Best paint for valve covers?
Old December 2nd, 2011, 11:52 AM   #1
MacDizzle's Avatar
00 GT-MMR4.75(291)
MacDizzle will become famous soon enough
Im thinking about repainting my stock valve covers in the next couple days. Anyone have suggestions of the best way to go about this so it doesnt peel off?
Im into high speed chase play and im First On Race Day!
Old December 2nd, 2011, 12:15 PM   #2
1997 cougar 4.6 1/2PI
TooFast4theFUZZ
OptionalStang will become famous soon enough
i just roughed em up and then washed them with those sos pads with the built in degreaser shit.. and painted them with high temp engine spray paint i got from autozone..the only reason there is anychips is from my mafs hitting the corner of it..oil nor gas has even touched the finish and its 2 years old..i threw them in the oven for 10min while they were drying..heres a quick look of them, i wish id have done the black crinkle paint tho..
Old December 2nd, 2011, 12:48 PM   #3
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
1: Thoroughly clean the valve covers with degreaser. Even Dawn detergent will do.
2: Scuff everywhere with a 3M scuff pad. I used the red one. Make sure you get every crevice, and rough it up plenty.
3: Clean again with a lint free rag and some acetone or isopropyl alcohol. Something that evaporates and leaves no residue. Better still if you can use a tack cloth. A tack cloth is not required or necessary, but is "best practice."
4: Mask off as desired.
5: Hit that baby with some hi-temp engine paint. I used the Duplicolor which surprisingly worked out well, despite my bad experiences with their laquer based body paint in the past. When spraying stay perpendicular to the surface, coat in even, slow sweeps, overlapping 50%. Adjust distance so that you don't have it too far to get dry spray, but not too close that you get runs. You want the paint to flow evenly.
6: Let it flash off for 5-15min depending on conditions
7: Hit it with another 2 coats or so.
8: Let it dry and admire your work.
Hope it turns out like this:
Disclaimer: Painting your valve covers WILL NOT turn your engine into a 4v.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old December 2nd, 2011, 02:24 PM   #4
CobraStang161's Avatar
4V twin turbo 2000 GT
I live my life a quarter mile at a time xD
CobraStang161 will become famous soon enoughCobraStang161 will become famous soon enough
That hi temp shit peels very easy. If you want a REALLY nice quality job. Find your nearest auto body supply store and ask them to mix you up some urethane paint in a can, with a can or two of urethane clear. Urethane clear only lasts for 24 hours but it is the best period. Also ask them for the best can primer they got. Primer is KEY to a quality job as well...
Built 4V Motor with Sullivan Single Plane Intake
Custom 66MM BB TT kit
Borla XR-1 Dumped before rear
Moser built 9" Rear
35 spline WaveTrac Diff with 3.75s
35 spline Moser axles
14PT roll cage and minitubbed
Old December 2nd, 2011, 02:44 PM   #5
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
So did you use regular high temp paint And the urethane clear coat?
Rock stock
Old December 2nd, 2011, 02:46 PM   #6
Bringing Yellow Back
zinc-vert02's Avatar
2002 mustang gt
12.2 at 117
zinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to beholdzinc-vert02 is a splendid one to behold
Send a message via MSN to zinc-vert02
powerd coating....
SOON TO BE 5.4 3V POWERD WITH A ROUSH CHARGER HELPING IT
BAMA Performance Drag Team Member #4
Old December 2nd, 2011, 02:50 PM   #7
Nooo. I used urethane paint AND urethane clear. Urethane paint and clear is the same paint and clear used on the exterior of vehicles.
Moser built 9" Rear
Old December 2nd, 2011, 02:51 PM   #8
Originally Posted by zinc-vert02 View Post
powerd coating....
Sure you could spend $250 having them powdercoated. Or you could spend about $40 and have the same quality
Moser built 9" Rear
Old December 2nd, 2011, 03:07 PM   #9
MM's king of Neon's
404 - car not found
17.81@87
Well I'm glad the PO took care of all the powdercoating on my blower/timing cover/pulley bridge.
But I'm intrigued by the urethane. Maybe I just have experience with crummy urethane, I think it was the Summit generic one, but my friend had terrible luck with it.
As far as what I used, I haven't had any problems with the hi-temp enamel. I've mainly used it on engine blocks before, and they get pretty toasty. I even had one friend coat his headers with it, and it held up fine there. It probably doesn't look as good as urethane, but I don't have any questions as to its integrity, and it's a hell of a lot cheaper too.
Old December 2nd, 2011, 03:39 PM   #10
Yea u need to get good urethane clear. Good paint is critical for good quality
Moser built 9" Rear
Old December 2nd, 2011, 04:04 PM   #11
MM's king of Neon's
404 - car not found
17.81@87
What brand do you use? I've generally stuck to lacquer and even dabbled with some waterborne paints, but I'm not well versed in urethane brands.
Still tough to beat a $3 rattlecan of enamel though.
Old December 2nd, 2011, 04:24 PM   #12
I'm not a big fan of enamel as it sometimes gives you that hazy clear if it's not quality.
Here's the clearcoat I use. It's awesome!
Spray Max Rapid Cut-in Spot Clearcoat aerosol
Moser built 9" Rear
Old December 2nd, 2011, 08:47 PM   #13
MikeJones's Avatar
13.7@103
MikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really niceMikeJones is just really nice
Cool thread, I was thinking about this the other day. Too bad I don't know what color I want to paint my engine..
Mod6
Bigbore
Kooks
(parting out 2v motor)
Old December 2nd, 2011, 09:57 PM   #14
MacDizzle's Avatar
00 GT-MMR4.75(291)
Lol thanks
Thanks but im all good without a 4V, ive got an MMR 4.75L 750SE!
Old December 2nd, 2011, 09:59 PM   #15
MacDizzle's Avatar
00 GT-MMR4.75(291)
Holly SSHiiatsu
Wow that looks so so good!
Old December 3rd, 2011, 01:04 AM   #16
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
[/QUOTE]
Those valve covers are Sik! Nice job, now I want to paint mine.....
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit.
Old December 4th, 2011, 12:35 AM   #17
Thank you sir! Yours can look like that with urethane paint in a can and the Spraymax clear I posted.
Moser built 9" Rear
Old December 4th, 2011, 12:37 AM   #18
NOR*CAL's FINEST
3valveStallion's Avatar
2006 Mustang GT
Established in the back of a Boss 429 circa 1988
3valveStallion will become famous soon enough
engine enamel yo
(BBK TB)(JLT CAI)(BMR A-Arms)(J&M LCAs)(Pypes C-back)(BAMA93)(PS LTs)(PS O/R H)(Steeda CMDPs)(Prothane Bullet Mnts)
Old December 4th, 2011, 01:09 AM   #19
TooFast4theFUZZ
get some cool almi aftermarkets for an arm and a leg...
Old December 4th, 2011, 11:22 AM   #20
1989 Mustang GT
stangs4life is on a distinguished road
That urethane paint really looks sick
Threads Similar to: Best paint for valve covers?
help me decide what color to paint valve covers slater 2005 - 2010 22 December 5th, 2010 01:15 AM
valve covers viperlocc 5.0 Mustangs 11 June 17th, 2009 07:08 PM
valve covers 91cobra5.0 5.0 Mustangs 1 May 31st, 2008 03:33 PM
