Fuel Pressure Guage
Old June 4th, 2007, 04:54 PM   #1
The Mean Green
MATT02GT's Avatar
MATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really niceMATT02GT is just really nice
Fuel Pressure Guage
Couldnt get any help in the electrical section so I thought Id try here...
Has anyone ever used an electric fuel presure guage. I recently put an Autometer one in my car and the thing is all over the place. The needle jumps when it shouldnt, and sometimes it seems to get stuck and read high psi when it shouldnt. The stuff is brand new. The only thing I could think that may be doing this is the sensor is mounted on the fuel rail, so maybe vibration?? Anyone else ever have this type of problem??
Bolt on list in Garage..
Old June 4th, 2007, 05:03 PM   #2
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
GTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud ofGTsetGO has much to be proud of
iTrader: 10 reviews
can't say that i have brah. mine seems to work fine (or what seems to be normal for me)
2008 Acura TL-S - 2008 Honda Pilot EX-SE - 2008 Cain F Big Bear Paradox
Old June 4th, 2007, 05:14 PM   #3
beheivjer's Avatar
beheivjer is on a distinguished road
if its vibrating on the rail you would be leaking fuel. mine is on the rail witha tee adaptor so i can still use the schrader valve and have no problems. a wacky gauge is usually a bad ground.
1969 Early Bronco 3.5" lift 37" swampers
1969 Early Bronco 2" lift half cab
1979 2.3t Cobra
1997 Black Cobra
http://www.cardomain.com/ride/680999
http://www.myspace.com/beheivjer
Old June 4th, 2007, 06:03 PM   #4
banned is on a distinguished road
thats why I went with all mechanicals - its a little more PITA - but more reliablely accurate
Considering selling my car to fund my race car: take a look and tell me what you think.
http://www.moddedmustangs.com/forums...ml#post1041280
Old June 4th, 2007, 06:08 PM   #5
Cigar Assassin
GTsetGO's Avatar
12.88 @ 112
iTrader: 10 reviews
Yeah, I have heard that mechanical are more reliable, but I mounted all of mine inside the compartment area and had to use electrical. it sucks cause they cost more
Old June 4th, 2007, 07:22 PM   #6
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Yep mechanical is great and cheaper but to run them inside your car you want to run electrical...
Thats how mine sits at idle and you can see it jump as I rev it...
Can you post a video of what yours is doing?
Facebook
Google+
Old June 12th, 2007, 09:33 PM   #7
The Mean Green
MATT02GT's Avatar
Finally got a video of the guage to post. Wouldnt the psi raise with the rpm? Does this look normal for an electric fuel psi guage?
http://s113.photobucket.com/albums/n...t=guagevid.flv
Old June 12th, 2007, 10:00 PM   #8
MM's nicest mod, :)
White99stang's Avatar
White99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to allWhite99stang is a name known to all
dude its not a boost gauge, all you need is the fuel pressure to stay at 40psi. If it were to raise it would only be by a couple of psi. It doesn't matter if you are going 2k rpms or 6krpms as long as the gauge doesn't go below 20 or so psi you are good. All the gauge is for is to make sure when you are under boost you don't loose fuel pressure cause that will lead to detonation.
06 Dodge MegaCab Diesel 455rwhp/815rwtq
REAL TRUCKS DON'T USE SPARK PLUGS
Old June 12th, 2007, 10:11 PM   #9
The Mean Green
MATT02GT's Avatar
Seems like a $300 piece of shit to me. I think its goin on ebay and getting replaced with an A/F guage
Old June 12th, 2007, 10:16 PM   #10
MM's nicest mod, :)
you are gonna be just as pissed with an a/f gauge, you think the needle is funny on the f/p gauge wait till you see the a/f gauge. It will be all over the place. Keep the fuel pressure gauge it is a great safety feature. I mean thats all gauges are meant for is to monitor your car not look cool and the needle doing cool things with the rpms. I think a a/f gauge from autometer is a big piece of shit. If you are gonna go with a a/f gauge get a LM-1 wideband sensor so you can actually hook it up to a laptop and get a/f reading all the time. But i would seriously keep the fuel pressure gauge. Cause you will never know when a fuel pump fails and you are low a fuel pressure and then boom
Old June 13th, 2007, 10:45 AM   #11
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Fuel pressure does not look bad in that video...Looks fine...
Keep the gauge...Watch the video in my post...
My wideband at idle runs 14.6 - 15.2...Just buy a good wideband...
Listen to what White99stang says...He speaks the troof...
BTW my Wideband is a Innovative XD-16 (gauge) and LC-1 (wiodeband controller)...I highly recommend them...
Facebook
Google+
Old June 13th, 2007, 11:33 AM   #12
The Mean Green
MATT02GT's Avatar
The guage has also got stuck like a 50-60 psi a few times, that ever happen to anyone?
Old June 13th, 2007, 01:08 PM   #13
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Never had it stick on me...I would call autometer and ask them what this could be...They can prolly tell you if it could be the gauge messing up...Or it could be an issue with your sending unit...They could help you out on all that...
Facebook
Google+
Threads Similar to: Fuel Pressure Guage
oil pressure guage g8tr 99-04 9 September 20th, 2007 11:33 PM
ELECTRIC FUEL PRESSURE GUAGE MATT02GT Audio/Video 2 May 29th, 2007 11:26 AM
air/fuel guage hookup...? Bossman Audio/Video 14 April 12th, 2007 11:53 PM
Fuel guage stuck after white face guage install r7r5 94-95 1 March 2nd, 2007 08:35 AM
oil pressure guage not working 1995svtcobra 94-95 2 August 20th, 2006 07:58 PM
