LinkBack (1) | Thread Tools |
#1
Enlongated Member
11.95@113MPH
Cobra tank/hat wiring questions
So Im upgrading my fuel tank to 03 Cobra tank, stock 03 Cobra fuel hat (modified) and dual Supercar pumps. It has the stock harness still on the pumps, that has 2 plugs. One plug is the black round one, that goes to my factory body harness.
The other plug confuses me, it is a small, rectangular, light Blue plug. What does this plug do? Im hoping this is plug-n-play as I have enough on my plate with having to run AN line back to my y-block. I'll take a picture if need be but it for sure looks like a stock plug, I never recall seeing it when I dropped my stock GT tank before. Also, I am trying to gather as much reading info on dual FPDM's and such so if you have any good how-to links on this, I'd greatly appreciate it. I've googled a few but all the info I can get is for the better. Thanks!
2002 Mustang GT 4V swapped Nitrous best: 7.47@93MPH 1.60 60ft Turbo best: N/A ![]() 2008 Pontiac G8 GT Grocery Getter Mineral Gray Club Member #5 |
1999 Mustang TermiGT
The plug is there on the tank but when I did the swap I had to cut the GT connector and solder it onto the Cobra harness. The wires are the same color etc the connector is just different.
Mods 545 RWHP/580 RWTQ on a Mustang Dyno Delta Force Tuned by Team Pure Insanity Racing |
MM's king of Neon's
404 - car not found
17.81@87
Rabid is right. Mine came with the connectors, it was just plug and play.
And if you're thinking of doing dual FPDM, do it now. It would be a pain to retrofit it later. You'll have to drill some holes in the hat for the second pump's power wires. A couple writeups for you that work great- WestCoastMustangs.com Tank Removal/Pump Upgrade Step by Step PPRV Delete for Dummies - Step by Step on Vimeo I think derek that did the dual FPDM writeup is on MM too. Black306 or something like that. His page is excellent. I personally did the stand alone plug and play dual FPDM harness rather than splicing. You can grab a second FPDM with the pigtail out of a junkyard for like $25. I also advise the PPRV delete as long as you're replacing pumps. One of those "might as well" mods as long as everything is apart. To prevent kinking look for a 3/8" stainless U-bend. I got mine from a beer supply company from Kenmore, NY. Stal94 recommended it and it worked great. Make sure you get the correct grade hose.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
12.9 @ 111.44
Def do the pprv delete while you have everything out, and my advice is to make sure the clamps on the fuel hoses are as tight as a virgins... yea you know what I mean, only saying that due to past failures.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
2004 Mustang
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 4 reviews
NXstang lol I like the name! Looks like you run the 1/8th as well, what all is done to the car? And vids @ the track? And if your staying on spray with the stock bottom end a good single pump with possibly a BAP will support more than your bottom end will.
![]() 305/333 WHP/WTQ with CMS Stage II cams 440/552 WHP/WTQ on Spray 7.86 @ 89.1mph, 1.61 60 foot N/A 7.20 @ 98.8MPH 1.55 60 foot on spray Stock Longblock with Cams |
2003 MUSTANG GT
![]() ![]() ![]() ![]() iTrader: 10 reviews
Where the hell did you find an 04 cobra gas tank? I have been looking forever
Sent from my Autoguide iPhone app
![]() 4v MMR 4.75 Stroker, Teksid block .020 over, 9.27:1CR, Posi Race Ported Eaton 4v MMR Stroker 1000 / Posi Race Ported Eaton Build How To: 2v to 4v COP Swap |
2004 mustang GT
![]() iTrader: 7 reviews
A cobra tank is different from the rest?
Flowmaster super44's, 70mm frpp TB, C&L plenum, K&N cai,UDP,SCT SF3/X3, TR3650, short throw shifter, Mac O/R H pipe Waiting to install vortech v2 s trim |
2003 MUSTANG GT
Yes, the 03/04's are baffled and sumped from the factory.
2004 mustang GT
And they fit in the GT's?
#11 | |
Enlongated Member
11.95@113MPH
Yes I run the 1/8th, although not as much as I used to. Our local track (10 minutes from me) is 1/8th mile. Best the car has went is 7.47@93.xxmph 1.60 60ft. WE only got a few passes that night and it was cold as hell, so the track on top of my blown struts were not allowing teh hookage. Combo is (well WAS lol): - 96 Teksid block - Cobra crank, forged rods, JE pistons (9.1:1 CR) - stock 96 cobra heads/cams (b-heads) - 96 Cobra intake, short runner (slightly) - SVO single blade TB - JLT RAI - Flowtech LongTube headers w/X-pipe, MAC catback - PA Racing tubular k-member/a-arms, strange coilovers 14/150 springs, strange 10-way struts (blown out) - stock rear shocks/Steeda Sport Springs - spare tire/jack removed - NX Nozzle 150 shot (wet) Had issues with prior tuning so I took it to a new tuner who got it worked out back in August. Didn't get to take it to the track much with family and work, prolly 2-3 outings. Best time came on a 48 degree night.
Enlongated Member
11.95@113MPH
Sidenote: So I'm getting ready to order a crapton of parts. Already have an 03 tank, stock hat, and gt pumps. I don't feel like messing with the modified stock hat I got so I am going with the Fore Billet hat.
Anyone know where I can pick one of these up at? For a 03 Cobra tank, returnless system. double or triple pump one. Used or new. Will be looking to buy within the next two weeks.
2004 Mustang
Im running a single Stryker Div X pump with no BAP and it will support way more than my bottem end can handle. And looks like your lauch your front end was bobbin up and down like a boat, maybe try setting your struts a little stiffer or going to a 175lb spring. Also your trap looks low for your mods, I trapped about that with my 2V with cams and a 150 shot but my bottle was almost empty. Hoping for 98+ MPH with about a 7.10-7.20 ET with a full bottle. Do you have a drag bag in the back right? There only $35, ima get one to help with my suspension from unloading after my launch. Anyways good luck with your build man.
Enlongated Member
11.95@113MPH
MY front struts are completely blown. I bought SN95 Strange struts and since I lowered my car, they blew out in 6 months. Strange told me to f*ck myself when I asked them to stand behind their product.
The motor is low compression, about 8.8:1-9.1:1. I bought the built motor already built. It was built for boost but I was told it was stock CR. It obviously is not, as when I got it dyno'd and asked about it, the guy said "9.1:1 is stock, right?" Then he said he wasn't 100% sure if it was even that high. With higher CR it would be trapping closer to 100mph. I do not have an airbagi n the rear. I had coiloversi n the rear and they were horrible, so I sold them and went back to my stock shocks for the time behind, until I decided what to do. Which is stock (cut) springs, airbag in RR, and strange shocks. new front (fox) struts will settle the suspension out.
2004 Mustang
Not seen anyone with sucess with C/O's in the rear on our cars yet. Tbird had them but had problems with the eyelet breaking off the shock on every set of rear C/O's, don't know if he ever got it working or not. Im sure they are better if set up right, but not seen anyone on here using them with sucess yet.
Enlongated Member
11.95@113MPH
Yeah my car hooked worse with coilovers and it rode like shit. Not worth the hassle.
What tires are you running on the rear? Did you go return style fuel system with the division x hat?
2004 Mustang
Just swapped the pump for the Div X pump no BAP and 26x11.5x15 Hoosier QTP's
Faster than my X
2000 mustang gt
Not yet
Codycat there is a local.guy selling a cobra gas tank and has some other stuff too
•MMR 4.75 900se coming soon• |
#19 | |||
April 2012 ROTM
True blue crew founder/member #1378/442 rwhp/rwtq*on a Mustang dyno* cams are in..#'s coming this summer |
Enlongated Member
11.95@113MPH
How do you like the Hoosiers? I am in the market for new tires and QTP's sound very nice.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/244211-cobra-tank-hat-wiring-questions.html
| Thread Cobra tank/hat wiring questions | Forums at Modded Mustangs | BoardReader | This thread | Refback | April 13th, 2012 01:21 PM | |
Threads Similar to: Cobra tank/hat wiring questions
| Mach 460 wiring questions | V8ornothing | Audio/Video | 12 | July 15th, 2011 12:14 AM |
| Wiring questions | Av8tor | 5.0 Mustangs | 0 | April 26th, 2011 12:14 PM |
| Fish tank Questions | sickfox | The Clubhouse | 14 | February 24th, 2010 10:24 AM |
| Fuel Tank Sump Questions?????? | Mike Johnson | 5.0 Mustangs | 17 | August 28th, 2009 02:46 PM |
| Got my BAP..... wiring questions! | BakerFX4 | 99-04 | 4 | February 12th, 2009 06:44 PM |
