Which is the best bang for the buck? - Page 2
Old December 27th, 2011, 01:05 PM   #21
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
I got my cobra brakes for the front for 260 with pads and I got the rotors for free
Rock stock
Old December 27th, 2011, 02:19 PM   #22
schoff's Avatar
2003 Mustang GT
schoff will become famous soon enough
Well that sounds like a hell of a deal for that cheap...doubt i would be able to find something for that cheap though. I see in your sig you got lca's...you think they were worth it?
Old December 27th, 2011, 02:44 PM   #23
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
somebody made a good point in looking into a tubular K member...
you will for sure need that for a turbo set-up. i need to look into one as well for myself. i think i may give UPR a try
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old December 27th, 2011, 03:02 PM   #24
ga289stocker's Avatar
2003 Mustang GT
13.58 @101.75
ga289stocker is on a distinguished road
My vote is the Plenum/Tb. I just installed the Plenum/spacer on my car last week, i already had a 70mm TB and it was a fun fairly easy install. The Stack unit is a nice quality piece for way less than an Accufab. I did not notice any bog down low, seems to pull a little better now above 4k from what i can tell. Can't wait to throw on the UPD's soon then try to improve on my times..
D/D- 2003 GT ,5sp,Borla O/R ,Predator,CAI,70mm TB,Upper Plenum,Steeda UDP'S,FRPP Alum d/s,Eibach's,CC,Tokico's, FR500's,3.27 gears-1/8 8.72 @82.63
1/4 13.58 @101.75
Weekend Warrior - 1965 2+2: 289 4sp-13.83@100.97
Old December 27th, 2011, 03:08 PM   #25
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Originally Posted by 35thredproject View Post
If u get the tb you will need a tune or u will bog, bought mine with a 78 and no tune... Bogged nasty 1-2500k rpms but I say suspension and look around for a used tb/plenum for much cheaper than that new price cause ur right it won't do much now but once you are pushing a lot more air it should help noticeably more.
You won't need a tune for a throttle body. Idk why yours was nothing, but it shouldn't unless there was a vacuum leak.
As far as gears, your supposed to run a higher gear (lower numerical value) with a turbo to help it spool. That's why you always see people run stock or 3.55s with a turbo.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old December 27th, 2011, 04:48 PM   #26
ham sandwich is on a distinguished road
tubular k member is a good idea
01 Bullitt #03179 Full bolt-ons. Cams incoming!
Old December 28th, 2011, 02:45 AM   #27
schoff's Avatar
2003 Mustang GT
"- QA1 K-member, A-arms, and UPR coilover kit for $645 shipped
Both include k-member, Tubular A-arms, and Coil-over kit. The QA1 also includes QA1 billet coilover fully adjustable strut and Caster/Camber plates"
I posted this a few posts back, it's a direct quote from the on3 website...all of this stuff is less than 700 bucks which to me seems like a pretty good price. Someone tell me otherwise if i should buy the parts seperate?
Also they have the MAF kit, injectors and the fuel pump you can purchase from them. I figured id just buy most the stuff from them as they seem to be good prices.
Old December 28th, 2011, 02:48 AM   #28
schoff's Avatar
2003 Mustang GT
I feel like when i have the turbo both the TB/plenum and lca's would both be things that would be beneficial to have. I was just curious which one would be the most noticeable difference to have now. I would assume both parts would be good additions to a turbo set up.
And that makes sense about the gears. I'd probably wait on the gears till i got the turbo so i could keep enjoying the gears. lol makes me feel like i have more power now! haha
Old December 28th, 2011, 11:48 AM   #29
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
buy the kmember kit now and install it(get it out the way).. thats what i would do..they also charge 280 or so fo injectors you can find 42s cheaper than that in great shape and low miles used for 175-200..hell you can get 60s for 225 used. get the fuel pump now and install it to get it out the way also(well i would) no reason to do the little stuff like tb/plenum when you can get the big crap out the way...then nit pick the little stuff while you are waiting till the summer to buy the kit..
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old December 28th, 2011, 01:22 PM   #30
just-agt's Avatar
2001 MUSTANG GT
just-agt is on a distinguished road
x2
A "Street Car" is......WHATEVER I WANT IT TO BE....stop cryin' and buy a Prius!!!!
Old December 31st, 2011, 09:54 AM   #31
99 Black GT
Not run yet
35thredproject is on a distinguished road
I may have left out it was the tb+plenum from accufab but 78mm is 13mm over the stock one and it definetely needed a tune.. Maybe that's not normal but it certainly fixed my car and my mpg went up.
Spec Stage 3 Clutch/Stack Racing CAI/SCT SF3 91 Tune/Accufab 78mm TB-Plenum/Nitto 555's
Old December 31st, 2011, 01:48 PM   #32
Faster than my X
2000 mustang gt
Not yet
crashed00gt is on a distinguished road
+1 QA1 k menber kit .i got some 39 ers off craiglist for 100 .search craiglist make it your best friend!
•MMR 4.75 900se coming soon•
Old January 2nd, 2012, 01:37 AM   #33
jivepepper's Avatar
jivepepper is just really nicejivepepper is just really nicejivepepper is just really nicejivepepper is just really nice
Originally Posted by schoff View Post
As sweet as that would be that is a little bit more than i was wanting to spend for a little pre turbo upgrade lol
I only had a about $350 in mine including Hawks racing pads. You can go to a parts store and get rebuilt calipers for a 96-98 Cobra for around $80-90 a piece. Pads for around $50 and rotors for about the same. I upgraded the brake hoses to goodrich braided steel ones for less than $50. But I ran the stock ones for the first few months. The brackets are cheap.
I found a deal when I bought mine. It was both calipers, brackets and pads for like 250 on ebay. Then I found a set of Brembo cross drilled and slotted rotors for less than $100. A company on ebay buys regular Brembo rotors and drills them in house. My stock brake hoses and banjo bolts worked fine. Sometimes you have to get new banjo bolts but they're are real cheap.
665/541 WHP/WTQ 4.6L SOHC 2V ON 93 OCTANE PUMP GAS.
NO METH INJ., NO E85, NO RACE GAS, N2O BABY BOTTLES!
TRAP=POWER: 11.01 @135, IN SUMMER HEAT, 1350' TRACK, 315/35/17 DR'S
Old January 2nd, 2012, 08:43 AM   #34
Abyssinian of AX
Jazzer The Cat's Avatar
'02 Saleen
19.34@42.259
Jazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant futureJazzer The Cat has a brilliant future
Originally Posted by Macattac View Post
Ask Jazzer what he thinks about LCA & UCA's
Go ahead.... make my day!
Go back a little over a year and was a thread on J&M upper control arms and important info from The Kitty
Jazzer
Cliff Notes: DON'T buy uppers that are solid with a poly bushing
Un-Official Suspension Guide | Choosing a new tire | Brakes upgrade ~ Speeding up slowing down | T-3650 ~ T-56 swap | Tire and Wheel Fitment Guide | The Kitty makes front page news
Originally Posted by Novanutcase View Post
"... although Jazzer's view is a little skewed since he pushes his car HARD so his opinion as to what works is more rooted in extreme circumstances!
Old January 2nd, 2012, 01:10 PM   #35
number1gt's Avatar
2002 mustang gt
You just got to look around, deals are out there that you'll never see without lokkinng around, I think my lca's were well worth it, I still spin quite a bit and im going to get relocated uppers....which is why I have stock uppers in now
Btw I got my mm lca's for 105 new shipped, deals are out there
Rock stock
Old January 2nd, 2012, 01:29 PM   #36
Abyssinian of AX
'02 Saleen
19.34@42.259
^ spinning is addressed by tires, where wheel hop is addressed by suspension. Relocated uppers will help a bit with weight transfer, but you, sir... need new condoms
Jazzer.... helpin' pepes with improved friction
Old January 2nd, 2012, 02:56 PM   #37
schoff's Avatar
2003 Mustang GT
haha thanks jazzer.
i remember now reading that thread last year sometimes. Good thing you reminded me cause i was going to purchase uca's as well, that saves me some money and i could just buy some flsfc's...with torque box reinforcements
Threads Similar to: Which is the best bang for the buck?
best bang for my buck AdaBoNGT 96-98 10 July 24th, 2010 10:42 PM
Best bang for my buck? RetroGT2006 2005 - 2010 147 July 6th, 2009 11:35 AM
best bang for your buck njstang 99-04 37 August 30th, 2008 02:50 PM
Best bang for the buck badf150boy123 99-04 15 March 3rd, 2008 11:14 PM
Best Bang For The Buck Mod? built54 Modular Mustangs 20 October 15th, 2006 01:23 PM
