Need info on a CAM upgrade!
Old December 28th, 2011, 01:34 AM   #1
USMCstang01gt's Avatar
2001 Mustang GT
13.2@110
USMCstang01gt is on a distinguished road
Im looking to buying the Comp cam stage 2 camshafts off AM. it reccomends me purchasing the adjustable cam gears for an extra $290 more. are those really needed or are the stock ones just fine?
Old December 28th, 2011, 01:59 AM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Read what I put in your other thread. Don't get Comp cams for TF heads. Get TF cams. The TF heads are completely redesigned and the TF cams are best suited to them. As for the adjustable cam gears, you will absolutely need them. When I degreed my cams I ended up with the passenger side gear retarded by 6 degrees and the driver side advanced 5 to get both cams to the recommended 110 degree intake centerline.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old December 28th, 2011, 01:59 AM   #3
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Im running the comps without it...works just fine
Rock stock
Old December 28th, 2011, 02:00 AM   #4
I like boobs!!!
2000 GT convertible
dunno
And get some aviation quality bolts that are drilled for safety wire.
Old December 28th, 2011, 02:18 AM   #5
2001 Mustang GT
13.2@110
i just have a SOHC. and alright! thanks for the info!
Old December 28th, 2011, 02:19 AM   #6
2001 Mustang GT
13.2@110
where did you get your TF stage 2's at??
Old December 28th, 2011, 02:21 AM   #7
number1gt's Avatar
2002 mustang gt
Who said anything about you not having a 2v?
Rock stock
Old December 28th, 2011, 02:21 AM   #8
I like boobs!!!
2000 GT convertible
dunno
I understand that you have SOHC, but you will have to degree each cam individually. I am SOHC too. The reason I did not go with a crank gear that has the different notches to advance and retard the cams is because of exactly what I ran into. I wouldn't have been able to advance one cam and retard the other because both chains are on the same crank gear. Get the adjustable cam gears.
Old December 28th, 2011, 02:22 AM   #9
I like boobs!!!
2000 GT convertible
dunno
I got my TF stage 2's from a guy on ebay, they were brand new. Gimme a sec and I'll put up a link
Old December 28th, 2011, 02:25 AM   #10
I like boobs!!!
2000 GT convertible
dunno
Trick Flow 2V Stage 2 Cams - 4.6/5.4 | eBay
I had them at my house from this seller in about a week.
Old December 28th, 2011, 02:35 AM   #11
2001 Mustang GT
13.2@110
awesome man. ha they have the exact same cams on summit for the same price. i guess its just where i want to get them from. the TF heads dont come with the rockers. did you upgrade yours?
Old December 28th, 2011, 02:37 AM   #12
I like boobs!!!
2000 GT convertible
dunno
I'm using stock rockers. Just reuse the ones you have. As for the price, I bought mine a few weeks before Christmas so I got them for $479. I guess that was just a lucky find for me. They came with a hat too though :-)
Old December 28th, 2011, 02:48 AM   #13
2001 Mustang GT
13.2@110
sweet. get to save money then. and ohh shoooot(:
lucky..... so with those new heads and cams im getting. pluss the xpipe, shortys, FR intake manifold, JLT cai, the FM 10's and an SCT tunner. i wonder how much power im gnna get?
Old December 28th, 2011, 02:57 AM   #14
number1gt's Avatar
2002 mustang gt
You shold get longtubes
Rock stock
Old December 28th, 2011, 03:01 AM   #15
I like boobs!!!
2000 GT convertible
dunno
Originally Posted by USMCstang01gt View Post
... i wonder how much power im gnna get?
Probably not as much as you'd like to see, but with a good tune it will be a noticeable increase. I'm hoping to see 350 at the rear with my setup, and that's really reaching.
Old December 28th, 2011, 08:13 AM   #16
'03 GT
15@98mph :(
Macattac is on a distinguished road
350 incl or excl the NOS shot?
Magnaflow Catback | Steeda UDP | UPR CAI | AccuFab 75mm TB+Plenum| 14" rotors with 8 piston calipers | BMR LCA&UCA | Eibach Sportline Springs
Old December 28th, 2011, 08:18 AM   #17
I like boobs!!!
2000 GT convertible
dunno
You're kidding right?
Old December 28th, 2011, 09:09 AM   #18
hooliganryder's Avatar
00 mustang gt
hooliganryder is on a distinguished road
Get the adjustable crank gear it's alot cheaper.. And it's two separate gears so u can adjust each cam separate.. Thats what I have on my Cms stage 2 cams and have had no issues.. And I had send my cams to modular head shop to have them degreed.. Nick does and awesome job and I had my cams back in less than a week
Cms stage 2 cams
04 explorer aluminum engine
spec 3 clutch
sct x3
k and n cai
410 gears
underdrive pulleys
roush short throw
Old December 30th, 2011, 01:17 AM   #19
aarongt2000's Avatar
2000 mustang gt
13.7 @102
aarongt2000 is on a distinguished road
i was at dez racing about two months ago and wih trick flow heads on a gt. he told me the stage 1 cams made more power and tq over the stage 2s. i dont remember what rps he stopped he pull at but it was a comparison woh both cams with both N/A and procharged? maybe vortech? just thought i would throw hat in there. it was a test for muscle mustangs and fast fords magazine. maybe it will be printed soon? ill be looking for that one
Old December 30th, 2011, 01:39 AM   #20
I like boobs!!!
2000 GT convertible
dunno
Originally Posted by aarongt2000 View Post
...he told me the stage 1 cams made more power and tq over the stage 2s...
I find that hard to believe. The stage 2's have .030 more lift, a bit more duration, and a wider LSA to keep the powerband low enough to be useable in a stock engine but still work well with a built engine. I'd like to see some real dyno sheets for that claim.
Threads Similar to: Need info on a CAM upgrade!
Wiring info and axle info needed Mustang7125 96-98 4 October 12th, 2010 08:21 AM
parts upgrade info. needed predator421 5.0 Mustangs 5 May 17th, 2010 12:30 PM
The Official 99-04 Info & How-To Center ***DIRECT LINKS TO INFO*** 06RedfireGT 99-04 7 April 5th, 2010 01:53 AM
Alternator Goin Out... Time For 3G Conversion? Info On Good Upgrade Iwannagofast 5.0 Mustangs 96 December 10th, 2007 11:16 PM
GT upgrade night rider Classic Mustangs 2 March 20th, 2007 05:47 AM
