Battery Drain
Old January 5th, 2012, 02:58 PM   #1
'01 Gt Vert auto
13.2@103.8 n/a Stock stall
eddy21x will become famous soon enougheddy21x will become famous soon enough
Battery Drain
anyone had this problem
every morning now it seems i need a jump start
i checked the alternator tested out goood
the battery also tested out good
but it did say bettery may have drain when key off
what could be the problem all of a sudden?
cold weather maybe?
any tips on how to track this down
253rwhp 294rwtq motor
337rwhp 427rwtq 90 shot
Old January 5th, 2012, 02:59 PM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
Deal with it, it's a mustang. They all do it eventually. I've pulled my hair out trying to find mine. I would kiss someones ass if they could tell me what it was. I have an aircraft electical technicians license and I haven't been able to find the cause of mine. I'm just telling you what I was told... deal with it.
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 5th, 2012, 03:04 PM   #3
'01 Gt Vert auto
it sucks man im stuck here at home today was suppose to be at work at 2
the good thing is i can get parts really cheap though since i work at carquest
im gonna try replacing the alternator to see if that helps
check all my fuses
Old January 5th, 2012, 03:06 PM   #4
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
Lol deal with it? That's laziness. Eddy, could be a dead cell in the battery. Try getting a new one and use yours as a core charge.
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 5th, 2012, 03:08 PM   #5
95mustangGT/SVT's Avatar
2001 Gt
95mustangGT/SVT will become famous soon enough
My car did that and my amps were the culprit. If you have a bad amp it will drain the car quick. I would put a meter on the amps
Old January 5th, 2012, 03:09 PM   #6
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Fuses wont cause the battery to die. It either has a connection or doesn't. You could check but I think you'll be wasting time. If it was your alternator, it would be draining the battery as you drive, and youd lose all your power.
Only other thing I can think of is something staying on after you shut it off. My dads mach did that, traced it down and the radio was staying on. Until he replaced it, he pulled the fuse everytime he got out of the car. But the fuse wasn't the issue, something inside the unit was keeping the power on
Old January 5th, 2012, 03:09 PM   #7
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Thats what it was! The amps. Good call. Bitch to trace down huh?
Old January 5th, 2012, 03:13 PM   #8
2001 Gt
That was a real pain in the ass to find. I had a ford shop manual for my car and it was a nightmare. If I am right then I just saved you countless hours! Good luck and let me know what it is.
Old January 5th, 2012, 03:16 PM   #9
I like boobs!!!
2000 GT convertible
dunno
You just gave me an idea. I have the stock stereo but right around when this problem started I lost all bass in my stereo. I haven't messed with it in months because I've been working on putting the engine back together, but if this is the problem then I will back up my word and.... kiss your ass
Old January 5th, 2012, 05:24 PM   #10
MM's Taint Shaver!
TaintedStang's Avatar
2003 Mustang GT
TaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to allTaintedStang is a name known to all
iTrader: 5 reviews
I used to could let my car sit for a month and never had problems with it cranking, now if it sits more then two weeks my brand new battery will be dead. I haven't felt like trying to find my problem yet.
Old January 5th, 2012, 05:32 PM   #11
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
It's probably just the battery. Oem is the best. In many cases. I still have my stock battery from 03 and 104,xxx miles. Although I think its on its way out.
Old January 5th, 2012, 07:48 PM   #12
'01 Gt Vert auto
yeah its gonna be the amps on mine i tihnk
Old January 5th, 2012, 07:54 PM   #13
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Could be the battery too. Take out the fuse for the stereo setup. Its in the car under the steering wheel. Not sure which exact one. But let it sit overnight and see if it starts right up.
Good luck man
Old January 6th, 2012, 02:02 AM   #14
'01 Gt Vert auto
will do thank shaun
ill report back
Old January 6th, 2012, 02:09 AM   #15
moneygreenstang's Avatar
2001 Mustang GT
moneygreenstang will become famous soon enough
That "its a mustang deal with it" statement has some truth to it, this is a common problem with all fox chassis mustangs especially high mileage sn95s and new edges.
Mine started doing this and I havent found it yet. I removed the aftermarket amp, CD player, all mach 460 amps and speakers.
I swear Mustang electrical problems are next to Jaguars. Ive had a 93 and 95 xj6 and xj12 and theyre a nightmare. at least the mustang is cheap to fix
01 GT Vert - Triple Black - 2v 5.4 270/340
00 Lightning - Triple Black - 2v SC 5.4 400/500
Brand New Tubular UCA and LCA set for sale PM me
Slightly Used 05-09 Halo Headlights for sale PM me
Old January 6th, 2012, 03:24 AM   #16
!FACEPLATED!
F8L GT's Avatar
7.84 @ 86.01
iTrader: 13 reviews
Walmart everstart battery is the same as a motorcraft battery. Both are made by Johnson Controls and are identical. OEM batteries are more expensive because of the warranty they have with them
Old January 8th, 2012, 02:07 PM   #17
2001 Gt
If the factory amps still have power going to them then your battery will drain assuming they are bad.
Old January 8th, 2012, 02:33 PM   #18
'01 Gt Vert auto
well ive had a new battery in for the past 3 days so far so good lets see if it slowly starts to drain
Old January 8th, 2012, 02:51 PM   #19
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
That just sounds lazy. It's something that can be fixed. Just trace it down.
Old January 8th, 2012, 03:05 PM   #20
SSG Pate's Avatar
00 Mustang GT Vert/88 5.0
SSG Pate has a spectacular aura aboutSSG Pate has a spectacular aura about
Deal with it is not a good anwser, many times a battery will show good, and have a dead cell. if your alt is running your car properly, and it checks out cross that off the list, and replace your battery. Even brand new batteris go bad. Replace it and your issue will go away.
Proud Iraq and Afghanistan War veteran
Powered By MMR 4.75L Stroker, Tuned at Kurgan Motorsports
Threads Similar to: Battery Drain
How long till battery drain while lisitng to radio car off? Jump car battery dead StoneColdStang V6 Mustangs 8 December 22nd, 2011 08:40 PM
Key Off Battery Drain ajzride Classic Mustangs 14 October 17th, 2011 09:59 PM
Battery Drain sukibusa 99-04 6 August 24th, 2009 11:48 PM
Battery drain 93Notch Audio/Video 3 February 16th, 2007 01:16 AM
Battery Drain 5.0mustang9509 5.0 Mustangs 1 November 7th, 2006 07:15 PM
