Battery Drain - Page 2
Old January 8th, 2012, 04:11 PM   #21
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
You can use a test light to find the drian.
Old March 10th, 2012, 08:53 PM   #22
2000 Mustang GT Vert
Novi 1000 is on a distinguished road
hey bud did you ever find your drain.
I am trying to trace my down again in my 2000 GT Vert...
Pretty annyoing....I have a draw of aprx 1.4 amps........as of today in the car i've yanked out all the radio, power windows, door locks, trac control switch, convertible top switch, and power trunk...and battery is still dying......Maybe i should go after the main fuses under the hood first???
Old March 16th, 2012, 12:11 PM   #23
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
eddy21x will become famous soon enougheddy21x will become famous soon enough
i did find the drain it was the amplifiers in the trunk
253rwhp 294rwtq motor
337rwhp 427rwtq 90 shot
Old March 16th, 2012, 12:49 PM   #24
MM's Taint Shaver!
TaintedStang's Avatar
2003 Mustang GT
TaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to all
iTrader: 5 reviews
Originally Posted by SSG Pate View Post
Deal with it is not a good anwser, many times a battery will show good, and have a dead cell. if your alt is running your car properly, and it checks out cross that off the list, and replace your battery. Even brand new batteris go bad. Replace it and your issue will go away.
This was my problem. My car got to where if I drove it everyday, it would start perfectly but two day's and the battery would be toast! I bought a battery tester from Harbor Freight and found my problem. With the battery under a load it would drain down within five seconds! I also tested this after recharging the battery by turning the key on and just by turning on the radio, I could watch the factory voltage guage drop to low within a minute!
Old March 16th, 2012, 12:57 PM   #25
2001 Gt
Amps are probably your problem as well.... eddy21x how about some reps?
Old March 16th, 2012, 01:07 PM   #26
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
This is what I did. I was able to narrow down my drain to the circuit for the Instrument Cluster/ECU. When I pull that fuse the light goes out, no change with any other fuse. Now I have to figure out what in that circuit is messed up.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old March 17th, 2012, 12:18 AM   #27
Ok still waiting on my stuff from harbor freight to finish testing.
but what fuse or fuses run the amp if applicable (is it one of the radio one's or one of the mains from the distribution box)? also on a vert where are the amps. Figure i'll poke around some more tomorrow as car is on the charger for the night.
thanks for the feedback
Threads Similar to: Battery Drain
How long till battery drain while lisitng to radio car off? Jump car battery dead StoneColdStang V6 Mustangs 8 December 22nd, 2011 08:40 PM
Key Off Battery Drain ajzride Classic Mustangs 14 October 17th, 2011 09:59 PM
Battery Drain sukibusa 99-04 6 August 24th, 2009 11:48 PM
Battery drain 93Notch Audio/Video 3 February 16th, 2007 01:16 AM
Battery Drain 5.0mustang9509 5.0 Mustangs 1 November 7th, 2006 07:15 PM
