Powerpipe Installed
Old January 4th, 2012, 08:34 PM   #1
scooter3's Avatar
2003 GT
scooter3 is on a distinguished road
Powerpipe Installed
Decided to start the New Year off by installing my powerpipe. Car really woke up and the power seems more instant. This may be the year of the build, but for right now this thing is a blast to drive.
2003 GT
V2 SQ intercooled, SCT tune, MRT catted H-Pipe, Edelbrock catback, FRPP 3.73's, MGW shifter
242rwhp/286rwtq NA
381rwhp/372rwtq V2
My DD
Old January 4th, 2012, 08:40 PM   #2
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Should be okay, but you may want to consider getting the tune looked at it. The stock Vortech intake is such a restriction its not even funny
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 4th, 2012, 08:45 PM   #3
scooter3's Avatar
2003 GT
Talked to my tuner and he said there is no need since it really is not affecting my MAF scale since I am running a blow through set up. He tunes it for the whole MAF scale.
2003 GT
242rwhp/286rwtq NA
381rwhp/372rwtq V2
My DD
Old January 4th, 2012, 08:52 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Id datalog your Fuel pump duty cycle to be safe then. From what Ive seen powerpipes pick up alittle boost, but free up a lot of air flow and make a good amount more power. The Vortech intakes like I said flow horribly.
Just for example, I went to a dyno, was getting belt slip. 8psi @ 365rwhp. Took the intake off, made 8psi and 395rwhp. I know a open blower will outflow a powerpipe all day, but just an example.
Old January 4th, 2012, 09:19 PM   #5
scooter3's Avatar
2003 GT
Sounds good man I will do some dataloging and check it out. Thanks for the heads up.
2003 GT
242rwhp/286rwtq NA
381rwhp/372rwtq V2
My DD
Old January 4th, 2012, 10:12 PM   #6
zinsavage123's Avatar
2001 Mustang GT
12.33@111.23mph
zinsavage123 will become famous soon enough
powerpipes always usually make a psi or 2, seems like the afm powerpipe is the biggest one I have seen? here is mine
2001 Mustang GT - mods+pics in garage, tuned by matt@performance evolution
1996 Civic DX - my dd
Old January 4th, 2012, 10:30 PM   #7
blownstang's Avatar
blownstang has a spectacular aura aboutblownstang has a spectacular aura aboutblownstang has a spectacular aura about
Should be a 4" pipe. My KMS powerpipe is 4" and aluminum. The MPH powerpipe should also be 4", but plastic.
2003 DSG Mustang GT 5spd
Full Bolt On's, Suspension, Built Rear, V1 S
N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60'
Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60'
Intercooled: 362/370
Old January 4th, 2012, 11:14 PM   #8
Steve03GT's Avatar
2003 MUSTANG GT
12.5@113
Steve03GT is on a distinguished road
What did you do for an air filter set up, I have a similar set up for you, and want a Power pipe, but wasn't sure what all it includes,
2003 Mustang GT 398 hp, 365 tq 12.518@114.38mph
Vortech V3, BA 2600, Magnaflow CatBack, Pro 5.0 shifter, SCT Livewire, BBK Catted X, M/T ET Streets 315/35/17, 160* Stat, FRPP 4.10, CXRacing IC, Vortech MaxFlow Race Valve, 3.33 Pulley, BBK 78MM TB
Old January 5th, 2012, 12:22 AM   #9
ckkone's Avatar
2003 GT Vert
ckkone is on a distinguished road
Dude make your own powerpipe:
parts list to make your own power pipe.
Here is mine, I used this Treadstone 4" filter
Chris K - 03' GT
Old January 29th, 2012, 03:23 AM   #10
Nitmare67 is a jewel in the roughNitmare67 is a jewel in the roughNitmare67 is a jewel in the rough
My powerpipe picked up 2lbs of boost and and about 25hp. Pretty insane over the stock Vortech intake. My setup is making 12lbs at 6200-6300 with nothing but a V3SI, Vortech Aftercooler, 3.60 pulley!!! and AFM powerpipe. 12lbs with a 3.6 pulley and a power pipe.... gotta love an Si trim.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber
Old January 29th, 2012, 12:08 PM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Guy at dyno day had an f1c procharged 97 saleen. Put down 745rwhp with an afm powerpipe. Took the powerpipe off, mad 791rwhp. Lmao. Picked up 46rwhp and like 50rwtq.
Old January 29th, 2012, 01:01 PM   #12
blownstang's Avatar
Maybe filters are the restriction? I can't see the powerpipe being a restriction.
Old January 29th, 2012, 01:06 PM   #13
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Probably the pipe. Airs only coming in a 4" tube that probably flows half the cfm of the blower. Then if you just let the blower run open, its taking the air wherever.
He had one of those big k&n or jlt I forget
Old January 29th, 2012, 01:20 PM   #14
blownstang's Avatar
What we need to see is dyno results with a powerpipe and filter, just powerpipe without filter, no powerpipe just filter, and no powerpie no filter. I can't see it making a difference if the blower is pulling in air or if the air is being pulled in through the powerpipe without a filter connected. Aren't both openings the same size? Now the filter still needs to do its job of filtering and can be a restriction no matter how big or small the filter is. I've seen people gain some hp by going with cheap filters that do a poor job of filtering vs the better filters. When I get my intercooler installed I'll have to see if my tuner is willing to do a pull with the powerpipe disconnected to see if there is a difference.
Old January 29th, 2012, 01:59 PM   #15
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
I went to a dyno and was making 360rwhp at 8psi with belt slip. Took the intake off, same boost made 395rwhp.
The powerpipe is only allowing air in one direction. An open blower will take air from whetever. But then again, that's for dyno numbers. At the track or on the street this wouldnt work due to taking in hot underhood temps
Old January 29th, 2012, 02:08 PM   #16
Formally Ur PaNic
Nito2v's Avatar
2002 Mustang GT 4.6L
Nito2v will become famous soon enough
I guess I'm buying an afm powerpipe with my v3 si. LOL
2002 Ford Mustang 4.6 GT Coupe
4-spd Awesomatic - B&M Hammer - Procharger P1sc - 3 Core Intercooler - SCT Xcal3 - SSS Terminators
DGR / Dave Guy Tuned
354 rwhp / 365 rwtq
Old January 29th, 2012, 03:00 PM   #17
If its not making MORE boost then its NOT making more hp. The way all of this works is by increasing boost. To pick up 35rwhp you need at LEAST 2lb increase in boost....
Old January 29th, 2012, 03:06 PM   #18
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
No not at all. I'll prove that point when I swap to my better flowing intercooler and bigger pulley. I'll be at the same boost level, but a better flowing intercooler will pick up power.
Cfm matters a lot. Not just boost.
Threads Similar to: Powerpipe Installed
JLT Powerpipe Scott2001GT 99-04 11 November 25th, 2009 05:50 PM
S/C Powerpipe MATT02GT 99-04 3 May 21st, 2009 11:35 PM
Anybody with the MPH PowerPipe?? BakerFX4 99-04 10 June 17th, 2008 07:12 PM
