Proper Gear Rebuild
Old January 4th, 2012, 10:01 PM   #1
Criscone's Avatar
Criscone is on a distinguished road
Send a message via AIM to Criscone
Proper Gear Rebuild
04 GT manual.
Swapping to 4.10s, what is the best rebuild kit to cover all my bases. Car has 98k. I see all types of rebuild kits, some with/without bearings, traklock?
In reality id like to get rid of all types of traction control if possible and just have a raw rear end, if that makes sense? Prob not an option tho id imagine, or even beneifical?
Old January 4th, 2012, 10:03 PM   #2
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
Just bought 4.10's too. Interested in what others say about this too
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old January 4th, 2012, 10:04 PM   #3
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Ratech part # 3008K has everything you need. That is the only kit we use at the shop when doing installs
Sent from my HTC Wildfire using AutoGuide App
Old January 4th, 2012, 10:10 PM   #4
TwistedScrew's Avatar
TwistedScrew is on a distinguished road
F8L GT, What size Hoosier's you running?
Old January 4th, 2012, 10:22 PM   #5
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
28x13.5x15
Old January 5th, 2012, 05:59 AM   #6
Criscone's Avatar
So no need for trakloc discs? I'm not even sure how they work or what there for, just happen to see them on the American muscle site.
Old January 5th, 2012, 06:08 AM   #7
ham sandwich is on a distinguished road
I didn't rebuild mine, but there are only 50,000 miles on my car
01 Bullitt #03179 Full bolt-ons. Cams incoming!
Old January 5th, 2012, 06:56 AM   #8
Criscone's Avatar
Ya that's why I'm wondering about them or anything else back there that should be replaced. What is there purpose anyhow? Just for traction control??
Old January 5th, 2012, 10:24 AM   #9
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
The clutch discs in the trac-loc rear end are what engage both tires at the point when one starts to slip. It will "lock" the wheels together and they will both spin, rather than just one.
The bearings are for the actual pinion gear itself, which sticks through the differential and turns the ring gear. The typical response seems to be to replace the bearings if you car has 50k+ miles or so, and to replace the clutch discs if you are getting the one-wheel-peel and or you feel like not having to worry about them for a while.
I'm assuming you're not planning on doing this yourself, in which case talk to the shop who will do the install and ask them to replace the clutches if they need it.
The "raw" rear end you're talking about is a locked differential, which sucks balls on a car driven on the street. I owned a jeep that had a welded differential, and it wasn't much fun to drive on the street. Off road, it was nice, but turning and parking was miserable.
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old January 5th, 2012, 10:52 AM   #10
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
^this
And as far as the raw rear end hes referring to, i think he just wants a rear end with no abs and no traction control.... But I could be wrong
Old January 5th, 2012, 11:07 AM   #11
Criscone's Avatar
Ok I'll be doing discs also just to be safe. I do all my own work, so yes I'll be doing this myself. I've replaced spider gears/axles on numerous trucks however I've never messed with this trakloc setup I'm sure there's a DIY out there.
Old January 5th, 2012, 11:20 AM   #12
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
There are a few how tos out there. I will see if I can dig some up for you
Old January 5th, 2012, 04:43 PM   #13
35.9@16.99
iTrader: 17 reviews
Here's a pretty good gear write up.
How To Install Gears on Your Mustang
Old January 5th, 2012, 04:54 PM   #14
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
while you're in there i would recommend getting a re-build kit for the limited slip. if you want it to operate like stock, i would give the kit with the kevlar clutch disks a shot. otherwise, guys that do gears alot told me to go ahead and get all the bearings. i think theres like 4 or 5 all together ??? counting the pinion bearing
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old January 5th, 2012, 05:22 PM   #15
02gtKev's Avatar
2002 Stang GT
02gtKev is on a distinguished road
Its pretty straight forward, but you would need some type of press to re-install the s-spring....it was a bitch.
2002 GT Premium: A few bolt ons and such.
My garage if you want to know.
http://www.moddedmustangs.com/forums...-member-37069/
Old January 5th, 2012, 08:58 PM   #16
Criscone's Avatar
thanks guys!
Threads Similar to: Proper Gear Rebuild
3rd gear doesnt strech to 100 after rebuild black05gt 5.0 Mustangs 6 March 23rd, 2011 01:18 AM
Choosing the Proper Gear Ratio JakeM Articles - Driveline 0 December 10th, 2010 08:23 PM
