Oil Leak Issue, Any Thoughts
Old January 5th, 2012, 05:46 AM   #1
2004 Sonic Blue GT
gates135 is on a distinguished road
Well Im a little confused, 2 days ago changed oil, drove car ran fine, parked it. came out this morning before work and there was a small puddle of oil beneath the car which appeared to be dripping from the driver side bend in the headers. I cranked the car up, idles smooth sounds fine, i did not see any apparent leaks in the engine bay, the oil drain plug is secure, oil filter is clean ?????? going to try and get the car in the air if i can get home from work in time but any thoughts ? Oh car has no power adder, only mods to engine are CAI, 75 mm tb , plenum , bbk long tube headers
Old January 5th, 2012, 07:08 AM   #2
2004 Sonic Blue GT
also it looked as if there may have been a small amount of oil on the header area near the dip stick oil tube. hopin mabe the tube came off or something simple, I hate being at work when theres something to be fixed ! crap will drive ya nuts haha
Old January 5th, 2012, 07:50 AM   #3
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Did you replace the gasket on the oil drain plug. If you don't have a good nylon gasket on it it WILL leak.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 5th, 2012, 07:54 AM   #4
2004 Sonic Blue GT
ill double check , but plug looked to be dry and clean
Old January 5th, 2012, 08:00 AM   #5
I like boobs!!!
2000 GT convertible
dunno
If it's not the plug, you could check where your dipstick goes into the block. There is just an o-ring around the dipstick, however I realy doubt it's coming from there, just kindof seems unlikely.
Old January 5th, 2012, 08:01 AM   #6
1999 Mustang GT
JTG87 is on a distinguished road
Check the oil filter housing gasket. Mine was leaking and throwing oil up the side of my valve cover by the dipstick tube like your talking about.
Old January 5th, 2012, 08:03 AM   #7
2004 Sonic Blue GT
ill definitely check these out, wish i could leave work so i could get the issue resolved, gotta show to attend on Saturday lol
Old January 5th, 2012, 08:06 AM   #8
I like boobs!!!
2000 GT convertible
dunno
This just reminded me. A long time ago on one of my old cars it was leaking after I had just done an oil change. What I found was that when I removed the old oil filter, the old oil filter gasket stayed on the engine so when I put the new oil filter on it was double gasketed and leaking through there. Might check that.
Old January 5th, 2012, 08:15 AM   #9
2004 Sonic Blue GT
not a bad idea
Old January 5th, 2012, 09:52 AM   #10
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Also make sure you didn't screw the filter on too tight causing the gasket to pinch and create a small "gap".
Old January 5th, 2012, 10:28 AM   #11
TheUNZippee!'s Avatar
Cam cover gasket?
BONER CREW EMPLOYEE - BWAL, CEO
Originally Posted by My Wife
Old January 6th, 2012, 10:56 AM   #12
2004 Sonic Blue GT
well after being stuck at work for 14 hours finally got home and got the car in the air, turns out that the small oil spot was from the oil filter change, so no oil leak. But I did discover the culprit! small leak in power steering line, and also the master cylinder appears to be bad. So at least its nothing major. thanks for the help guys
Threads Similar to: Oil Leak Issue, Any Thoughts
Intake manifold issue or head issue? sledgehammer357 All Other Vehicles 2 July 20th, 2011 01:58 AM
mafia issue? maf issue?? help nateCR 99-04 2 September 22nd, 2010 09:00 PM
Tranny issue, I need your thoughts please Diabeetus 4V / SVT 3 December 18th, 2008 03:33 AM
Opinions needed! Leak Issue redeluv General Tech 2 June 12th, 2008 09:37 PM
Evaporative Emission System Leak Detected (very small leak) Juggalo_X V6 Mustangs 11 April 25th, 2007 04:46 PM
