#21 | |
That's exactly what i've did when i replaced my cylinder heads (due to bad tune which cause extreme hot spark plugs)
Dark Shadow Gray 1 mod or 2 ![]() Thanks to Sarah for the Sig!! ![]() http://www.moddedmustangs.com/forums...-member-35708/ MM DSG Crew Member#3 |
#22 |
MM's king of Neon's
404 - car not found
17.81@87
When Eagle mentioned blowing lots of motors I expected a 5.0 in there somewhere. All the 5.0 guys I know usually have a disposable mentality. Boost the shit out of their motor, or spray the hell out of it till it pops, then go get a new one. Why re-build when you can get a salvage?
Which is also a strength with our 4.6's. They're everywhere in the junkyards. Better still you can get an Explorer which is effectively the same, but with an aluminum block. I tried talking a friend of mine into getting a MKVIII motor when he popped one of his pistons on nitrous. He refused, and ended up spending more to repair his than a MKVIII swap.
Official Secondhand Snake Build Thread Here Looks Like a Cobra, Sounds Like a Cobra, Tastes Like a Cobra, Not a Cobra. For Sale: P71 Interceptor motor ![]() |
#23 |
2000 Gt
Is there any chance that an extremely deteriorated timing chain holder ( the orange plastic peice ) could have caused this to happen?
also, the car was running an sct flash tune 91 oct which was specified for all my modifications, i'll just assume if it wasn't the timing chain housing thing, it was that the fuel injector was bad? i think at this point i'm just going to have the cylinder re-honed, possibly bored out slightly (like some of you have suggested) and get it running again, if all appears well after a while hopefully i'll start running some low amount of boost
2000 Gt - full bolt on's 3.73's eibach suspension. 265hp/307tq |
#24 | |
MM's king of Neon's
404 - car not found
17.81@87
Now for detonation, the main factors are AFR, ignition timing, compression, octane, IAT's, and swirl/squish. Your compression, IAT's, swirl, octane, and swirl are the same across the entire bank. Since the injectors are independent, it could be a bad injector causing a lean AFR. It could also possibly be ignition related, but this is a long shot. I don't think I know of a failure mode that causes premature ignition, normally ignition failure results in late/no spark, which is a misfire. The only other thing that could happen is if a valve got hot enough to cause pre-ignition due to carbon deposits, but this is something you see in race cars, seldom street cars. Looking at the valves in that cylinder may not hurt though. And I'm sure someone else can chime in about how agressive or conservative the SCT 91 tune is.
#25 | |
2000 Gt
what could the problem have been? my plugs? i had just replaced them with ngk platinum plugs
#26 |
2003 mustang v6 ;)
slow
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 2 reviews
email tune mixed with a bad injecter could have alot to do with this. even though people say they are safe there is no real data on your car vs info that they think they have. 91 octane tune could have been confused and sent out as a 93 tune. or you could have gotten some bad gas which happens sometimes. i do my best to fill up at the same gas station where i got my tune from
![]() bone stock from the factory! |
#27 | |
2000 Gt
#28 | |
MM's king of Neon's
404 - car not found
17.81@87
Like I said, if your coil or plug craps out on you, it usually causes a misfire, which WILL NOT cause detonation. Especially with the fact you have new plugs I don't think this was a factor. You may have been hearing very slight detonation, and when you romped on it, that was the straw that broke the camel's (or piston's) back.
#29 | |
2000 Gt
Threads Similar to: Engine Blew Piston - Still Reliable? (PICS INSIDE!!)
| Finally getting engine together. (Pics inside) Where to hide the wires...? | Mustang46 | 99-04 | 22 | January 1st, 2012 11:21 AM |
| New motor blew a piston or something? :( | Roadrashjr | 99-04 | 34 | October 12th, 2011 11:12 PM |
| fire extinguisher at work blew up!(pics inside) | 00mustang00 | The Clubhouse | 20 | November 12th, 2010 01:13 AM |
| engine bay painting..pics inside... | oscrfsh | 5.0 Mustangs | 15 | June 16th, 2010 05:36 PM |
| how reliable are piston rings | ddarkslayer | 5.0 Mustangs | 1 | November 12th, 2009 01:54 AM |
