2001 Mustang GT
How Much?
How much power can a naturally aspirated 2v 5.4 Make compaired to the 4.6?
![]() BBK Shorty headers,O/R X pipe, Magnaflow Catback CAI Accufab 75mm throttle body C&L Plenum Tokico Lowering springs Trans go shift kit Soon:Comp Cams,SCT Tuner,3:73 Gears,MM Cast Chamber Plates |
2003 Mustang GT
There was a guy that made 395rwhp out of his 2v, stroked to a 5.3l I believe lots of compression, tfs heads, real aggressive mhs stage 4 cams.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
2001 Mustang GT
is it worth swapping to a 2v 5.4?
2003 Mustang GT
I don't think so. I'd rather swap to a 4v setup if you were going to stay all motor and wanted big numbers.
2001 Mustang GT
Im just saying the 2v 5.4 bc everything is pretty much the same.. from the 4.6
Look at what Shaun wrote and decide if it is worth it to swap to a 5.4.
![]() 2003 DSG Mustang GT 5spd Full Bolt On's, Suspension, Built Rear, V1 S N/A: 266/300, 3,550lbs, 13.44 @ 100.5 1.77 60' Non-intercooled: 356/371, 3,575lbs, 12.81 @ 110.47 1.86 60' Intercooled: 362/370 |
