Mod Routes For 2v - Page 2
Old January 5th, 2012, 03:02 AM   #21
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
Originally Posted by 86er View Post
Last swing at this moth flying around the porch light.
Cams sound like such a cool thing to brag about, but in an auto car, your gains will be ok but not as great as you're thinking they will be.
Convertor, gears and a programmer with some good tires you will cut 1.5-20 seconds off your current time. Throw a $500 nitrous kit and knock another .75 or so off and spend not a lot more than the cams and springs etc that will MAYBE get you .5
Its your car, your time and your money
exactly..........
cams are not going to gain you much (except for a shitty running/driving car) on an auto without the propper converter & gears.
I'd do the gears first in your case & see where your at then.
BTW, 4.10's are a bare minmum on an auto car, you'll gain nothing with 3.73's but a lighter wallet.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 5th, 2012, 03:30 AM   #22
1999 gt
Don't know 13s
99 blk gt is on a distinguished road
4.30s , 3600 stall or 380@ whatever u like. Shift kit or change shift points and rev limit with tuner, full length sub frames and lower control arms. As for bolt ones get a mid pipe with high flow cats or off road if u can pass emmisions and a nice car back exhaust. Those mods you can actually feel. Then long tubes if you can afford it. The intake and throttle body stuff can come much later and like mentioned before isn't the restriction on these cars. In all reality the PI came are quite good and efficient it's the heads that are the most restrictive part of the car. If your going to drop 1500-2000$ on cams I'd say get the trick flow twisted wedge heads and then save for the matching trick flow stage 1-2 cams you will make 330+ with that set up and bolt ons, best heads for the 2v motor hands down.
bbk CAI, bbk throttle intake, frpp, 3.73s, sct 91 oct tune, steeda upd, magnaflow cat back, magnaflow O/R X pipe, MM Flsfc, Lakewood LCA, mgw shifter, king cobra clutch, 18"rims nt 555 Nittos 245, 285, halo angel eyes, autometer guages.
Old January 5th, 2012, 04:36 AM   #23
HighDensity's Avatar
Can fill 7 car garage
HighDensity has a spectacular aura aboutHighDensity has a spectacular aura about
Originally Posted by ham sandwich View Post
pullies are worthless, throttle body and plenum are worthless
get gears and save for your cams
Agreed on pullies and throttle body. But, plenum with power adder is beneficial. Running 502rwhp with stock TB but with Trick Flow plenum.
MM+ Cleavage Club #28
2 Fords - modified
1 BMW - modified
1 Mercedes - modified
2 beaters - bonestock
Originally Posted by thrasher View Post
OMG i couldnt imagine having lotion all up in my butt
Old January 5th, 2012, 06:00 AM   #24
ham sandwich is on a distinguished road
Sure, but for his application it would be a waste of money.
01 Bullitt #03179 Full bolt-ons. Cams incoming!
Old January 5th, 2012, 08:16 AM   #25
86er's Avatar
The heads arent that bad they are around a 175 or so cc head from the factory. Thats in line with aftermarket pushrod heads.
Just a truck
Old January 5th, 2012, 08:54 AM   #26
03OFP's Avatar
2004 Mustang Gt
Unknown
03OFP is on a distinguished road
Hi-Tech stage 2 cams are NOT drop in. Yes, they claim this and I'm currently running this set up. However, I degreed my cams and found passenger side was off 4.5* and the driver side was off 3*. This was enough that if just dropped in I would've had PTV. Make sure whoever installs your cams degrees them!!!
04 GT, Vortech V-3, Hi-Tech Stage 2 Cams, BBK shorties, ProChamber mids, SLP LM1's, FRPP aluminum D/S and 3.73's, Acufab upper plenum, 75mm TB, 75lb/hr FIC injectors
Old January 5th, 2012, 08:55 AM   #27
03OFP's Avatar
2004 Mustang Gt
Unknown
But this is what they sound like! Sick.
Old January 5th, 2012, 09:14 AM   #28
bulloch27's Avatar
2003 Mustang Fauxbra
N/T @ Fast
bulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the roughbulloch27 is a jewel in the rough
Spoken like a true believer. This advice is very true.
All the typical bolt-ons, well a lot are welded on. Bone stock I tell ya. First time at the track, what do I do now?
03 Silver Fauxbra; 06 Legend Lime GT, 89 Outwlaw 10.5W Coupe, 93 Teal Cobra, 93 Red GT, 93 Teal LX - All Sold
Old January 5th, 2012, 09:21 AM   #29
Mustang_Girl_32's Avatar
2003 v6/2003 GT vert
Mustang_Girl_32 will become famous soon enough
iTrader: 11 reviews
Defintely gears... 4.10s
2003 sonic blue v6- 18" gianna's, straight pipes, 12" DC level 5 with DC 3.5 K
2003 sonic blue GT vert- Bout to be a Procharged P1sc BEAST
Old January 5th, 2012, 10:40 AM   #30
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
Originally Posted by Woodman View Post
I tend to think differently than most.
Power without control is a waste. So in my opinion, upgrade suspension, brakes, tires, and full length subframe connectors first.
These are my thoughts as well, I've done tires, brakes, and my next step after the LCA's is 4.10's. However, mine is a 100% street car at this point
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old January 5th, 2012, 10:59 AM   #31
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
The easy ones would be gears, LCA's, FLSFC's, exhaust, stall, shift kit.
Stage II cams are generally a pain with 2v's. Stage I's you can usually drop in at the stock timing and without changing valve springs, but go bigger and you need new valve springs (more money) and will have to either notch pistons or retard timing to avoid PTV contact. Not fun.
If you're looking for a bigger jump in power, spray or FI is the way to go.
...or rip out your drivetrain/fuel system and replace with a Cobra one. At least that was my approach instead of bolt ons. But I'm also incurably insane.
BTW I'm about an hour south of you.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Old January 5th, 2012, 11:51 AM   #32
2001 gt
osa6637 is on a distinguished road
4.10's, converter, tune, flow tech longtubes and all stock longblock
went from 14.04 at 96.00mph to a best of 13.02 at 105.00
oh and the guys at Modular Headshop sell a very nice drop in Bullet Cam.
01 GT totaled, 97 cobra,95 GTS
bracket racing crew member #8
Old January 5th, 2012, 01:36 PM   #33
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
eddy21x will become famous soon enougheddy21x will become famous soon enough
4.30's
and spray
253rwhp 294rwtq motor
337rwhp 427rwtq 90 shot
Old January 5th, 2012, 07:38 PM   #34
mattrotten's Avatar
Black 2003 Gt 5spd
2hrs@46mph
mattrotten is on a distinguished road
yea seeing that the car is auto, i def wold do somethin else. i didnt notice u said that til afterwards. in that case, a stall, 4.10s and an sct tuner. you'll see a dramatic difference compared to stock. and although not cheap for all that totalled, its the best bang for buck in ur situation imo
Old January 5th, 2012, 08:29 PM   #35
BaznastyDave's Avatar
2004 Mustang
BaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to allBaznastyDave is a name known to all
My cams were just dropped in with trick flow springs, if I were to do it all over I would just do full intake and exhaust and an ON3 turbo kit @ about 9-10psi.
305/333 WHP/WTQ with CMS Stage II cams
440/552 WHP/WTQ on Spray
7.86 @ 89.1mph, 1.61 60 foot N/A
7.20 @ 98.8MPH 1.55 60 foot on spray
Stock Longblock with Cams
Old January 5th, 2012, 09:06 PM   #36
02BlueMustangGT's Avatar
9.12@77.7 - first time racing
02BlueMustangGT is on a distinguished road
Originally Posted by dbowen2007 View Post
save up and throw some force induction at it. Boltons will just penny and dime you to death. but gears are definitely worth the money
I've seen this advice enough to take heed of it lol
That's why I'm saving up for a used Vortech kit, instead of adding more bolt on's. But the P.O. put most on already anyways...
TRUE BLUE CREW MEMBER #7
2002 GT 5spd-Borla Stingers-Bassani O/R X pipe-BBK CAI-BBK 75mm TB-C&L Plenum-B&M short throw-JDM Race Seats-FRPP 4.10's-SCT Tuned by Bama-Lowered
Old January 5th, 2012, 10:38 PM   #37
1999 gt
Don't know 13s
First off decide what your car is going to be used for is it a DD is it a second day drive in rotation with a second car or is it a weekend warrior. Street car or dedicated track car. Figure out and plan wha your going to use the car for before you just start modding it and then realize down the road that you have to redo stuff. Ate you staying na for a longtime or looking for a power added/ FI/ or noz. I've known a lot of people who have wasted a lot of money doing things and down the road they needed to chage them. Like don't go high compression of your going to go findown the road don't do huge na cams of you wanna supercharge it and don't do pulleys. It your stayig na then all those things are great options. So basically just make sure you have a plan for the car before sinking unnessary money into it.
Old January 6th, 2012, 12:16 AM   #38
86er's Avatar
ha ha ha ha ha ah aha ha ha noz ha ha ha ha ha ha ha ha ha noz he said noz ha ha ha ha ha ha he really said noz ha ha ha ha ha ha ha ha ha
NOZ
Just a truck
Old January 6th, 2012, 04:03 PM   #39
mattrotten's Avatar
Black 2003 Gt 5spd
2hrs@46mph
NOZ
smh i knew some1 was gonna rip him for that lol
