Cheapest Way To Spray...
Old January 3rd, 2012, 11:07 PM   #1
02gtmustang's Avatar
13.4@101 wheel spin
02gtmustang is on a distinguished road
So basicaly... Whats the cheapest way for me to do a 50-100 shot of nitrous? Dry or wet? What brand? Im already looking into my safety areas so dont worry bout that... Ima be getting a window switch an if the kit doesnt come with it a WOT switch an bottle heater a purge kit and also the blow down tube or what ever you call it i cant remember rite now... An i been hearing ill need a tach adapter for the window switch.. An another thing whats the biggest shot i can spray am get away with not having a custom tune
02 GT K&N CAI no cats FRPP drop diablo programmer cherry bomb mufflers MGW short throw shifter TFS UDP's 3.73's... Looking into some shorty headers upper intake got a 75mm tb waiting ... Ironhorsemotorsports.com for all your ford needs!
Old January 3rd, 2012, 11:33 PM   #2
laoutlaw01's Avatar
laoutlaw01 is on a distinguished road
Harrisspeedworks.com has some decent stuff at a fair price.
Old January 3rd, 2012, 11:36 PM   #3
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
mrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to beholdmrbigjeep is a splendid one to behold
100 shot on the stock tune all day. or on your current tune as long as its not too agressive
i'd go with a wet kit...any brand will work. i like harris speed works and nitrous express
cams + 150 shot
Old January 3rd, 2012, 11:42 PM   #4
13.4@101 wheel spin
Im thinking bout taking out alot of timing on my tune i have...
Old January 3rd, 2012, 11:57 PM   #5
13.4@101 wheel spin
I like the looks of the harris kits... Thanks for showing me them ive never heard of them till now an they seem very nicely priced...
Old January 4th, 2012, 12:02 AM   #6
mrbigjeep's Avatar
04 mustang gt
7.21 @ 98
how much timing is in your current tune
cams + 150 shot
Old January 4th, 2012, 02:07 AM   #7
MM's official Brony
foursixblurrrr03's Avatar
2003 Mustang GT
14.13 @ 98.4
foursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to allfoursixblurrrr03 is a name known to all
Send a message via AIM to foursixblurrrr03
Definitely do NOT do a dry kit. Here is a quote from the NX website:
"Every intake manifold made, either by the factory or the aftermarket is a compromise. No two cylinders get the same amount of air. Try as they might even the best sheet metal race intakes flow differently across all cylinders. When dry nitrous is introduced into the intake air stream of any intake manifold every cylinder will get a different amount of nitrous. Some will get more, and some will get less. Now, where does the fuel come from to utilize this nitrous? It comes from the stock injectors. Being an inanimate piece of hardware all it knows to do is introduce a predetermined amount of fuel into the cylinder that the ECM tells it to. This is without regard to how much nitrous actually got to the cylinder. Therefore every cylinder will be either rich or lean, but none will have the correct air/fuel ratio. Depending on how far this ratio is off will determine how much damage is going to happen to this cylinder. Very small amounts of nitrous can be successfully introduced without damage but the resulting imbalance of nitrous/fuel is always harmful to the engine."
Nitrous Express Next Generation Nitrous Oxide Systems <-- link
Originally Posted by Jazzer The Cat View Post
suspension is a waste of money. Throw a blown big-block in there and run a set of sumi's
Old January 4th, 2012, 06:15 AM   #8
13.4@101 wheel spin
Im unsure the diablo doesnt tell much on the hand held device
Old January 4th, 2012, 11:47 AM   #9
MM's official Brony
2003 Mustang GT
14.13 @ 98.4
Don't run nitrous with the 93 tune. Just modify the stock tune for your gears.
*edit* also, don't forget the little things you're going to need to spray. Colder plugs, a fuel rail adapter, etc (I went with zex plugs and a zex adapter). Maybe look into getting the NX genX II upgrade kit. It comes with a pressure regulated bottle heater, a liquid filled nitrous pressure gauge, a purge, and a blow down tube. It's a bit on the pricey side, but it's a great kit. Anyway, if you end up getting a used kit to save money, make sure that you have enough cash left over for little pieces that you're gonna need. Wires, splices, grommets, switches, plugs, fuel rail adapter, possibly more lines, fittings, etc. The little things are the reason I'm finally installing my first nitrous kit on my car, after owning 3 seperate kits. Ended up selling the first 2 because I didn't have the funds to finish it up and I got impatient.
Old January 4th, 2012, 11:52 AM   #10
1 Wheel Peel
GreenMustang00's Avatar
2000 Mustang 393w
2001 Mustang GT Vert
GreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura aboutGreenMustang00 has a spectacular aura about
Dynotune Nitrous is also very cheap..
I would like. To add that the kits on Summit aren't too badly priced. The Baseline Nitrous Express kit runs 300 bucks and comes with a free pressure gauge. I personally went with a Proton kit from NX when I had my sixxer motor. It is identical to the Zex kit except cheaper.
2000 393w Swapped Vert
2001 GT Vert
2002 Six Banger
Old January 4th, 2012, 01:04 PM   #11
13.4@101 wheel spin
Im looking at the nos sniper kit on summit an im already running a step colder plug the ngk tr6's... Harris speedworks i heard there solenoids wont open if you have a bottle psi over 1000... This true? An when you say dont run the 93 tune ill still have to run 93 too spray rite? Like as far as the fuel grade not the tune
Old January 4th, 2012, 02:09 PM   #12
1 Wheel Peel
2000 Mustang 393w
Nitrous Express (NX) - SummitRacing.com
they don't include a free gauge anymore but do give 30 summit bucks with the purchase of it.
Retard timing 1 degree per 50 shot
2001 GT Vert
2002 Six Banger
Old January 4th, 2012, 03:21 PM   #13
13.4@101 wheel spin
I like the looks of this one an price DynoTune Product, 622.2-99-04 Mustang GT/Cobra Nitrous System - DynoTune, Nitrous systems, Purge kits, Nitrous Bottle heaters and more!
Old January 4th, 2012, 04:16 PM   #14
N20zuki is on a distinguished road
NOS sniper kit... Although keep in mind the words Nitrous and cheap are not something you want in the same sentence...
2004 Mustang GT 40th Aniv 5spd, Stock for now.
2005 Joe Gibbs Silverado #0396
1986 Monte Carlo SS
Old January 4th, 2012, 05:03 PM   #15
1 Wheel Peel
2000 Mustang 393w
What makes the Sniper kit better than the other kits in the same price range? The orange bottle?
2001 GT Vert
2002 Six Banger
Old January 4th, 2012, 05:06 PM   #16
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
TNT nitrous makes a nice T/B plate kit.
I have also had good experiances with ZEX kits and they are pretty reasonable use.
Old January 4th, 2012, 05:23 PM   #17
Too Soon, Junior!
asiansensation78's Avatar
03 GT Vert
15:43.28@25.21 Too many naked bitches in the back
asiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to beholdasiansensation78 is a splendid one to behold
Buy my kit and save a ton of money
Includes everything from the Zex wet system and some additional toys: 10lb tank, solenoids/control unit, plate nozzle, lines, window switch with gear skip function, jets, bottle heater, purge solenoid, switches, gauge, etc. I'll also throw in a new set of NGK spark plugs if the price is right.
I also have a Diablosport Predator for sale if you need one. PM me if you want to discuss price.
03 GT - Scrapes on lane markers - Modded
02 Cougar - Able to clear most speed bumps - Some mods
01 Explorer - Parking blocks NOM NOM NOM - Stock
Nitrous Switch Panel for sale!
Old January 4th, 2012, 07:21 PM   #18
I aploigize not going into great detail about my reasoning, and the NOS sniper kit is somthing I recommend as I have actually used it before with great success..
I also saw someone recommended Dynotune Nitrous, I would also have the stand by that company as I have bought and used multiple kits from them for motorcycles I have had when I use to drag race them a few years back, I have used 5 dry kits from them and converted 2 of those kits to a wet direct port system.
And my statement of not wanting the words cheap and nitrous in the same sentence is due to this is where you hear the horror stories of Nitrous sucks and it blew my motor and all of those shinanagans... I have been using Nitrous for 10yrs with no incidents knock on wood and its because building or using the right kit and knowing the limits of nitrous and taking proper safety precautions.
1986 Monte Carlo SS
Old January 5th, 2012, 11:20 PM   #19
tbirdscwd's Avatar
12.88 @ 109.45 N/A
tbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to alltbirdscwd is a name known to all
iTrader: -1 reviews
Fun: 2004 Mustang GT
DD: 1994 Ram 2500 Cummins 4x4
Borla "Stinger" Exhaust Vids
Old January 5th, 2012, 11:30 PM   #20
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Honestly though, there is no "cheap" way to spray. I wouldnt just buy a zex kit and call that safe. Id run everything to guarantee its safe. Purge kit, bottle warmer, bottle pressure gauge, Id run a fuel pressure guage (BaznastyDave was getting a real nasty lean spike) etc.....
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Threads Similar to: Cheapest Way To Spray...
Your cheapest and best mod done... hbjarosek 2005 - 2010 62 May 30th, 2008 02:48 PM
Cheapest 4.10s Stang6899 V6 Mustangs 30 April 5th, 2008 02:38 AM
Spray or tune then spray GreenFaleen The Clubhouse 70 March 12th, 2008 10:35 PM
Cheapest S/C kit. RAGEman 99-04 24 March 7th, 2008 02:19 PM
