Compression Test With Warm Engine
I'm thinking of doing a compression test on my engine. I've read that you have to do it when the engine is warm to get the best readings. Will pulling the plugs out while the engine is warm mess up the threads on the heads? I want to avoid any possible damage.
04' GT - Vortech & Meth |
2002 mustang gt
![]() iTrader: 1 reviews
It should make it easier to get the plugs out
Rock stock
2003 Mustang GT
The heads are aluminum, I was always told to wait because the threads can easily strip out. So not exactly sure.
![]() Vortech V1 Intercooled @ 11psi 394rwhp/392rwtq @ 9.5psi 415rwhp/400rwtq @ 11psi on Methanol Tuned By: Pete @ Performance Dyno Affordable Supercharger Build Guide Supercharger Info for Noobs |
I've pulled them HOT, COLD, WARM at least 40 times on the worst series motor built. The windsor 4.6. Never had a plug problem even with 150hp wet kit and 12lbs of boost. The key to survival is correct plug torque and anti-seize. 156in/lbs final torque with anti-seize and your golden.
99 Mustang GT 446rwhp, Vortech Aftercooled, Killer Chiller @12lbs, HPX, 3.73s, MGW, Battery Relocation, Intercooler Tank Relocated, CF DF clutch, Steeda Quick Release Quadrant, 75mm TB, Ported C&L Plenum, Stock PI Cams Advance 4 degrees, Pro Chamber |
12.88 @ 109.45 N/A
![]() ![]() ![]() ![]() ![]() ![]() iTrader: -1 reviews
If the engine is at normal operating temp, it is fine to pull the plugs. If the engine is HOT, then wait til it cools down. Upon re-install, use anti-seize on the spark plug threads and actually torque them down.
#6 | |
Also it is best to use a 1/4" drive torque wrench as you will be operating at the top end of it's range. A 3/8" drive wrench is OK, sort of. Using a 1/2" drive wrench is generally not possible because most of them have a range that starts out at 20 lb-ft. Here is an alternative I have been using for a while now, a torque limiting spark plug socket: ![]() Read more about this here...
-cliff knight- My Mustang 2003 GT, UPR X, 24lb/h injectors, Magnaflow, 180° stat, PP 70mm TB & plenum, DF Commando, Steeda UDPs, Ralco RZ_flywheel, RAM HDX clutch, WX EFX COPs 3.73s, 262 rwHP/305 lb-ft. Flex-fuel: burns gas and rubber...
1999 GT 35th LE
CliffyK your link isn't working!
![]() Drive it like you stole it |
Working on it right now...
[edit] Got it, the blog index was corrupted... [/edit]
Last time I changed the plugs I used anti sieze and torqued them to 13 lb-ft. I will let the engine warm up just enought for the fan to kick on then I will pull them and do a compression test. Does the throttle body have to be at WOT for the readings to be correct?
Yes, it does not have to be ALL the way open but at least 1/3 to 1/2 open--also remove all eight plugs before conducting the test...
Threads Similar to: Compression Test With Warm Engine
| Question on compression test and/or leak down test | TheOdessa | 99-04 | 20 | November 25th, 2011 11:30 AM |
| Compression Test | Stangin94GT | 5.0 Mustangs | 6 | July 27th, 2010 12:01 AM |
| compression test | hardhitter | 99-04 | 81 | July 9th, 2010 09:14 PM |
| Compression Test! | 2003_GT | 99-04 | 11 | June 9th, 2010 11:58 PM |
| compression test | winterftbl | 99-04 | 5 | June 18th, 2009 02:56 PM |
