wheel spindle removal
Old May 31st, 2007, 05:50 PM   #1
smoke-em's Avatar
2004 Mach1
smoke-em is an unknown quantity at this point
Does anybody know how to get that mo fo off? I'm pretty sure i broke it when i hit a curb.
Old May 31st, 2007, 07:10 PM   #2
DrHolliday is on a distinguished road
I haven't looked to closely at the spindals on these cars, but I have changed them on a late 80's camaro.
You need to take the disc and bearing off the car. The center cap behind the rim should pry off they there is a pin going through a big nut to keep it from backing out. Remove the pin and nut, then pull the disc off. (if the disc just slides off with the claliper removed that you will only be removing the bearing housing that has the lug nuts attached to it)
Now, the spindle should be attached to the lower ball joint and the strut. The lower ball joint should just unbolt, and the strut should have 2 bolts connecting it to the top of the spindal. Unbolt it and it should come out.
I'll have my car on a lift tomorrow. I'll pull the wheels off the front and see how the sucker really comes off if you need me to. I could even take a few pictures.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old May 31st, 2007, 08:08 PM   #3
smoke-em's Avatar
2004 Mach1
cool man thanks
www.myspace.com/drunk_fest
Originally Posted by God View Post
Pussy is the single most greatest thing in the world. You're welcome.
Originally Posted by thetrooper31 View Post
i think smoke-em should be a role model for men everywhere
Old May 31st, 2007, 09:08 PM   #4
np, lemmi know if you need anymore help
Mustangless atm
Threads Similar to: wheel spindle removal
Help: TB and EGR removal nolife 5.0 Mustangs 7 August 24th, 2011 11:02 PM
94-95 spindle swap on a 1990 Notch kevnsue 5.0 Mustangs 12 October 21st, 2007 12:40 PM
Front spindle torq spec. Katen Classic Mustangs 1 September 19th, 2007 08:26 AM
Scratch Removal Coltdog 2005 - 2010 1 March 16th, 2007 12:40 AM
new headlights removal droppedbass87 Visual 10 January 19th, 2007 08:30 PM
