Wet Carpets Inside My Car?
Old January 5th, 2012, 09:46 AM   #1
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
I have a brand new top on my car which I do not think can be leaking. The old top was torn so I assumed the previously wet carpets had come from the 3 foot hole in the top. The only wet areas are behind the front seats. The reat seat and front seats are all dry and the interior panels are also dry. I just have a mysterious amount of water on the floor between the rear seat and the back of the front seat. Any experiences with this or thoughts at all?
Old January 5th, 2012, 11:22 AM   #2
termi_GT's Avatar
12.41@114
termi_GT has a spectacular aura abouttermi_GT has a spectacular aura about
If its on the passenger side I would guess your heater core has gone out.
I had a 99 GT that happened to and it had anitfreeze leaking on front passenger side and clear to the floor board of the backseat.
Old January 5th, 2012, 11:56 AM   #3
LGHTNG02GT's Avatar
4V swapped '02 GT
(2v) 13.9@101
LGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the roughLGHTNG02GT is a jewel in the rough
iTrader: 10 reviews
like termi GT said, check your heater core and make sure that is not the culprit...especially if your only having this problem on the passenger side. otherwise, you may have a leak somewhere up by the cowl. i know for sure i have this same problem with my '02 Coupe but its only after a very HARD rain that my carpet will become damp.
BSD 100MPH Club
YMR #8975
4v Swap and a little Purple Bottle
MM Nitrous Club #7
MM Cobra Club #87
Old January 5th, 2012, 02:04 PM   #4
2000 Mustang GT 5spd
35.9@16.99
Cabikejumper is a jewel in the roughCabikejumper is a jewel in the roughCabikejumper is a jewel in the rough
iTrader: 17 reviews
I read somewhere water gets in the side skirts and the water builds up then seeps(sp) in somehow. But i can't remember if I read that here or on a Subaru forum..
MODs: HP292 cams, LT's, o/r x, SLP LM1, 4.10,Mac cai, pro 5.0 more visual bs
Blu rays for sale: http://www.moddedmustangs.com/forums...ps3-fs-ft.html
Originally Posted by RZNCAIN View Post
Thats not a Mustang, thats a V6!
Old January 5th, 2012, 02:08 PM   #5
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
Heater core
Old January 5th, 2012, 02:54 PM   #6
2001 Gt
I do not think that it is my heater core. My front carpets are dry. It is definately coming from the rear. I had water under my rear seat and in the lining the top folds down into. Thoughts?
Old January 5th, 2012, 03:26 PM   #7
2001 Gt
Anyone?
Old January 5th, 2012, 03:40 PM   #8
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
This is what the guy at the convertible shop told me as well, that debris gets into the rails in the side skirt and when it gets backed up, it can cause water to seap in
Old January 10th, 2012, 02:29 PM   #9
StangGT99's Avatar
1999 Mustang GT Auto
StangGT99 is on a distinguished road
Had all sorts of leaking problems. Water would normally be on passenger side rear foot well. What I found was that it only leaked when the car was on an incline where the front of the car was pointing up the incline. If the position was reversed no leak.
Turns out that the water that was being channeled down into the rocker panel would drain out of a rocker panel weep hole towards the front of the car when car was facing down the incline. No water draining out of the weep hole towards the rear of the rocker panel. What I ended up doing was drilling a hole in the bottom of the rocker panel towards the rear of the door opening. No leak after that....at least not so far.
I would first take your back seat out to see if there is water there first. If that area is dry I would suspect a blocked drainage hole.
Threads Similar to: Wet Carpets Inside My Car?
What could cause this?(Pic Inside) mig4236 99-04 35 May 21st, 2009 03:01 AM
If you want to Laf Look Inside. 330CubeGt Videos 10 April 15th, 2009 01:22 AM
Just ordered! Seats/Carpets/Harnesses/Fog Lights/Seat Brackets gills99stang 99-04 19 April 28th, 2008 04:31 PM
the inside 07 STROKER Pictures 16 February 22nd, 2008 11:38 AM
I am sad...vid inside 1SLO85 Videos 13 June 13th, 2007 10:04 PM
