Cars Making Loud Chirping Noise. Need Help.
Old December 3rd, 2011, 11:49 PM   #1
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
joshdj13 is on a distinguished road
i think my manual trans is making a loud chirping/squeaking noise, but it could be something in the bottom of the engine. its been making a quiet chirping/squeaking noise but when i almost had a semi hit me head on while i was leaving the gas station i dumped my clutch in reverse and goosed it. now the noise is loud like a sliping belt but in the back of engine or the transmission also my breaks seem to want to scrub but the pads and rotors are a week old. please help
Old December 3rd, 2011, 11:53 PM   #2
I Hate Convertibles...
2000 GT Vert
JoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to beholdJoshC! is a splendid one to behold
Send a message via MSN to JoshC!
if the noise goes away when you put pressure on the clutch pedal its your throw out bearing.
Im topless, are you?
Topless Mustang Club Founder
Black Stang Crew Member #boobs out
mods/pics
Old December 4th, 2011, 12:01 AM   #3
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
yep sounds like TOB. mine did the same. would go away completely as soon as the clutch pedal was pressed even slightly
cams + 150 shot
Old December 4th, 2011, 12:03 AM   #4
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
yeah it does seem to go away when you press the clutch in. what about the scrubbing? like i said it sound like the breaks but could my clutch be grinding/catching?
Old December 4th, 2011, 12:06 AM   #5
NOR*CAL's FINEST
3valveStallion's Avatar
2006 Mustang GT
Established in the back of a Boss 429 circa 1988
3valveStallion will become famous soon enough
my rear tires make loud chirping noises, seriously though alot of people w/ the same generation Mustang are creating threads about the TOB, must be that time of the year for TOBs
(BBK TB)(JLT CAI)(BMR A-Arms)(J&M LCAs)(Pypes C-back)(BAMA93)(PS LTs)(PS O/R H)(Steeda CMDPs)(Prothane Bullet Mnts)
Old December 4th, 2011, 12:11 AM   #6
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
is there a preferred bearing to buy or can i just get one from autozone?
Old December 4th, 2011, 12:21 AM   #7
2000 GT Vert
always buy a ford tob. NEVER buy anything different.
mods/pics
Old December 4th, 2011, 01:14 AM   #8
IsaidWOT's Avatar
IsaidWOT is on a distinguished road
What about the TOBs that come in the kits? Would you still buy a Ford bearing instead of using the one provided? Just wondering because I'll be replacing my clutch in a few months.
2002 Mustang GT | Short Throw Shifter | CAI | 3.73 Gears | Exedy Mach 400 Clutch
Old December 4th, 2011, 01:53 AM   #9
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
it seems alot of guys have bad luck with any other TOB other than an OEM/Ford piece. thats what i used when i put in my SPEC clutch
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old December 4th, 2011, 08:23 AM   #10
2000 GT Vert
NEVER USE AN AFTERMARKET TOB
i just wanna make sure im clear aftermarket TOB's will start making noise shortly after the install.
<<--- this dude found out the hard way
mods/pics
Old December 4th, 2011, 10:43 AM   #11
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
is it still ok to drive with or is it something that i need to park the car?
Old December 4th, 2011, 02:08 PM   #12
2000 GT Vert
itll be fine for a while but it is something youll want to think of replacing.
mods/pics
Old December 4th, 2011, 02:50 PM   #13
MMM JELLO!!!
esonu's Avatar
2003 mustang GT
esonu is on a distinguished road
damn i guess thats my problem too lol. how much does it cost to get it replaced? or is it worth it to change the whole clutch at the same time?
2003 Mustang GT Manual
18in staggered fr500s,Mach 1 lip, mach 1 grill
Old December 4th, 2011, 03:15 PM   #14
2000 GT Vert
if youre in there, its not a bad idea to just replace the clutch too. cost will depend on if you do it yourself or take it to a shop. different shop will charge different amounts.
mods/pics
Old December 4th, 2011, 05:29 PM   #15
joshdj13's Avatar
02 gt 5 speed
13.7 @96 stock
well it looks like the ford tob is b/w $40-50. i plan to do it myself so i hope it doesn't take too long. i've only replaced one and the car was on a lift so i hope its not too bad with the car on jack stands.
Old December 4th, 2011, 06:47 PM   #16
2000 GT Vert
ive done it on stands. its time consuming but can be done.
mods/pics
Old December 4th, 2011, 07:02 PM   #17
02gtKev's Avatar
2002 Stang GT
02gtKev is on a distinguished road
Shop i went to to installed my clutch, flyhweel, and replaced my rear main seal for $400 labor.
2002 GT Premium: A few bolt ons and such.
My garage if you want to know.
http://www.moddedmustangs.com/forums...-member-37069/
Threads Similar to: Cars Making Loud Chirping Noise. Need Help.
Cars making a weird noise.... :( schoff 99-04 5 June 10th, 2011 12:13 PM
Replaced idler pulley and still have chirping noise. freefallin2000 99-04 39 July 22nd, 2010 07:17 PM
Chirping Noise freefallin2000 99-04 15 May 1st, 2010 12:57 AM
engine chirping noise KB281JD General Tech 7 December 21st, 2009 01:04 PM
chirping noise nathom05 99-04 7 March 17th, 2008 05:36 PM
