02 gt
elec problem
im having an elec issue with my 02 gt i will be driving down the road and alll my elec will start cutting in and out and sometimes the car will not start acts like the battery is dead can come back 10 mins later and it will start right up car never cuts out when running or lose hp just elec power any sugggestions
02 gt
oh yeah when the power cuts in and out its only off for a few seconds
12.9 @ 111.44
Sorry to hear that man, electrical gremlins can be a pita. Easiest things to check are going to be battery terminals, the battery itself, the alternator, and fuses. Make sure your terminals are clean and tight. If you have a local autozone they can check your battery and alternator for free. Also, are you throwing any codes?
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2010 Mustang V6 Convert
Unknown
I would try taking some coke and pouring a bit on the terminals then cleaning them off with an old toothbrush.
If it's Fast and Cheap, it isnt reliable If it's Cheap and Reliable, it isnt fast If it Fast and reliable, it isnt cheap |
#5 | |
12.9 @ 111.44
A wire brush alone could do the job, still waiting for an update from the OP.
2000 Mustang GT 5spd
35.9@16.99
![]() ![]() ![]() iTrader: 17 reviews
I've done te coke trick and made it worse. So i bought a terminal brush for 1.99 and works the best.
Sounds more like a short somewhere in the wiring. Could have contact, hit a bump and come loose. Hot another bump and connects again. Strictly a guess.
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html |
![]() iTrader: 1 reviews
+1 clean the cables and check to make sure all conections are tight.
02 GT- TF TB/ upper, flows, steeda triax, steeda UDP, BBK CAI, H&R SS springs, Steeda SFC, Poly bushings, AGX shocks/struts, MM CC plates, Steeda bump steer, Chrome Cobra R's, Rear control arm kit. |
02 gt
Figured it out the battery itself is has a short I checkn the connections on the battery and noticed u could hear the battery arcinginside the casing
02 gt
Thanks thoe
check your grounds
Threads Similar to: elec problem
| Elec. Fan | blakehunter316 | 5.0 Mustangs | 23 | February 5th, 2010 09:19 PM |
| Elec Boost how to guide? | fastregalwe2 | 2005 - 2010 | 1 | June 18th, 2009 09:37 PM |
| is it elec. or mech. | Iownastang | 5.0 Mustangs | 11 | September 11th, 2007 06:43 PM |
| need elec. help | redalert89 | 5.0 Mustangs | 28 | July 13th, 2007 07:09 AM |
| elec. cut outs... | WVSNS& | 99-04 | 4 | April 5th, 2007 12:19 PM |
