2003 mustang gt
99 gt longblock/shortblock same as my 03?
might have the chance to pickup a longlbock from a 99 gt locally with 70k miles...mihgt even just shoot the guy an offerfor the shortblock, cause he wants 700$ for the longblock...but is it the same because i figure if i have anohter block i can slowly start building mine becaue ill still have my car running throughout the time, i can drop it off at my engine builder and then just give him deposits when i get the money and he said hell work on it over time...this way i can rreally crank up some boost
... but back to the main question, will i just be able to swap the built shorblock for mine if its from a 99?
![]() 386/385 Kenne Bell powered ![]() 11.44@121.9 1.59 60 foot |
1999 GT 35th LE
The 99 Mustangs came with the Windsor engine. You more than likely have the Romeo engine.
Some differences between the two. Windsor - 13/14 bolt valve covers Romeo - 11 bolt valve covers Windsor - 8mm and 10mm bolts in the timing cover Romeo - 8mm bolts Windsor - 8 bolt crank Romeo - 6 bolt crank You would be better off to buy his longblock if it's a complete engine.
![]() Drive it like you stole it |
#3 | |
Can fill 7 car garage
So OP, yes, as long as you use the other complete engine in its entirety, you'll be fine. |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
windsor motors are accualy better than romeo. the rods are 1 gram heavier, and they have dowl's in the side of the block instead of bolts. they are also rated to hold more power, not that it is common for a romeo block to crack. romeo heads are better than windsor heads, the have cam girdles, and the later year heads have 9 spark plug threads. not that windsor heads are bad but most get timeserts installed.
![]() bone stock from the factory! |
Threads Similar to: 99 gt longblock/shortblock same as my 03?
| MMR Longblock | trent2590 | 99-04 | 53 | April 23rd, 2010 09:22 PM |
| 5.0 Shortblock/Longblock? | batlaxe | 5.0 Mustangs | 26 | February 10th, 2009 08:35 PM |
| 5.0 vs5.0 longblock | ThE GhOsT RiDer | 5.0 Mustangs | 2 | January 13th, 2008 11:57 AM |
