03gt
![]() iTrader: 4 reviews
Pulling and engine with longtube headers installed??
I am removing my engine that has longtube headers installed on a 2003 Mustang GT. Will I need to remove the headers first to remove the engine or will there be enough space to pull it with them attached? Another option would be unbolting them and leaving them in the engine bay if I can get to all the bolts which looks nearly impossible with the k-member on. Just trying to think of an easier way without having to drop the K-member and remove the steering shaft. Any suggestions or ideas?
2002 mustang gt
![]() iTrader: 1 reviews
Yes you can leave it on, you can drop the engine in with them on so yeah, you'll have to disconnect the steering shaft though
Rock stock
Can fill 7 car garage
Is the transmission still connected to the engine? If you plan on pulling out the trans before the engine, you'll need to make sure the trans will clear the longtubes. My BBK LT's do not allow my trans to clear. If they don't clear, then you will be taking those LT's out!
1996 GT Convertible
13.88@100.71
Not sure in your '03 but I had to pull the drivers side when I pulled motor and trans in my '96. I didn't have enough room to get my steering shaft to swing out from where it runs between the middle tubes. Passenger side was not an issue and stayed on.
![]() Mods: Katzkin Leather, MMR stage II heads w/PI cams, PI intake, Accufab 75mm TB & Plenum, CAI, Ram HDX clutch, Pacesetter LT's & X pipe, Pypes hi-flo cats, Flowmaster cat back,3.73 gears, Sct SF3 tuner, Mamba M2's |
Here is one on me either installing or removing my engine with bbk longtubes. I did not have the trans attached.
03gt
Thanks guys. I'm pulling it without the tranny attached.
Threads Similar to: Pulling and engine with longtube headers installed??
| Longtube headers or shorty headers for 95 Mustang? | MustangV6Man? | V6 Mustangs | 27 | November 23rd, 2011 06:04 PM |
| Pulling engine without pulling tranny? | jrfan4life | 99-04 | 13 | June 4th, 2011 12:27 PM |
| i need help bad (longtube headers) | nolimits | 5.0 Mustangs | 2 | May 22nd, 2010 07:54 PM |
| longtube headers! | ZoomZoomMFer | 96-98 | 8 | November 7th, 2007 12:14 PM |
