My New Romeo Motor With My Blower Bracket..
Old January 6th, 2012, 09:52 AM   #1
BakerFX4's Avatar
BakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud ofBakerFX4 has much to be proud of
iTrader: 14 reviews
Question.... My heads are already romeo. My new block will be a romeo block. My blower bracket is for a windsor. I will have to get the bolts for a romeo timing cover. All my accessories and timing cover will be the same so there is no reason for me to not be able to use my windsor blower bracket right?
The only reason I think there is 2 different procharger brackets is because of tensioner shit. But since Im keeping my goods on the front of the motor the same, should stay ok right? Just making sure. I hate interruptions.
4.75 MMR 900se
Livernois ported heads
HP 292s blower cams
Procharger D1sc at 20+ psi
IW 15% OD pulley
(and more bolt ons)
E85
Tune/numbers coming shortly!!
Old January 6th, 2012, 10:06 AM   #2
I like boobs!!!
NickPohlAandP's Avatar
2000 GT convertible
dunno
NickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of lightNickPohlAandP is a glorious beacon of light
If everything on the front of your current engine is going on your new engine then there's no reason it won't work just fine
Last time you voted to prove you aren't racist. This time prove you're not an IDIOT!!!
My Garage--->http://www.moddedmustangs.com/forums...-member-46919/
Old January 6th, 2012, 12:17 PM   #3
Shaun03GT's Avatar
2003 Mustang GT
Shaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant futureShaun03GT has a brilliant future
iTrader: 12 reviews
The 99 motor has a 3 bolt tensioner cover like the 96-98. In 2000 they switched to a 1 bolt cover. So your bracket will work on anycar with a 3 bolt cover since yours is a 2000 (right?)
Vortech V1 Intercooled @ 11psi
394rwhp/392rwtq @ 9.5psi
415rwhp/400rwtq @ 11psi on Methanol
Tuned By: Pete @ Performance Dyno
Affordable Supercharger Build Guide
Supercharger Info for Noobs
Old January 6th, 2012, 01:29 PM   #4
Eagle2000GT's Avatar
12.73@111.36
Eagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to beholdEagle2000GT is a splendid one to behold
According to the ProCharger installation manual. 99 is different. 00-04 is the same. It doesn't matter if its Windsor or not.
ProCharger P-1SC, 9 psi, STD 396/383; Uncorrected 388/375; SAE 383/370
Mods list in Garage.
Old January 6th, 2012, 05:49 PM   #5
'00 gt, '95 gt, '83 lx
11.85@116
bottled2v is a jewel in the roughbottled2v is a jewel in the roughbottled2v is a jewel in the rough
Send a message via AIM to bottled2v
yeah the brackets dont go by windsor/romeo. just use your same timing cover and the bracket will fit fine. the 96-99 had the 3bolt style and 00-04 had the 1bolt style.
'00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come.
'95 GT, 347, tko, etc-11.8@116-sold.
WTT-my mildly built 4r70 for t56/tko.
Old January 6th, 2012, 06:55 PM   #6
BakerFX4's Avatar
iTrader: 14 reviews
i think its 99/00 because mines a 2000 and it uses the 99 bracket (the one that looks like a "y". The 01-04 uses the one that looks like a "c" i think. Oh well. lol
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old January 6th, 2012, 08:08 PM   #7
12.73@111.36
My 2000 is the same at the 01-04s. Belt routing,everything. It's the 99s that are different. Here is a page from my installation manual. This is exactly the way my 2000 is set up.
Old January 6th, 2012, 08:21 PM   #8
12.73@111.36
Here is the same page for the 99. It is very different.
Old January 6th, 2012, 09:18 PM   #9
BakerFX4's Avatar
iTrader: 14 reviews
oh.... damn... so you are running that y shaped bracket?
4.75 MMR 900se
HP 292s blower cams
IW 15% OD pulley
(and more bolt ons)
E85
Old January 6th, 2012, 09:54 PM   #10
Shaun03GT's Avatar
2003 Mustang GT
iTrader: 12 reviews
Eagle is running the first picture he posted. You have to remove the bracket to get the belt on.
The 99 timing cover bracket (with the 3 bolt tensioner) you dont have to remove the bracket to put the belt on.
Old January 6th, 2012, 10:18 PM   #11
12.73@111.36
Shaun is correct. I'm running the first picture and it is a pain taking the bracket loose to change the belt.
Old January 6th, 2012, 10:48 PM   #12
Baker Jr.
bandity2k00's Avatar
Coming after build!!
bandity2k00 is a jewel in the roughbandity2k00 is a jewel in the roughbandity2k00 is a jewel in the rough
Send a message via AIM to bandity2k00
Yes you can use your same bracket..
your running the same timing cover ...only if you changed to romeo timing cover. You just need the nee bolts for bolting timing cover on and then your good
MMR-Modular Mustang Racing
Phils Machining-For your ABS Module Delete Manifold!
American Muscle-www.Americanmuscle.com
HorsePower By Hermonn-TUNER
THANKS TO ALL SPONSORS,READY FOR THIS 2012 RACING SEASON!
Old January 6th, 2012, 11:59 PM   #13
Baker Jr.
You have a romeo timing cover with mid 01-04 procharger bracket. Which is the "Y" bracket
Old January 7th, 2012, 02:38 AM   #14
12.73@111.36
If you look at the very top sentence of the first page I posted. The Y bracket fits 00-04 Mustang GTs. It doesn't matter whether its a Romeo or a Windsor. They changed the tensioner and added an extra idler pulley in 2000. I have a Windsor motor and I'm running the Y bracket.
Threads Similar to: My New Romeo Motor With My Blower Bracket..
Motor mount bracket not lining up! redfire gt 2005 - 2010 8 June 20th, 2011 10:17 AM
a/c blower motor bustedknuckles 94-95 5 June 14th, 2010 06:06 PM
Interest in Bracket for SVO/Roush Blower? MikeB 96-98 0 December 18th, 2007 04:16 PM
