2003 mustang roush
Maf Pro M
I just found a Maf with 1000 miles on it for $80 its a pro m blow thru 3inch tube I think 80 mm is that good for a vortech v2 intercooled And it's calibrated or 42lbs injectors
2004 mustang gt
should be good. where you find it at? cuz im looking for one also
Vortech Intercooled hitech stage 2 cams 373 gear 75mm tb and c&l plenum bbk l/t 410rwhp 390ft lb @7psi ![]() image host |
#3 | |
BTW, you can get a brand new 90mm lightning maf LMAF for $90-110 used they are cheaper. They are the standard when it comes to a good maf for up to 500 rwhp.
2003 mustang roush
I'm going blow thru though
What is your point?
Does pressure now prevent a thermal mass meter (aka maf) from working?
2003 mustang roush
I didnt think u could do blow thru with that Maf army they blow thru ?
12.9 @ 111.44
I've heard lmaf's can have a hard time over 400hp, thats why I bought an hpx maf for my build.
![]() l Custom Hotside l TurboSmart l MHS l Hallman l On3 l BBK l Hellion l SCT l Flowmaster l Steeda l AEM l Tial l HPX l Hawk l Trickflow |
#8 | |
Now to the suck/blow maf question. Yes either one can be used in either application. Now the slot style (05+, hpx) mafs have proven better overall, BUT the 90mm LMAF is still a great maf even though it is typically used in suck through applications.
2003 mustang roush
Oh ok I got ya
2003 mustang roush
Oh and it's an older pro m also
3" = 75 mm...
Also, the 90 mm Lightning MAF will support right up to the maximum the PCM can support (1740 kg/h) without re-scaling the transfer function, standard air charge, and a couple other tune settings. 1740 kg/h = 3830 lb/h, running f/i that is enough air for 555 fwHP, 472 rwHP. Click here for more about "calibrated" MAFs...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
