Rearmount Turbo?? - Page 3
Old January 6th, 2012, 03:19 AM   #41
Mighty Stang's Avatar
2003 mustang gt
reallly slowwww
Mighty Stang is on a distinguished road
lol i haven't droven either a PD or Centri blower car so i don't know what is funner (not a word I know) to drive bcs i just want something to fucked around in the streets with. Money isn't a huge thing. I wouuld rather pay the xtra money and get something i want then get something cheap and wish i had spent more
Minnesota!
Too many exterior mods.....3:73 Gears, BBK Long Tube, O/R H Pipe, Stainless Magnaflow, JLT Ram Air MGW Short Throw Shifter, FLSC, MM C/C plates, H&R SS Springs,
Old January 6th, 2012, 03:22 AM   #42
stal94gt's Avatar
2003 mustang v6 ;)
slow
stal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud ofstal94gt has much to be proud of
sorry i have not read the entire thread, but i would not go with rear mount turbo kit. it is a ton of pipe to run, plus it has quite a bit of lag in it. many people have issues with water damage from where the turbo is mounted. you really want to mount the turbo as close to the motor as possible. hot air is fast air
bone stock from the factory!
Old January 6th, 2012, 03:23 PM   #43
N20zuki is on a distinguished road
You should read the whole thread though... Multiple people have stated alot of lag but nobody has posted any reason or evidence of this... I have seen and heard only good things about these kits and is a great alternative as well...
2004 Mustang GT 40th Aniv 5spd, Stock for now.
2005 Joe Gibbs Silverado #0396
1986 Monte Carlo SS
Old January 6th, 2012, 04:14 PM   #44
slow02gt's Avatar
2002 mustang gt
11.38@119
slow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the roughslow02gt is a jewel in the rough
Send a message via AIM to slow02gt
yes rear mounts have lag...one way they try to improve on spool time is the exhaust houseing on the turbo is only an .43 a/r so helps but cant make big power because the car will fall on its face up top..
and you posted videos on VETTES...these motors are 281ci...not a 427ci like the z06 and not 346 like a standard ls1 car...so they move ALOT more air than these motors..another thing about sts kits is you need to run 2 scavenger pumps..which are loud and can easily fuck up and you will never know till its to late...unless you go with the comp turbo oil-less turbos..
anything else?
built motor,trickflow heads,logan intake,80mm comp turbo on the way..
Old January 6th, 2012, 04:19 PM   #45
slow02gt's Avatar
2002 mustang gt
11.38@119
Originally Posted by moneygreenstang View Post
The rear mounts are popular on F and Y body cars because this is NO room in the engine bay, I removed and re installed a LT1 in a camaro over the summer and theres really no space for a turbo up front without lots of modfication.
x2 another reason
and they dont like doing it either because of the scavenger pump problem..alot of them make a oiling system in the back just for the turbos..which is more money and more shit to put on the car..
Old January 6th, 2012, 06:22 PM   #46
anything else?
All right then well heres some videos of the little 281 doing work then....
1986 Monte Carlo SS
Old January 6th, 2012, 07:05 PM   #47
slow02gt's Avatar
2002 mustang gt
11.38@119
so you post up vid of some stock mustangs? besides the drift car(which actually has its own rear oiling system for the turbo also)
then i am stil correct lol
good try though
Old January 6th, 2012, 07:08 PM   #48
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
Slow dont like black people.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 6th, 2012, 07:25 PM   #49
MM's king of Neon's
WickedSnake00's Avatar
404 - car not found
17.81@87
WickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud ofWickedSnake00 has much to be proud of
I believe I mentioned the DVDB car earlier. I didn't know he used an independent oiling system. On a race car that's certainly wiser, given the concerns of oiling system failure.
Like I said earlier, it's definitely something you can do, and you'll get some results, but it won't be on par with a closer turbo, and will be considerably more vulnerable in the event of a failure.
Official Secondhand Snake Build Thread Here
Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra.
For Sale: P71 Interceptor motor
Threads Similar to: Rearmount Turbo??
Dyno results from new CEA 67mm Billet Turbo from Precision Turbo 499whp 552wtrq 13psi Turblow 99-04 18 November 9th, 2010 09:12 PM
Turbo timers and Boost Controllers? Turbo guys where you at? 95StangSVT General Tech 14 July 11th, 2008 07:01 AM
Mellon's Twin Turbo Stealth vs Wills99z's Single Turbo z28 Mellon Videos 10 December 30th, 2006 10:05 AM
Super Charger vs Turbo/Twin Turbo: Pros and Cons of each FireryDriver 2005 - 2010 9 September 17th, 2006 04:15 PM
