you WHAT AND WHERE that wrong something is.
2003 Mustang GT
Just because its easier doesn't make it okay. Just saying id do a leakdown test on that cylinder.
2001 mustang GT
thanks guys ill do a test on that cylinder an see how it checks out
2001 mustang GT
UPDATE the car had coolant leaking into spark plug cylinders causing the misfire, the shop cleaned out the water after this the smoking stopped would only smoke when at idle but would stop after i drove it for a while. After the weekend was over the car began to smoke again like before its a blueish/white (More blue than white) smoke and smells like burnt oil, I was in the process of taking the car back to the shop the following day and all my coolant leaked out of the resivoir onto the ground, anyone got suggestions or ideas??
#11 | |
2001 Mustang GT
01 GT Vert - Triple Black - 2v 5.4 270/340 00 Lightning - Triple Black - 2v SC 5.4 400/500 Brand New Tubular UCA and LCA set for sale PM me Slightly Used 05-09 Halo Headlights for sale PM me
MM's king of Neon's
404 - car not found
17.81@87
Even before this check what your oil and coolant looks like. This many issues popping up that the same time has got me wondering. Blueish smoke indicates burning oil, and pushing coolant out the reservoir can indicate the system is being pressurized by another source. I won't say what it might be because I don't want to jinx you.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
2001 mustang GT
The oil is fresh seems a lil runny though, under the oil cap only once have i seen any white on the bottom of cap, but as far as my dip stick no discoloration, my antifreeze isnt discolored, stinks and there is some brown residue on the inside of resivoir but i have read that is normal.. But like before i can pull the injector plug off the second inj from the front of car on driverside, I can pull this connector and no change in idle, I have put a noid light to this harness and i have a pulse And I imagine it will do the same for that coil like before these two components can be unplugged an u'd never know, swapping these parts does not help the problem either..
2001 mustang GT
other than the smoking and leaking coolant while parked for a while and the slight skip the car has, it runs great only startup problem i have had since the problems i have is when its really cold in the mornings its hard to start usually have to wait till the sun gets out around lunch but has only done that to me twice.. This is an awesome car but these lil mishaps are driving me crazy is the motor fucked or am i missing something...
i do have upgrades like 44lb inj 75mm TB an plenum and a p1sc charger and a few more goodies but it currently has a stock MAF in the car no tune that im aware of but i do have the correct MAF (Pro-M) fir my car just no housing to fit it... {If any of this helps} |
2001 mustang GT
im gonna start to tear this motor down and may just give myself an early bday present and grab the MMR 900 shortblock ive been droolin over
Threads Similar to: Cylinder Misfire...
| 6 cylinder misfire??? | 07CreamSickle | 2005 - 2010 | 16 | July 22nd, 2011 07:24 AM |
| cylinder 4 misfire and lodw compression in that cylinder.. helpppppp | $GTSTUD$ | 99-04 | 2 | June 1st, 2011 12:23 AM |
| cylinder 1 misfire | DsmDave | 99-04 | 7 | April 30th, 2011 01:46 PM |
| Misfire in Cylinder 1 | John's_stang | 99-04 | 6 | January 17th, 2010 10:27 PM |
| misfire cylinder #6 | hellbred07 | 2005 - 2010 | 11 | April 20th, 2009 09:40 PM |
