Electrical Help PLZ - Page 2
Old January 6th, 2012, 04:16 PM   #21
waynetx383 is on a distinguished road
That's your best bet for the ground. You should be able to find a good ground location in the dash around the din. Typically aftermarket headunits use a slightly larger gauge ground wire coming out off it's harness plug and the factory wiring the kits have you wire it to is a lot smaller gauge. Also, if you run the ground through the factory harness it has to cover a lot more distance. Grounds should always be kept a short as possible.
Old January 6th, 2012, 04:20 PM   #22
2001 mustang gt
14.5
noser7 can only hope to improve
Makes sense. Thanks G
Sent from my LS670 using AutoGuide.Com Free
Threads Similar to: Electrical Help PLZ
Need Electrical Guru's help! Electrical gremlins in my cluster 94FiveOVurt 5.0 Mustangs 6 August 8th, 2011 07:37 PM
electrical HELP!! Ksmith7548 Audio/Video 11 November 11th, 2009 01:15 PM
electrical : ( grnstang 5.0 Mustangs 17 March 9th, 2009 02:32 PM
electrical help bobb17 2.3 Mustangs 10 February 10th, 2008 11:27 PM
Electrical help... joeice14 2005 - 2010 8 January 30th, 2008 01:34 AM
