Rough idle after throttle body spacer
LinkBack (1) Thread Tools
Old January 1st, 2012, 02:31 AM   1 links from elsewhere to this Post. Click to view. #1
1992 Mustang GT
Black_GT is on a distinguished road
Just installed the throttle body spacer I bought off am and it idles almost like it has a cam but it runs fine. What could be causing this?
Btw I tried unplugging the battery, I left it unplugged for 5 mins and it still does it.
Old January 1st, 2012, 08:03 AM   #2
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
Sounds like a vacuum leak. Check all of your vacuum lines including the one on the backside of the plenum.
By the way the spacer was a waste of money and time spent putting it on.
Drive it like you stole it
Old January 1st, 2012, 08:12 AM   #3
2003 gt
5.4 32v on the way
DickH is just really niceDickH is just really niceDickH is just really niceDickH is just really niceDickH is just really nice
Probably a leak between the spacer and the throttle body or plenum. Make sure the gaskets are good and the bolts are snug and of course make sure all the vac lines and whatnot are plugged in, you may have bumped something and pulled it out.
2003 Mustang gt - usual mods - slowly working on 5.4 swap
2004 srt4 - Stock DD/winter beater
Click here for your tuning needs
Before asking a gearing related question click THIS link and enjoy all your saved time.
Old January 1st, 2012, 09:28 AM   #4
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
That was going to be my comment, take the spacer off and re-install the TB--then use the spacer as a unique paperweight...
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old January 1st, 2012, 09:42 AM   #5
2000 mustang gt vert
doubleohvert is on a distinguished road
check the EGR pipe. I had the same issue when i installed a UPR spacer. I thought the EGR pipe was tight enough until I started the car and my buddy as like "damn hen did you get cams?" Its a pita t get on tight because its barely long enough for stock, the you raise it 1/2"
Old January 1st, 2012, 10:50 AM   #6
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
sounds like your TB gasket is leaking, sometimes they get pinched during the install, did you use a new gasket? I always put silicone on my oring style gaskets during the install it keeps them from pinching and they slide into place better.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Old January 1st, 2012, 11:15 AM   #7
cliffyk's Avatar
If you use any sort of sealant on the intake (or for that matter at all anywhere on the engine) make certain it is labeled "oxygen sensor safe", those that are not can damage O2 sensors even if used in very small amounts...
-cliff knight-
My Mustang
Old January 1st, 2012, 11:17 AM   #8
SSG Pate's Avatar
I was not talking about selant I was talking about lubricant. but good point
LinkBack to this Thread: http://www.moddedmustangs.com/forums/99-04/244292-rough-idle-after-throttle-body-spacer.html
Thread Idle surging after throttle body install | Mustang Forums for All lFord Mustangs | BoardReader This thread Refback January 4th, 2012 10:06 AM
Threads Similar to: Rough idle after throttle body spacer
Throttle Body Spacer mrperple 2005 - 2010 V6 31 April 2nd, 2011 08:39 PM
throttle body spacer JASonic V6 Mustangs 7 October 12th, 2007 11:35 PM
throttle body spacer JASonic The Clubhouse 11 July 18th, 2007 08:46 PM
new throttle body old spacer cali 5.0 5.0 Mustangs 2 April 30th, 2007 12:33 AM
Throttle Body Spacer MartinG83 V6 Mustangs 33 January 12th, 2007 05:04 PM
