2000 Gt
2000 Mustang Gt Short Block - Where to find?
Hey guys i've reached the conclusion that if i buy a new motor i'm going to buy a 2000 mustang gt short block and also buy trickflow heads with a good cam to suit the heads (ideas welcome) What cams are you guys running with your trickflow heads ^^? my car will be a daily driver.
anyways my question is where can i find a re manufactured short block to buy? Thanks! |
1999 Mustang GT
stock 14.00@101
i would go with either the TF cams that are designed to go with the top end kit OR my favorite is the COMP CAMS stage 2
otherwise there is HiTech, VT, CMS, and a few others as for the block I'm not sure on re-manufactured, my guess is to google it... or just buy a short block from MMR or DSS
![]() Dark Satin Green 1999 GT | K&N | B&M Short Shifter | H&R SS| MM C/C Plates | Flow Master 40s | Mac O/R H | | 275/40/17 Front 315/35/17 Rear | NT555's | Visual stuff | YES I HATE BBK WAITING TO BE INSTALLED K&N FIPK, Accufab TB/Plenum, FRPP 4.10
#3 | |
2000 Gt
if not i'm mainly focused on finding the 2000 gt 2v motor, re manufactured =P p.s i love your spoiler delete, good thinking, love the looks of no spoiler Last edited by Mike Hadz; December 30th, 2011 at 03:38 PM. |
yes.... its just basically a stock shortblock rebuild with forged internals so all your old stuff will work..
whats your goals with the car rwhp wise?
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
#5 | |
wiggety wiggety whack!
Ford Modular engine - Wikipedia, the free encyclopedia |
2000 Gt
2000 Gt
shameless self bump
Products - Latemodel Restoration Supply
Products - Latemodel Restoration Supply 281 - 4.6L/281 - 2000 - FORD - Engine Rotating Kits - Engine Kits & Rotating Assemblies - Engines & Components - SummitRacing.com
03 V1 S trim @5psi 339/359 3:73's Iraq and Afghanistan War Vet 4 deployments from 01-08.My Wife is also a War Vet
Baker Jr.
Get a mmr shortblock...exact same just forged man..get a mmr 600shortblock and it will last to 600u or a 750 shortblocklike or a 900 which will hold 900 hp...more $ though but they have great sales going on right now and often. There a site sponsor and vendor so go check out there sales in the vendor section here!
MMR-Modular Mustang Racing Phils Machining-For your ABS Module Delete Manifold! American Muscle-www.Americanmuscle.com HorsePower By Hermonn-TUNER THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Baker Jr.
Cant beat a mmr motor...
#11 | |
#12 | |
2000 Gt
so this is the block yeah? MMR Street Mod 600 4.6 (up to 600 RWHP) $2599 SALE $2399!!] and i should get the 2v, i assume when i order it i can tell them what heads/cam i want and they will ship it with them on? then i can just simply swap all parts off old motor? and drop her in? |
12.73@111.36
I believe it will still be less expensive if you buy a long block from MMR. The 4.75L (up to 750 hp) motor starts at $4,800. MMR will install the Trick Flow heads for an additional $1,400. You can add cams for $640. They will adjust the compression ratio to your specifications. You will need to buy new valve covers. Windsor valve covers will not fit on Trick Flow heads. I think they told me you can get the Trick Flow valve covers for $300.
Edit: I need to make a correction. I was just told that Trick Flow heads will accept Windsor valve covers. My previous source was apparently wrong and that just saved me $300 if I select that option later. Modular Mustang Racing
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. Last edited by Eagle2000GT; December 31st, 2011 at 10:32 AM. |
#14 | |
2000 Gt
with that longblock can i use the stock ecu and just bring it to a performance shop to get it tuned? what else do i need to buy that won't swap over from my old engine? do you guys recommend a new intake manifold?
#16 | |
I like boobs!!!
2000 GT convertible
dunno
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!! ![]() My Garage--->http://www.moddedmustangs.com/forums...-member-46919/ |
Your intake manifold is fine. And for everything you need down to the T send a pm to either SSGPATE,NICK, ORI think his screenname is macdizzle. All of your parts including the manifold should swap right over. Its basicly just like getting a new motor but its just built/forged internals. And your ecu should work but you would want to get it tuned as far as i know.
#18 | |
12.73@111.36
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370 Mods list in Garage. |
00 Mustang GT Vert/88 5.0
Yes you can swap everything over, if you buy a long block you wont need to change over much, but with this block and trick flow heads you might want to upgrade you TB plenum. you can use your ECM you have now, but you will need a tune. you can reuse your intake manifold BUT if you go with trick flows you will need new valve covers since you have a windsor motor and heads?you will need new gaskets intake maniflod, TB, timing cover if it dont come with the new Longblock, water inlet gasket. check to see if it comes with an oil pan if not you will need that gasket, but you can reuse your stock pan. be sure to hang onto your old transmission Dowels from your old engine. That MMR stroker is a bad ass shortblock I have turned it many timesup to 7000 RPM with a long block you should be able to swap this in 2 days and have it running. any more question please feel free to ask. now I fogot to post this before but do not forget this you stock oil pan can be used as I said previous;y BUT you have to bend down the oil galley at the very front of the pan IF NOT the crank bolt will spin around and hit it.. I noticed this during my install. NICK MACDIZLE you guys check this cause it will hit.
![]() Proud Iraq and Afghanistan War veteran Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Baker Jr.
Mine did not hit...did not touch my stock oil pan..Just tossed it on...
Everything will work with the MMR man..They are top of the line and they are the place to go..They have a 1 year warranty and speak to MARK. He is the man and will take care of you. They hold many records and they are the mustang modular guru's!! As you can see, everyone is recommending them. Get you one of these beasts!! I personally run a mmr 900. There customer support is second to none and they will help you along the way with everything you need. They also send you some directions and tells you every little thing that you need to make sure you do so you dont have any catastrophic failures... Good luck man, Hope to see you rocking a MMR and putting a nice blower on one day and making that big power!!! Ryan Thompson MMR Phils Machining American Muscle HorsePower By Hermonn
Threads Similar to: 2000 Mustang Gt Short Block - Where to find?
| 11-11-11 SUPER SALE for MODDED MUSTANG MEMBERS > 900SE FORGED SHORT BLOCK $2499!!! | Mod Mustang Racing | 99-04 | 13 | November 12th, 2011 06:17 AM |
| 2005-10 Mustang 4.6L 3V Ford Racing (Frpp) "Aluminator" Short Block For F/I | Daniel0318 | 2005 - 2010 | 8 | September 29th, 2010 02:33 PM |
| short block's block vrs block in car stock? | adrenaline=lifeline | 99-04 | 7 | August 19th, 2008 08:22 AM |
| short block differs from a long block how? | mustangfox9091 | 5.0 Mustangs | 35 | September 26th, 2007 10:57 PM |
