Spun Bearing?
Old January 3rd, 2012, 03:14 AM   #1
99 gt
that.damn.deigo is on a distinguished road
Spun Bearing?
x/
Old January 3rd, 2012, 03:26 AM   #2
0949er's Avatar
12.85 @ 114
0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough0949er is a jewel in the rough
I think the usual procedure here is to do a leak down test on all cylinders and see if anything turns up there. A knocking that gets louder/stays on par with acceleration is not a very reassuring sign though.... hopefully you are just real low in oil!!
MODS:
Vortech V1 T-Trim @ 7.5 PSI (tuned down)
Comp Cam Stage 2's
+ more
432 rwhp / 396 rwtq 02/27/2011
NEW VIDEOS!
**It takes ~$60 a rwhp (over stock) for a 99-04 Mustang GT.** Do the Math
C2H5OH on the horizon
Old January 3rd, 2012, 05:07 AM   #3
jeep45238's Avatar
2003 Mustang GT
jeep45238 is on a distinguished road
See if the noise is louder if you get your head by the ground - if it is, then you probably have a spun rod bearing. (your ears have a more direct line to the oil pan, making it more obvious when you're on the ground, and less so when you're standing)
Old January 3rd, 2012, 05:16 AM   #4
Mike Hadz's Avatar
2000 Gt
Mike Hadz is on a distinguished road
when you hear a bad sound and a knocking noise at higher rpms probably means you're running on 7 cylinders or something, and you should NEVER keep driving once a sound like this develops, could definitely cause further damage
Old January 3rd, 2012, 06:17 AM   #5
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
at this point the cost to rebuild the stock parts is not worth it. you can get your crank machined and polished to fix any scoring. as for the rods they are junk and you can pick up a set of modmax 5140 forged I beams for 275. as for the pistons they are kind of pricey but worth it at 515 for a set of 2618 forged pistons. where the money comes in is the machining of the block. for a budget build a torqe plate and hone, square deck and serfacing, and then you have to get it all balanced. if you choose to use arp main studs it adds more to the machining cause you should get the mains line honed. i have seen people spend 800-900 dollars in bock prep alone. even still you will need new bearings, rings, head studs, head gaskets, and much more. the average sb cost about 2700-3600 depending on how extream you want to go, and what parts you choose to re-use. if you cant afford to build a motor the cheapest way is to source a used running motor.
bone stock from the factory!
Old January 3rd, 2012, 08:05 AM   #6
1999 GT 35th LE
99GT35thLE has a spectacular aura about99GT35thLE has a spectacular aura about
since you have a 99 GT, you have the Windsor block. Just so you know if you decide to buy a short block from MMR they use the 04 Cobra block. There are some differences between the Windsor and the Cobra block. If you decide to go this route contact me and I can tell you what all you need parts wise as I am building a new engine using the MMR short block and I have the Windsor engine in my 99 GT.
Does your engine sound like it's missing at all?
Buy a automotive stethoscope and see if you can locate where the noise is coming from.
I had a lash adjuster (lifter) that was making a loud ticking sound, the noise went away and then a week later it blew apart.
Drive it like you stole it
Old January 3rd, 2012, 03:04 PM   #7
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
I have the manley pistons and 4340 forged MMR H beams for sale. They are the same internals that come in the MMR 600 kit. Pistons are stock comp and .20 over so your block will need to be bored .20 over. Then just use ur own crank or another stock crank.
I had originally bought the MMR 600 kit minus the crank. But now i have an all forged shortblock on the way from MMR so no need for these goods. Ill make you a good deal. If you or anyone else wants them, toss me a pm with an offer!
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 3rd, 2012, 03:04 PM   #8
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
MMR is great. All my dealings with them have been very good and they are always there to help you out and answer questions. You can't beat their prices on eigine packages either.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 3rd, 2012, 05:36 PM   #9
mattrotten's Avatar
Black 2003 Gt 5spd
2hrs@46mph
mattrotten is on a distinguished road
take a vid and put it up here so we can hear it. ive hadat least 7 spun bearings in my old cars. i kno 1 when i hear 1
Old January 3rd, 2012, 10:47 PM   #10
99 gt
anyone check out the vids?
Old January 4th, 2012, 12:00 AM   #11
screwd4vgt's Avatar
2001 gt mark8swap
13.8@100 for now
screwd4vgt is on a distinguished road
sounds like a spun bearing to me
01 GT with mark 8 swap.. with a 2.1 kenne bell...in the process
3.73s . longtubes o/r x pipe magnapacks, cobra brakes, gauges
Old January 4th, 2012, 11:06 AM   #12
screwd4vgt's Avatar
2001 gt mark8swap
13.8@100 for now
haha im from medina and i spun about 6 bearings about 5 months ago
Old January 4th, 2012, 11:19 AM   #13
I like boobs!!!
2000 GT convertible
dunno
That's a bearing, at least one. Time to tear down.
Old January 4th, 2012, 01:22 PM   #14
94racing's Avatar
2006 mustang gt500racecar
94racing will become famous soon enough94racing will become famous soon enough
if you woulda been in southeast ohio id have came and helped a bit. hope it turns out to be something easyer.
Check out our race team!
http://www.facebook.com/media/set/?s...3927011?v=wall
American Iron Mustang- ^1.6 lateral gs
03 Steeda 1.2 lateral Gs-ra1
08 Gt
Old January 4th, 2012, 04:28 PM   #15
jeep45238's Avatar
2003 Mustang GT
Same, but if you were in SW Ohio. Always up to gain more experience working on my kind of car - it just would have helped you out a bit too
Old January 4th, 2012, 04:46 PM   #16
99 gt
ha, thnx guys ill start a new thread once i begin a breakdown so everyone can stay updated.
Old January 4th, 2012, 05:58 PM   #17
mattrotten's Avatar
Black 2003 Gt 5spd
2hrs@46mph
yup bearing it is. oh well, 5.4 time!
Old January 4th, 2012, 06:29 PM   #18
99 gt
is the 5.4 a straight swap?
Old January 4th, 2012, 09:22 PM   #19
mattrotten's Avatar
Black 2003 Gt 5spd
2hrs@46mph
no theres a couple minor things to change like im adaptors and a few other minor things. theres a TON of info on this site alone to help. the motors are fairly cheap too and waayyyy torquier than ours
Old January 5th, 2012, 12:18 AM   #20
99 gt
gotcha.. im leaning more towards an mmr shortblock. ive heard nothing but good things from them and its useless rebuilding mine when itll cost the same if not more by the time im done..
Threads Similar to: Spun Bearing?
Spun Rod Bearing? Roadrashjr 99-04 7 May 23rd, 2011 11:23 AM
Spun bearing....what now BULLITT-STANG Modular Mustangs 4 February 23rd, 2011 11:07 AM
Spun Bearing? '98 sn95 96-98 3 August 12th, 2010 12:20 PM
Spun Bearing? treblruh 4V / SVT 2 March 7th, 2010 05:36 PM
spun a bearing WNTS 2RN 99-04 4 September 8th, 2008 08:33 AM
