#21 |
1999 GT 35th LE
USMCStang, check out the cams at Modular Head Shop, if you are using Trick Flow heads thay have some Bullet TFS specific cams for NA, nitrous, or boost.
The adjustable crank gears are the way to go and a lot less money. They do have to be either welded or pined together, but it's a lot less money. Have you already purchased your TFS heads?
![]() Drive it like you stole it |
#22 |
2000 mustang gt
13.7 @102
i also understand that i doesnt sound normal. i was shocked to hear that myself. but if you think about cam duration and lift ect vs CI the more aggressive cams work more normally and come in earlier on a bigger cube motor.. this is because there is more airflow which is higher intake and exhaust velocity per port size. my theory for the results he claimed, is that the trick flow heads are so much better than stock port flow, that the smaller cam is sufficient at filling the cylinders. im no engine builder by any means. and i have no idea why, but im being straight with all of you. he did NOT tell me if stock heads would be better with stage twos. but with trick flow heads and trick flow cams, he said stage ones worked better.. next time i go by the shop ill ask more about it and will definitely talk to him about some printouts and see if he would get on the forums. im sure many of you have read about dez racing in some of the MM&FF mags here and there. ill see what i can do about some proof tho.. i know you want to see it i would too
#23 | |
00 Mustang GT Vert/88 5.0
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Threads Similar to: Need info on a CAM upgrade!
| Wiring info and axle info needed | Mustang7125 | 96-98 | 4 | October 12th, 2010 08:21 AM |
| parts upgrade info. needed | predator421 | 5.0 Mustangs | 5 | May 17th, 2010 12:30 PM |
| The Official 99-04 Info & How-To Center ***DIRECT LINKS TO INFO*** | 06RedfireGT | 99-04 | 7 | April 5th, 2010 01:53 AM |
| Alternator Goin Out... Time For 3G Conversion? Info On Good Upgrade | Iwannagofast | 5.0 Mustangs | 96 | December 10th, 2007 11:16 PM |
| GT upgrade | night rider | Classic Mustangs | 2 | March 20th, 2007 05:47 AM |
