Heat Only Comes On When Driving
Old January 5th, 2012, 02:32 PM   #1
me2dumb4college's Avatar
me2dumb4college will become famous soon enough
So the heater only blows hot air when the car is at >1500rpm. Is this a heater core going bad or something else?
The temp gauge shows the car cooling off quickly at idle.
Old January 5th, 2012, 02:33 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Most likely you have low coolant level.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 5th, 2012, 02:44 PM   #3
I Poop Entirely Way Too Much
Blown 03 GT
03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice03_StangGuy is just really nice
If the core was bad you would have a "sweet" coolant smell in the car. Even if it were bad you would still get heat long as you have coolant in the car.
Old January 5th, 2012, 02:50 PM   #4
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
it would probubly be a good idea to look into a thermostat or at least make shure the one in the car is functioning properly.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old January 5th, 2012, 02:52 PM   #5
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
Not true. Heater cores plug up easy, and when plugged they don't smell but just don't blow hot at idle.
Op, start by checking your coolant. If there's still some in there I'd then flush it and throw a thermostat in it. If you do that I'd drain it all, unhook the heater core hoses and put a water hose on one and try and flush all the crap out of it. However that doesn't always work and if it's still just as bad you're gonna need a new heater core. If you've ever put bars leak or something like that in the cores probably plugged.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 5th, 2012, 02:58 PM   #6
wow good call, there's virtually no coolant in there... wtf
Old January 5th, 2012, 03:03 PM   #7
I like boobs!!!
2000 GT convertible
dunno
reps please LOL
Old January 5th, 2012, 03:04 PM   #8
i've given you too much rep nick...
Old January 5th, 2012, 03:05 PM   #9
i'm not sure what happened, but it was full before my mechanic changed out my spark plugs last week...
Old January 5th, 2012, 03:11 PM   #10
I like boobs!!!
2000 GT convertible
dunno
LOL I know you have, I was just kididng.
As far as why it's low, you should have that looked into. Do a cooling system pressure check. If you don't have a pressure tester, get one. They are fairly cheap and very useful. Do you know how to use one?
Old January 5th, 2012, 03:26 PM   #11
Blown 03 GT
If its clogged wouldnt it not put out much heat at all?
thats not good. Definitely top it off and see if you can find the leak.
Old January 5th, 2012, 03:26 PM   #12
Never done it before, but I'm sure I could figure it out. What pressure should it be at?
Old January 5th, 2012, 03:44 PM   #13
I like boobs!!!
2000 GT convertible
dunno
You want to pump the pressure in the system to the relief setting that your cap is rated for, usually about 13-15 psi. The first thing you will do is fill your system up with coolant (or you'll be pumping forever). Once you have it at around 13 psi just stop pumping and watch the gauge. It should be pretty steady. If it's dropping then you have a leak somewhere. With the system full of coolant and pressurized, if it's dropping pressure, you just have to find where it's leaking from, which should be evident by the coolant leaking onto the ground somewhere.
Old January 5th, 2012, 03:50 PM   #14
number1gt's Avatar
2002 mustang gt
number1gt will become famous soon enough
Couldn't say it better nick
Rock stock
Old January 5th, 2012, 03:58 PM   #15
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Kind of off topic, but my car has been losin antifreeze latley. I dont smell any at all when i pop the hood, and I just changed my oil and it was fine, not milky. The dipstick was fine, just oil came off of it.
Any ideas?
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 5th, 2012, 04:11 PM   #16
I like boobs!!!
2000 GT convertible
dunno
Any ideas?
Do this.
Old January 5th, 2012, 05:34 PM   #17
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Will do, but i figure if its leaking outside id definitley be able to smell it. Antifreeze has a strong and linguiring odor to it.
Old January 5th, 2012, 07:25 PM   #18
I like boobs!!!
2000 GT convertible
dunno
If it's a small enough leak and it's diluted with dirt and other crap you won't always smell it. You're right, antifreeze is pretty pungent, but sometimes it can be evasive. The best way to find a leak is with a pressure test. That being said, be careful. Don't overpressurize the system (keep it around 13 psi) and if pressure is dropping off and you're not finding a leak outside, check around the heater core asap, you don't want to douche your interior with coolant.
Threads Similar to: Heat Only Comes On When Driving
To heat or not to heat- Storage 08calspecial 2005 - 2010 5 October 28th, 2011 01:27 PM
No heat? black2001gt 99-04 12 March 27th, 2011 10:23 PM
heat? or no heat? 02gtmustang 99-04 17 July 16th, 2009 10:44 PM
driving a V-6 in the heat JASonic V6 Mustangs 19 May 7th, 2007 06:42 PM
no heat hmotes 5.0 Mustangs 8 January 15th, 2007 04:24 PM
