Rebuilt Motor And Reinstalled. Now Drive Train Noise
Old January 3rd, 2012, 07:30 PM   #1
nathanielwilliam's Avatar
2001 Mustang GT
nathanielwilliam is on a distinguished road
tick is light and speeds up with rpm's. i didn't touch the tranny, just a new clutch, TO bearing and rebuilt the engine.
the tick stops if i put just a little pressure on the clutch pedal.
any ideas?
2001 Mustang GT
short throw shifter
4:10 gears
3 inch dual exaust (no cats!)
I have an F-150 which I drove the balls out of for seven years. Now I have a mustang that I drive the balls out of also.
Old January 3rd, 2012, 07:53 PM   #2
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
Tick or squeak.
I know if it squeaks and stops with slight pressure on clutch pedal it's a tob. But you just replaced it. Others will chime in with more knowledge.
Flywheel maybe?
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old January 3rd, 2012, 08:02 PM   #3
N20zuki is on a distinguished road
Did you use the self adjuster on the clutch pedal? Throw out bearing could be lightly touching the pressure plate...
2004 Mustang GT 40th Aniv 5spd, Stock for now.
2005 Joe Gibbs Silverado #0396
1986 Monte Carlo SS
Old January 3rd, 2012, 08:04 PM   #4
2001 Mustang GT
not a squeak, sounds like a metal on metal tick. kind of like the sound you would hear if you had a fan hitting a shroud. I can't imagine what it would be.
2001 Mustang GT
short throw shifter
4:10 gears
Old January 3rd, 2012, 08:05 PM   #5
2001 Mustang GT
explain N20zuki... i should try adjusting the pedal?
2001 Mustang GT
short throw shifter
4:10 gears
Old January 3rd, 2012, 08:11 PM   #6
86er's Avatar
well its in the clutch area, you have that figured out. Try adjusting the clutch again and what TOB did you use? Did you lightly grease the input shaft?
Just a truck
Old January 3rd, 2012, 09:02 PM   #7
To use the self adjuster you just lift up on the clutch pedal towards you with the tip of your foot and you will hear the pressure be taken off clutch fork.
I did a TOB in my wifes GT 2 weeks ago, thats it, didnt mess with anything else other then that and when I put it back together it needed to be re-adjusted so I would assume yours would need to be as well. Her pedal had no play in it and the new throw out bearing you could hear. Adjusted it and boom sound went away.
1986 Monte Carlo SS
Old January 4th, 2012, 12:46 PM   #8
2001 Mustang GT
86er... I greased the input shaft when installing. not sure what the brand was at the moment because it came in a kit.
I tried adjusting it last night and seemed to help some but still heard the sound when driving around the block. going to take it out today and see if it is better on the highway.
2001 Mustang GT
short throw shifter
4:10 gears
Old January 4th, 2012, 07:45 PM   #9
86er's Avatar
to be honest, wouldnt be shocked if it was the TOB. Ive seen them last just a few days, Ford is the ONLY TOB I would put on a car
Just a truck
Old January 4th, 2012, 09:29 PM   #10
2000 mustang gt vert
doubleohvert is on a distinguished road
did you make sure the ball that the clutch fork rides on is tight and not worn out?
Old February 2nd, 2012, 04:10 PM   #11
2001 Mustang GT
Well boys, I think I know what my rattle was. Today was warm so i cleaned out the garage and put the car on stands and crawled under it. original idea was that i needed to get an aftermarket clutch cable firewall adjuster. this may still be true but...
http://i1241.photobucket.com/albums/...2-01164735.jpg
500 Miles!!!! GRrrrr....
2001 Mustang GT
short throw shifter
4:10 gears
Old February 2nd, 2012, 04:18 PM   #12
2001 Mustang GT
oh, question... that bearing is obviously split but still has the balls in it. it feels very loose on the shaft. Do I need to mic the shaft and see if it is worn down? what should the diameter be? should a new throwout bearing be loose on the shaft?
i can get a Timken throwout bearing for $14 at Autozone right down the road. any recommendations on brand for replacement or should i just get the Timken.
2001 Mustang GT
short throw shifter
4:10 gears
Old February 2nd, 2012, 04:21 PM   #13
2001 Mustang GT
oh, doubleohvert... I did replace the stud that the fork rides on during the rebuild because it was worn.
2001 Mustang GT
short throw shifter
4:10 gears
Old February 2nd, 2012, 06:30 PM   #14
Jackpot, fishypoopypants!
2003 GT
1@3,000,000.... or is it 3,000,000@1?
Cathedral has a spectacular aura aboutCathedral has a spectacular aura about
From what I've read, the only TOB you should ever put in your car is a Ford TOB. Everyone seems to have problems when they use an aftermarket TOB.
Old February 2nd, 2012, 07:29 PM   #15
86er's Avatar
it wont wear down on the shaft, i wouldnt worry about that, but avoid the Timken, even though they make great parts, Id just throw the ford in there and call it quits
Just a truck
Old February 2nd, 2012, 07:31 PM   #16
cliffyk's Avatar
cliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of lightcliffyk is a glorious beacon of light
I think that what you are seeing there is just the self-centering/aligning action of the TOB, in action. Almost all replacements including FRPP's are made that way.
The release lever is not aligned perfectly parallel to the clutch assembly, flywheel, etc--nothing about the lever's mounting system assures this, and if it did it would likely be a real PITA to adjust.
So, the "swivel" action of the self-centering bearing assembly allows the actual bearing to cant slightly in it's holder so that it does press evenly against the clutch spring fingers.
-cliff knight-
My Mustang
2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat,
PP 70mm TB & plenum, DF Commando, Steeda UDPs,
Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs
3.73s, 262 rwHP/305 lb-ft.
Flex-fuel: burns gas and rubber...
Old February 2nd, 2012, 09:15 PM   #17
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
^+1
Threads Similar to: Rebuilt Motor And Reinstalled. Now Drive Train Noise
Drive train ???? kreil45 99-04 3 December 30th, 2011 07:42 PM
Drive train questions lcorriveau3 V6 Mustangs 10 December 3rd, 2009 10:15 AM
Drive train problem Mikes03 99-04 2 March 22nd, 2008 10:02 AM
drive train slack flattusmaximus78 5.0 Mustangs 35 January 3rd, 2008 02:00 AM
Drive train? BravoTeamLeader 5.0 Mustangs 1 December 17th, 2006 05:39 PM
